Thread: Emerson DVD player subtitle problem |
Zeb McKinney |
| Posted on Sunday, November 16, 2003 - 10:52 pm: |
I have an Emerson EWD7002. Every so often, subtitles/captions will appear on screen while playing a movie even though I have them turned off in the player's setup menu. I tried turning them off using the disc's menu also but it still happens. My television isn't closed caption capable so I know it isn't the problem. Has anyone else had a similar problem with this model and/or know how to fix this? |
Rob Derbyshire |
| Posted on Wednesday, December 10, 2003 - 05:04 am: |
I also have the same problem on my Emerson TV/DVD combo (ETV101), any help would be appreciated. |
Unregistered guest |
| Posted on Friday, January 16, 2004 - 04:38 am: |
I have the same problem with my Emerson TV/DVD Combo and I am currently chasing their tech support in th UK as well as Funai the manafucturer...I'll post and answer when I get one. |
stuart marsh Unregistered guest |
| Posted on Friday, January 16, 2004 - 03:49 pm: |
Update for emerson dvd/tv.......no reply from Funai or emerson...however I've discovered that if you press the "gui" button and go accross and highlight the (a) marker for the subtitles and arrow down it will then change to off and viola, subtitles are now off. You will need to do this everytime you go back to review the dvd, but at least it works...
Lee Sola Unregistered guest |
| Posted on Monday, February 09, 2004 - 11:05 pm: |
I'm having a problem with my Emerson DVD/CD player EWD7002. The audio synch drifts badly. I first noticed that when I'm showing subtitles the audio is always out of synch. A few months later, the audio seems to drift out of synch gradually when not using subtitles. If I stop and start again, it fixes itself, but very soon drifts again. I've been wondering if it's the DVD player or bad DVD's. Anyone know if this is a common flaw with this machine? |
| Posted on Sunday, April 04, 2004 - 11:12 am: |
I have the same problem with an emerson dvd/vcr combo. It is totally pathetic. At first I thought that it was too hot, but I've had it start drifting two minutes after I start a DVD. We need to try and get a recall on this piece of crap, and stop everyone else from buying one!!!! |
| Posted on Tuesday, April 20, 2004 - 02:21 pm: |
I bought an Emerson vcr/dvd 4 mos. ago. Now all the menu options are in spanish, some of the remote buttons don't work, and the vcr records snow. I don't know what to do. Does this sound familiar to anyone? |
stephon Unregistered guest |
| Posted on Friday, April 30, 2004 - 08:42 am: |
i have emerson ewd7001 dvd player.it will play the first couple of seconds then it act like it will pause,but the counter will keep going.i can put it in fast forward,@2x it not do anything,@8x it will fast forward. |
New member Username: David
JOHOR BARU,
JOHOR
MALAYSIA
Post Number: 2 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 01:47 pm: |
jvc dvd player always claim that it can player all problem dvd , is it true ? |
JOHOR BARU,
JOHOR
MALAYSIA
Post Number: 3 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 01:54 pm: |
i ever uesed phillip and samsung dvd player and came across a lot of problem of skippng some problem this, I try very hard to solve this problem by looking for new player , finally my found china-made dvd player is better, it is Amoi dvd player, is anyone want to know how powerful this dvd player |
JOHOR BARU,
JOHOR
MALAYSIA
Post Number: 4 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 01:59 pm: |
even if samsung dvd player has special function of fit screen but it sacrisfy a lot of picture quality. |
JOHOR BARU,
JOHOR
MALAYSIA
Post Number: 5 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 02:02 pm: |
In my country every dvd player is code-free. there are no problem of unlock dvd code |
JOHOR BARU,
JOHOR
MALAYSIA
Post Number: 6 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 02:06 pm: |
in fact china made dvd player is very cheap and yet is has adequate function for example, the progressive scan and DTS decoder etc |
| Posted on Saturday, June 05, 2004 - 11:55 am: |
can anyone tell me what remote control i can buy that is compatible with the EWD7001. My dog chewed up the one that came with it? |
| Posted on Monday, June 07, 2004 - 10:24 pm: |
My DVD player pauses for like a split second every so often. What causes the problem and how can I fix it. I don't know if this has anything to do with it but I have my DVD on top of my VCR which sits on top of my TV. Thanks in advance for your assistance. |
New member Username: Cmcneil
Fayetteville,
NC
Post Number: 1 Registered: Jul-04
| Posted on Monday, July 05, 2004 - 02:47 pm: |
I have an Emerson EWD7002 dvd player but it won't read mp3 discs. Every time I try to play a disc it says "disc error." I misplaced my operating manual and I don't know how to switch from dvd to mp3. Can somebody who had the same type player help me out? Thanks. |
New member Username: J4sonex
Newminas,
NS
Post Number: 1 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 11:28 am: |
does the emerson dvd/vcr work with pal dvds |
| Posted on Thursday, September 02, 2004 - 02:23 pm: |
I am having problems with Emerson like most of you. With so many complaints agaist Emerson's products, why is it not being looked into? Is there a complaint department with the company? What can customers who have paid hard earned money for this faulty product do? |
New member Username: Jwolsey
Somerset,
Ky.
United states
Post Number: 3 Registered: Sep-04
| Posted on Thursday, September 02, 2004 - 06:41 pm: |
i have had problems with this one myself i have not had the problems that some have had but i dont like this one here its not worth what i paid i no that there will be no more emersons for me thats life is to much of a problem to spend good on junk. jwolsey |
| Posted on Thursday, September 09, 2004 - 09:44 pm: |
I'm having problem w/Emerson DVD w/Video EWD2202. After viewing a tape, dvd doesn't work. Need to turn totally off and let sit, most times till next day. Will not "read" dvd - loads till error message appears. I hate it and its just barely over a year old |
| Posted on Wednesday, September 22, 2004 - 05:36 pm: |
I have an Emerson DVD EWD7002. I just got this thing for Christmas!! I'm very unhappy. The subtitles pop up out of nowhere. The audio gets out of sync OFTEN. (Pause and Play usually gets it back on track but that's annoying after a while.) Sometimes it will play audio CD's, other times it won't. Now...IT WON'T DO ANYTHING AT ALL. Every disc that I put in it gets the same message "disc error". When I turn the power on, it tries to load without a disc in it at all! |
sma-movies/dvd Unregistered guest |
| Posted on Thursday, September 30, 2004 - 12:01 pm: |
I have an emerson dvd/vcr player and I recorded a show and it wont turn on the dvd/vcr. Every time I turn the power on it shuts down every few seconds and the cst-in keeps blinking and shutting it down any ideas on how to fix it. I tried turning it on and unplugging it. That fixed it last time. But it wont work. |
| Posted on Thursday, October 07, 2004 - 11:23 am: |
I have a emerson dvd and I can not get it to play ,I lost the operating manual, and I have no Idea how to fix the problem.Its a Emerson MP3 serial# D16340493B Model# EWD7003, can you help me? |
| Posted on Saturday, November 06, 2004 - 12:56 am: |
My emerson dvd/vcr player will not play dvds anymore after two weeks after purchase. It says everytime I put the disk is: Disk Error, might not be a readable disk. I have tried to put a disk cleaner but it does not work. Help. |
| Posted on Tuesday, November 09, 2004 - 07:30 pm: |
i also have the emerson dvd with vcr and now after a year i also get the disk error and if it will play at all it skips badly. is this fixable like a cleaning problem or should i buy new dvd player? please help!! |
onecutebiggurl Unregistered guest |
| Posted on Monday, November 15, 2004 - 11:41 am: |
like so many of you i've had my emerson dvd/vcr combo for less than a year and the dvd player now reads disc error...for the past 3 months. I've tried to find a hotline or website to contact emerson...but i've haven't been successful. I totally agree that this thing is a piece of crap...and should be recalled. If there is anyone who can tell me how to launch a complaint I would really appreciate it. |
| Posted on Wednesday, November 17, 2004 - 12:55 pm: |
I have and emerson DVD/VCR combo. I've only had one problem with the DVD half and it only happened once however I can't get it to record on the VCR half. I put a tape in and it starts playing right away. I push stop and it ejects it right away then shuts off. Does anyone know how to help me with this problem or maybe even be able to tell me what I'm doing wrong? I would really appreciate it.
mad_apple Unregistered guest |
| Posted on Tuesday, November 23, 2004 - 03:14 am: |
I feel like my message should just contain ditto marks, I don't have the subtitle problem, but I have the disc error one, any word yet on what to do besides pitch the thing out the picture window? |
| Posted on Saturday, December 04, 2004 - 06:13 pm: |
I just bought a emerson dvd/vcr combo. I cannot get it to record a cd from vcr. I set the situp menu to dubbing and tried to follow directions. I just get a disc error but i am using the right cd. After reading some of the complaints here I am really considering returning the product while i can. Can anyone tell me which brand would be a good one to buy and easy to use. Thanks |
| Posted on Monday, December 20, 2004 - 06:17 pm: |
whenever i put in a cd into my emerson dvd/vcr combo it reads it but i cant hear anything unless i fast forward or rewind. can n e one help me?
New member Username: Caliguy
Post Number: 1 Registered: Dec-04
| Posted on Friday, December 31, 2004 - 03:54 pm: |
i have an Emerson dvd/video player and i lost the onwers maneul but can sumone plz give me the code for it?? i really need it, my email is rvrr5@yahoo.com |
| Posted on Saturday, January 01, 2005 - 09:44 pm: |
Just got a ewd2004 for christmas and the *&^% thing hesitates, and flat out stops while playing dvd's. After reading this I'm returning it. someone suggested it's a heating problem which makes sense since it seems to do it after playing awhile. |
Anonymous too Unregistered guest |
| Posted on Sunday, January 16, 2005 - 09:51 pm: |
I have had 2 Emerson DVD EWD7002 Had problems with both. WILL NOT buy another Emerson product again. I Will write the company and complain. Shouldn't have to buy a new DVD player every year. Please write the company if you have problems. Then Maybe they will fix their DVD players if they want to sell them. |
harvacles Unregistered guest |
| Posted on Tuesday, January 18, 2005 - 09:08 pm: |
I found the website for you all! I downloaded a manual. http://www.emersonaudiovideo.com Your all welcome! |
New member Username: Duser
Post Number: 1 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 05:19 pm: |
I have an Emerson DVD/VCR player and the DVD player will not work. It is less than a year old and will not play any DVD's. An error message comes up to eject the disk. Is this common and is there anything that we can do to make the thing functional again. The VCR works, at least at the moment. The entire unit does seem to get quite warm. |
New member Username: Freakynkc
| Posted on Monday, January 31, 2005 - 04:10 pm: |
I have purchased both emerson and philips dvd/vcr combo products and they both started the "disc error" crap in less than a year. I have a friend who works on electronics and the problem isn't the brands-it's the combination of putting a dvd and vcr in one unit. They tend to overheat very rapidly and blow out. BUY THEM SEPERATELY!! This will save you time and money. Good luck trying to find a new VCR since they're phasing these out altogether. Hope you kept on to your old ones. |
transistoradio Unregistered guest |
| Posted on Monday, January 31, 2005 - 09:42 pm: |
emerson has a firmware problem,I saw this posted on another h.t. forum . there was a hack posted also explaining how to take care of some of the playability issues. you might find this on a "emerson dvd hack" search . good luck! next time pay alittle more money it's worth it. |
Patrick Korellis Unregistered guest |
| Posted on Tuesday, February 01, 2005 - 12:06 am: |
I have the exact same problem. I just bought it 5 months ago and today it doesnt want to play any DVDs. This product really sucks |
| Posted on Wednesday, February 02, 2005 - 07:40 pm: |
My wife bought the EWD 2004 DVD / VCR combo a couple of weeks ago. WHAT A DEAL!! (right) Apparently someone else bought it first and found out that the remote and instruction booklet is worth more than the player. Because neither one was in the box! After several attempts at hooking it up, all it did was mess up my regular TV reception. My Thanks to haryacles and the web site he provided. I'll try this one and hope for a response! All of my searches have come up empty. Think maybe they don't want to be contacted? We should all learn a leason from this, I guess. There is a difference between a bargin and cheap. MAKE SURE you know the difference!! Big G |
Rickj442 Unregistered guest |
| Posted on Thursday, February 03, 2005 - 01:37 pm: |
I just called the 800 number on the instruction book Tuesday and told them the the audio wasnt in synch. They took my name and address and said UPS would pick it up by the end of the week. We've had this dvd player 7002 for almost 3 years and they are going to fix it for free. They were very polite on the phone. |
New member Username: Aa2zr
Post Number: 1 Registered: Feb-05
| Posted on Tuesday, February 15, 2005 - 04:06 am: |
I've had my EWD7002 for 2 years and have subtitle & disk problems. Also have an AV101C with nothing but problems since day one. Since I bought the AV101C on Ebay I never bothered to contact Emerson about it. I bought it from someone in Canada figuring this would only complicate matters worst since I live in the US. I am looking for an all-in-one remote for the EWD7002. Does anyone know of one that will work? |
ana lilian Unregistered guest |
| Posted on Tuesday, February 15, 2005 - 08:38 am: |
i bought a DVD/VCR emerson model no. EWD2003, but i live in brasil now and i can´t get it to play the dvd's from here... how can i unlock it and change the region??? my e-mail is fashion_ana@hotmail.com. on the title of the e-mail please write "emerson unlock" because i don´t open e-mails from stragers... thank you! |
| Posted on Tuesday, February 15, 2005 - 03:29 pm: |
hey everyone! I have a emerson EWD7004 and can not get it to connect it to my satellite receiver right - can anyone help - no picture no sound. What do I need to do - send me step by step instructions. Thanks |
| Posted on Thursday, February 17, 2005 - 12:27 am: |
I got an emerson dvd/vhs player last christmas. all of a sudden, it wouldn't read my discs, a few days later, it worked and now it doesn't work at all. i tried cleaning the lens, that didnt help. it tries to load disks when there isn't even a disk in it or when i have it set on vhs mode. it's so annoying!!! but since i have my stereo, dvd player and tv hooked up together so i can hear every thing through my stereo speakers as well, i have to leave the dvd tray open so i dont have to get annoyed but the stupid thing trying to load. i HATE emerson! |
| Posted on Saturday, February 26, 2005 - 09:58 pm: |
I _just_ within the last hour bought a new Emerson DVD player as well as 3 new DVD's to replace an old Emerson I had. (which after about 1 year died.) I got it home, hooked it up, opened up a new DVD, stuck it in the machine, and waited... It made some funky clicky noises... sat for a few seconds, then I got a "disk error" notice which informed me I had to eject due to a bad disc. Figuring, okay, it's happened before... perhaps I bought a faulty disk.. I eject it and have a look. Sure enough... from the center to about half way out, there are the scratch markings that look as though someone ran a saw accross the DVD. So... I decide I'll shrug it off... grab new DVD number 2. This time, I check out the disk.. make sure it's not damaged. It's shiney and new. I put it in... the machine makes a funny clicky noise again... still again for a few seconds... and _again_ I get the error message. Now... I'm getting a bit annoyed at this point... I take it out and turn it over to find _IDENTICLE_ scratch markings _EXACTLY_ the same pattern - i mean MIRROR image of the first disc I had put in... Now... I'm pretty pissed... so, I call the 800 number and after about 10 minutes of menus and terrible music, I get a human in the customer 'support' department. She says "Well, I'd exchange it." (Did I call to get the obvious answer?) I say... well, frankly, I don't want another of your machines... it just ate 2 brand new DVD's! What exactly do I do about that? Don't you reimburse people for damage that _your_ machines cause? And she very curtly replied "There's nothin' I can do" and hung up the phone. Now.. I may not be so incredibly ripe if she had been a bit more 'supportive' seeing as how I am a customer... and she works in the 'customer support' department... but now I feel obligated to raise some awareness. I can deal with it happening and being put out a hundred bucks.. not very happy about it, but i'll get over it... what I am not willing to do is sit around silent allowing them to continue to sell and profit from ... well.. a crappy product. I wanna get loud and heard and make them understand that without the support of their customers... they don't have a business. So... whadda ya say? who's ready to tear down some Emerson bottom? ~ Storm elowehionole@yahoo.com |
Danny Mac Unregistered guest |
| Posted on Tuesday, March 01, 2005 - 06:40 pm: |
I've had a Emerson EWR20V4 since the New Year's 05. I recorded about 60 dvds transferred from my old 80's and 90's collection of VHS tapes. I getting scare that in about 8 months this thing is going to take a dump. By then, maybe my 350+ VHS tapes will be done. Thanks for the comments so far mine is working good I usually run it 12 hours a day transferring and have had some problems with skipping near the end of the DVD. I bought about 200 4X TDK from Target and got a good deal and so far they seem to be OK, make sure you get 4X only one's that will work. I did go cheap and have 1 for the bedroom and 1 for the living room. Good thing I only need 1 remote. Our rival in Jr. High School was Emerson hoping it doesn't return
| Posted on Sunday, March 20, 2005 - 04:23 pm: |
Anybody have an emerson ewd2204 with problems? If so, please let me know. I brought it a few months ago, because I had one of the emerson vcrs for ten years with no problems, until it just stopped rewinding one day, so I figured it was time for a new one. Works great, but I would like to know what's down the road. Thanks. |
J. Thorpe Unregistered guest |
| Posted on Friday, April 01, 2005 - 01:40 am: |
I have the Emerson EWR20V4. When off, I notice that the fan / or motor inside runs at all hours of the night and day. Off and on and off and on…. The only way to get it to stop is to unplug the thing. This busy fan would seem to indicate that the machine will break down sooner than should be expected. Many people on this forum seem to be having that problem. Such a fan would also seem to indicate planned failure or poor engineering. I cannot tell which… |
| Posted on Wednesday, April 06, 2005 - 01:23 pm: |
Hey people i nees some help here. i have a Emerson EWD7003, what i am trying to do is burn a dvd's but yet none of them will work in my dvd player. they work on my cousins but not mine. im not for sure if its just the format the is wrong or why it is doing that but i guess my question is does anyone know what format Emerson EWD7003 plays i cant find it anywhere. hit me back....thanx |
| Posted on Tuesday, May 31, 2005 - 12:24 pm: |
Do any of you know of a hack for the ewd2004 to make it region free? |
New member Username: Troll111
Post Number: 1 Registered: Jun-05
| Posted on Wednesday, June 22, 2005 - 12:45 am: |
Can anyone tell me the code from the emerson dvd player for a universal remote. We purchased a demo tv and it lost its remote. We are trying to program it into our dish satelite. ??? |
