Thread: Can anyone help me with a dvd rec. question please? |
New member Username: Dorkus_mcforkus
Beverly hills,
California
Post Number: 2 Registered: Jun-04
| Posted on Saturday, August 07, 2004 - 01:56 am: |
I dont know if something like this exists...but is it possible that.. well say i wanted to tape a series on dvd..can u later add programing to a dvd disc the next week? or must it all be done at once. becasue i sort of have a tivo. i have dish network and have the dvr system which stores 100 hrs of programing on the hard drive...so say after 2 episodes of a certain show are stored on my dish dvr, is it possible to tape them on a dvd disc together? also are there any systems that can do simple non linier editing...like taking out comercials and stuff like that on to a dvd-r or dvd-rw disc..casue i want it to be compatible with most dvd players. if anyone could help me here i would appreciate it very much. i basicaly want to know if i can tape several things onto one disc, and if i can edit out comercials and stuff on the hardrive without having it lose any compatability. thank you. |
Silver Member Username: Samijubal
Post Number: 114 Registered: Jul-04
| Posted on Saturday, August 07, 2004 - 11:49 am: |
You can record onto a disc till it is full, it doesn't all have to be at the same time. If you use DVD-RWs the commercials can be edited out, DVD-Rs can't be edited except for deleting an entire recording. |
Unregistered guest |
| Posted on Sunday, August 15, 2004 - 12:09 pm: |
how can you record from DVR to DVD, period? |
Post Number: 128 Registered: Jul-04
| Posted on Sunday, August 15, 2004 - 12:59 pm: |
I have never used a DVR, but I don't know why you couldn't just hook it up to a DVD recorder and record. |
New member Username: Kikorama
Post Number: 1 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 12:43 pm: |
you would need a dvd recorder to connect to your dvr and burn your dvd-r. i have a panasonic dvr that records to hard drive and dvd discs. it allows me to do very precise edits back and forth (using the hd and dvd-ram discs) without any degradation hope this helps |
| Posted on Wednesday, December 15, 2004 - 08:33 am: |
My wife records soaps daily on vhs then records over them after watching. Can you do the same thing with a DVD recorder ? |
Post Number: 536 Registered: Jul-04
| Posted on Thursday, December 16, 2004 - 09:51 pm: |
As long as you use a rewritable disc, DVD-RW, DVD+RW, DVD-RAM. |
Bronze Member Username: R1t1joby
Post Number: 15 Registered: Oct-04
| Posted on Friday, December 17, 2004 - 12:42 am: |
Omar, you most definitely need the Panasonic DMR E-85 DVD Recrorder. It has a 120 gig hard drive where you can hook up, your TIVO machine, and anything else you want, then record it onto the Panasonic hard drive, edit out the commercials, or anything else you want edited out, then dub it onto a DVD-R. You can tape a TV series on it's hard drive and keep it on your hard drive until the next episode airs or dub it from the hard drive onto a DVD-R disc. Just do not finalize the disc if you are planning on adding stuff to it later. So, yes, you can later add stuff to discs that already have something on them just as long as you have not finalized the disc yet. I record weekly TV series on my Pansonic DVD Recorders hard drive, edit out the commercials, put them on a DVD-R disc. Then the next week add another epsiode to the disc. But most the time, I save the episodes in my Panasonic's hard drive until I have enough episodes to put on disc so I can do it all at once and finalize the DVD then delete the episodes out of my hard drive to make room for the future recordings. The Panasonic recordings on DVD are compatible with more DVD players than I have ever known.
