Home > Message Board > Home Video > Satellite TV > Archive through August 27, 2004 > Will this Dish 500 work with the pans...
Author Thread: Will this Dish 500 work with the pansat 2500a?
Username: Eqlootseller
I have a dish 500 with 2 LNB's and they have 2 sw21 switches. Since I had Dish Network years ago, my plan is to put this dish back up, use my Dish Network box to locate the 110 and 119 satellites and then swap out to my Pansat 2500A box.
Will this setup work or what do I need to do to make the dish work. Pic is attached showing the dish I have.
Thanks
image/bmpUpload
Dish 500 Duel LNB -1.bmp (76.9 k)
GET A FREE DIRECT TV DISH
Username: Jmill1948
Chester, Va
Usa
Post Number: 156
need dish pro 500
Username: Ben_d
yes you can just run each side into your diseqc and treat them as seperate satellites no switch 21's
Home > Message Board > Home Video > Satellite TV > Archive through August 27, 2004 > Will this Dish 500 work with the pans... [ « Previous ] [ Next » ]
