Thread: Dvd plays on pc but not dvd player |
New member Username: Sgee
Post Number: 1 Registered: Jul-04
| Posted on Wednesday, July 07, 2004 - 10:40 am: |
Hi all,I've got myself an external dvd+ recordable drive to make my own copies,when i have burned a dvd it plays fine on my pc,but when put onto my dvd player which is a limit 8070 MR,it does not play at all,i'm burning on dvd+r disc.the dvd player is only a year old,im using nero 6,but also have tried sonic,do you think it is my dvd player? or shall and try to burn onto dvd-R media,Hope you can help me,thanks |
Bronze Member Username: Samijubal
Post Number: 46 Registered: Jul-04
| Posted on Wednesday, July 07, 2004 - 04:01 pm: |
DVD-R is supposed to have a little better compability with home DVD players, but not all DVD players will play DVD-R/DVD+R recordings. The owners manual should tell you if the player is +R/-R compatible, though some will play the discs even if not listed in the manual. |
