Home > Message Board > Home Video > VCR > Archive through February 16, 2005 > A/V Switch scrambled signal
Author Thread: A/V Switch scrambled signal
I'm running a cheap radio shack switch from tv to a DVD & VCR. Playing newer video tapes back are now scrambled. Tv has only one line out. Any suggestions on what to do?
Username: Samijubal
Post Number: 30
If the switch is hooked up properly there shouldn't be a problem, is the DVD a recorder or player?
Username: Xol
Post Number: 29
Probably you are suffering from protection on the tapes. Take a look here
http://www.dimax.com.ua/
http://www.dimax.com.ua/English/dvd_recorder.htm
Should have known - The cheap Radio Shack cables I bought were faulty - Bought new ones - no problems now.
Thanks
Home > Message Board > Home Video > VCR > Archive through February 16, 2005 > A/V Switch scrambled signal [ « Previous ] [ Next » ]
