Thread: Insert card into loader |
Anonymous |
| Posted on Saturday, November 01, 2003 - 03:22 pm: |
I was having a problem with my loader it was saying that the device was not detected. so I spoke to someone and they told me to try to change the setting to comm2 so that worked but now it says to insert card into loader. i can't get it to work i tried several cards and nothing. can someone please help. |
| Posted on Monday, November 03, 2003 - 04:41 pm: |
if your loader is a mik 3 then card goes in white side up |
| Posted on Tuesday, November 18, 2003 - 11:18 am: |
I have the same problem with my xtreme pro programer it say insert card and i do and it times out waiting for card.... |
New member Username: Woody64
Post Number: 2 Registered: 02-2004
| Posted on Wednesday, February 18, 2004 - 09:57 am: |
I have the same problem with a t9-11 using extreme hu 3.5a.I downloaded a version of extreme hu 3.5a,worked perfectly and all of a sudden I get message to insert .I tried different 3.5as from different sites but no luck,if anybody knows what is going on or any suggestions please post. |
Yonelba olivo Unregistered guest |
| Posted on Thursday, February 19, 2004 - 03:35 pm: |
does any 1 know how to fix..... error v5.0 not supported |
Bronze Member Username: Dtvmaster
Post Number: 17 Registered: 01-2004
| Posted on Friday, February 20, 2004 - 09:50 pm: |
YES INSERT VALID ACCESS CARD MEANS URE IMAGE IS NOT GOOD BRO . U NEED A VALID 3M AND CAM ID . THAT MEANS DEALER SUPPORT EMAIL ME DTVMASTER@AOL.COM I HELP NEWBEES FOR ALL INFO EMAIL ME !! |
