Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2004 > WinExplorer script error when program...
Author Thread: WinExplorer script error when programming bootstrap
I have an HU card which I clean in Extreme HU. I've been trying to re-program my bootstrap in WinExplorer with a "Blocker Options" file since it's no longer allowing my bin files to work on the card. I keep getting an error message "Script Error on Line 227, Sc.Getbyte.Requested Byte Exceeds Last Read Request". Anybody know what I need to do?
I keep getting
Sc.GetByte: Requested Byte Exceeds Last Read Request
when trying to program my bootstrap and my card just runs forever and never cleans now. I have used it before on 4 cards and it worked but now it does nothing but attempts to clean.
Any help is appreciated. thanks
you do not have enough power running to your loader to keep up with winexplorer! you need to get a power adapter for you loader, your pc power isn't enough. if you have a adapter try setting it on 9voltz. the adapter i'm using is a(model:AH3 WH)(INPUT:AC 120V 60Hz 7W)(OUTPUT:DC 1.5/3/4.5/6/7.5/9/12v)(CURRENT:DC 300mA max)its a RCA ADAPTER FROM RADIO SHACK ABOUT $12.00.
JoeyG
I get the " error on line 248" and I am using an adapter set at 9 volts.What else can I try?
error in winexplorer.exe 0096:bff8e1ad
Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2004 > WinExplorer script error when program... [ « Previous ] [ Next » ]
