Thread: VCR 2 VCR COPYING |
JOE YO 1 THANKS Unregistered guest |
| Posted on Sunday, July 18, 2004 - 12:02 am: |
IM HAVING TROUBLE HOOKING UP 2 VCRS TO MY TV SO THAT I CA RECORD MY VHS TAPES ON BLANK ONES. I NEEED TO KNOW EACH AND EVERY STEP TO DO THIS, THANKS, JOE
Bronze Member Username: Samijubal
Post Number: 73 Registered: Jul-04
| Posted on Sunday, July 18, 2004 - 11:29 am: |
Hook RCA jacks from the play VCR out to the record VCR in, then you have to change the record VCR from tuner to line. If you are trying to record pre-recorded videotapes you will probably have copyguard problems. |
| Posted on Friday, October 22, 2004 - 06:37 pm: |
i am also having the same problem recording vcr to vcr. the vcr i am recording TO has no line option. i am rcording from a vcr,dvd player. i have rca jacks that have a red,white, and yellow plugs. only yellow and white on TO vcr, and all three colors on dvd-vcr.i am going IN to the recording vcr, but nothing is recording, i am recording taped tapes to blank one, no copyguard. any help?...........tom |
Silver Member Username: Samijubal
Post Number: 344 Registered: Jul-04
| Posted on Friday, October 22, 2004 - 07:10 pm: |
There should be a input or aux button on either the remote or the unit. You need a Y cable if your VCR is mono or you will miss a significant part of the audio. |
| Posted on Sunday, October 24, 2004 - 01:03 am: |
I'm recording VCR to VCR. One VCR will record the other won't . I have followed instruction until the point of setting recording VCR to "line". NO "line" option on the VCR & I have no remote to help the process...Is there anything I can do??? |
Post Number: 348 Registered: Jul-04
| Posted on Sunday, October 24, 2004 - 01:39 am: |
If the input select button was on the remote then nothing you can do except find a universal remote that has it on it. |
Simply me Unregistered guest |
| Posted on Sunday, October 31, 2004 - 09:02 am: |
hey David can you tell me how to change one of the risisters in the automatic gain control in a VCR |
Post Number: 370 Registered: Jul-04
| Posted on Sunday, October 31, 2004 - 04:26 pm: |
What are you trying to accomplish? I wouldn't suggest playing with adjustments. What's wrong that you need to adjust something? |
Simplyme Unregistered guest |
| Posted on Tuesday, November 02, 2004 - 08:04 pm: |
if you change the value of one of the risistors in the AGC it will remove microvision, i know there is a lot easyer way but i would like to explor it and see how it is done |
Post Number: 376 Registered: Jul-04
| Posted on Wednesday, November 03, 2004 - 11:36 pm: |
The macrovision attacks the color circuits, the gain won't make any difference. |
| Posted on Sunday, November 07, 2004 - 04:41 pm: |
o yeah it works and works good to i found it in a repair manual wow it works great it is in the AGC |
| Posted on Saturday, January 08, 2005 - 04:24 am: |
have 2 vcr's and want to copy a wedding video. dont have a manual on how to do this could you please help on the connections. |
Post Number: 560 Registered: Jul-04
| Posted on Sunday, January 09, 2005 - 10:37 pm: |
Connect RCA jacks from the play VCR out to the record VCR in, then set the record VCR to line. There should be an input button on the remote or the VCR. |
New member Username: Kaydeeqh
Post Number: 1 Registered: Jan-05
| Posted on Thursday, January 13, 2005 - 12:50 pm: |
How do you get past copy protected vhs tapes? I heard that if you cover the safety tab with vinyl tape or cellophane tape. Is that true? Or can you buy something like the Red Copier? Any suggestions? |
Post Number: 563 Registered: Jul-04
| Posted on Friday, January 14, 2005 - 07:27 pm: |
A digital video stabilizer. |
| Posted on Saturday, January 15, 2005 - 07:58 pm: |
I'm also trying to hook up 2 VCR'S to my TV that has cable and wanting to play one and record on the other.
Post Number: 570 Registered: Jul-04
| Posted on Saturday, January 15, 2005 - 08:18 pm: |
Use an A/B switch on the output of the VCRs. |
| Posted on Saturday, February 12, 2005 - 10:20 am: |
Can someone please help me. I want to record a copy of a home video I have. I need specific steps on how to hook up 2 VCR's to do this. One is a built in VCR in the TV set, the other is just a regular VCR. I have the red, yellow and white cables but don't have a clue on what goes where. Thank you very much!! |
