Thread: Poor signal quality!! |
Bronze Member Username: Yalfaress
Post Number: 22 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 01:03 am: |
Hi everyone: I finally was able to get a maximum of 40% quality on my cw600 receiver from galaxy 19(97.0 W) I downloaded all the channels into the receiver, and most of them worked for a while. Then they all went scrambled except for Al-jazeera English Channel. I tried to adjust the skew and focus on the LNB to get a better quality, but without any success. In addition, I tried to move the dish up and down and right and left to improve quality, but also without any success as any slight movement of the dish would result in the reduction of quality to 0%. How can I improve the quality to get to watch the channels on my TV. Will a signal amplifier help?? or are there any other suggestions to solve this problem? Please note that the dish view is very clear with no apparent obstructions. |
Silver Member Username: Shenanigans
Post Number: 258 Registered: Sep-06
| Posted on Sunday, November 08, 2009 - 01:56 am: |
It's possible your lnb is faulty. Do you have good signal quality on any other birds? |
Post Number: 23 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 02:11 am: |
Thank you for responding. I really haven't tried other birds. Any other suggestion before replacing the LNB?? |
Post Number: 260 Registered: Sep-06
| Posted on Sunday, November 08, 2009 - 09:16 am: |
I wouldn't replace the lnb until I tried to get a signal on a different satellite. JMO You could also check your coax and connectors to make sure there isn't a problem there... |
Silver Member Username: Chumley
Post Number: 667 Registered: Dec-08
| Posted on Sunday, November 08, 2009 - 09:58 am: |
Also, some channels on 97w will be scrambled.. ..not every TP on that sat will give you good quality. When you adjust the dish and get 40% what TP are you using? On 97w with 30" dish my quality level ranges from 82% to 28%. Even the 28% is watchable with no break-ups, - (cw600s) |
Platinum Member Username: Nydas
Post Number: 16535 Registered: Jun-06
| Posted on Sunday, November 08, 2009 - 10:02 am: |
Chumley watching Iranian TV!!! She must be a double agent or something. |
Bronze Member Username: Dibblydooda
Post Number: 44 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 10:39 am: |
Yaser, don't forget about weather. If you are at 40% sometimes cloudy weather can make a difference, but I would check my connections, terminate unused connections, and check your desq switch. |
Post Number: 24 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 10:46 am: |
chumley: I am getting 40% quality on 12152/H/20000/3/4. On the rest of them I get less than that, even 0% on some of them. The cable and connections are good. Would a signal amplifier help??? |
Post Number: 45 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 11:04 am: |
Yaser I'm not sure if Chumley will agree but the only signal amplifier I would use would be a larger dish or an LNB with a lower noise ratio than the one you have. I personally would go with a spitfire elite LNB it is fairly inexpensive, less than $20.00 and has a .1 db ratio. |
Post Number: 46 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 11:13 am: |
I forgot to note that if you do have a cable run of a 100ft or more then a signal amp might work. |
Post Number: 668 Registered: Dec-08
| Posted on Sunday, November 08, 2009 - 11:38 am: |
TP 12152 is one that has the highest quality reading on my cw600s setup at 72% (earlier i posted 82% as high Q. - actually it's 72%) Check here to see recommended dish size for your location http://www.lyngsat-maps.com/maps/galaxy19_namku.html |
Post Number: 16537 Registered: Jun-06
| Posted on Sunday, November 08, 2009 - 11:48 am: |
A signal amplifier will work if you place it near the LNB. period.period.period.period. |
Post Number: 16538 Registered: Jun-06
| Posted on Sunday, November 08, 2009 - 11:54 am: |
The order of importance to you for better signal. 1. Larger Dish. 2. Better LNB. 3. Signal amplifier. You might have to postpone item 1 because of costs and convenience. Item 2 is easier, but item 3 is easiest to try although least important in the heirarchy of usefulness. in the heirarchy of usefulness, chumley is the least useful person on this forum. Her main aim is to disrupt and obscure the real helpers like Plymouth. Ole McDonald is a newcomer and seems to be posting rationally and intelligently so far. |
Gold Member Username: Gregraf
Post Number: 3861 Registered: Dec-07
| Posted on Sunday, November 08, 2009 - 01:03 pm: |
At least justforhaha's has style unlike you Nyda you Mole and Rat. |
Bronze Member Username: Justforhohas
Post Number: 64 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 01:41 pm: |
Nalin Nyda.........chumley is the least useful person on this forum DO NOT use profanity or demean your fellow users. chumley knows more about FTA TV then you will ever know. To the Mole in charge here now, why did you deleted my thread ? I broke no ecoustics rules and Nalin Nydass who has broken ecoustics rules his thread is still here? This is a Public forum and the members here have a right to know. |
Post Number: 16542 Registered: Jun-06
| Posted on Sunday, November 08, 2009 - 01:48 pm: |
justfarhaha's: You are just boasting about yourself. Everybody on this forum knows that. |
Platinum Member Username: Plymouth
Post Number: 11594 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 02:00 pm: |
justfarhaha's Bronze Member Username: Justforhohas Post Number: 64 Registered: Oct-09 I gived you a advertizing, but it seems that you not understand it!
Post Number: 66 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 02:04 pm: |
Nalin Nyda Platinum Member Username: Nydas Post Number: 16538 Registered: Jun-06 Posted on Sunday, November 08, 2009 - 11:54 am: -------------------------------------------------------------------------------- The order of importance to you for better signal. 1. Larger Dish. 2. Better LNB. 3. Signal amplifier. You might have to postpone item 1 because of costs and convenience. Item 2 is easier, but item 3 is easiest to try although least important in the heirarchy of usefulness. in the heirarchy of usefulness, chumley is the least useful person on this forum.Her main aim is to disrupt and obscure the real helpers like Plymouth. Ole McDonald is a newcomer and seems to be posting rationally and intelligently so far. |
Post Number: 11596 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 02:15 pm: |
Yes Cumley is very good as good that he give RTN on 93W when those channels are on Galaxy 3C 95W. Good comment idiot! http://forum.ecoustics.com/bbs/messages/2/599587.html
Post Number: 670 Registered: Dec-08
| Posted on Sunday, November 08, 2009 - 02:40 pm: |
Keep trying Plymouth.. The Retro Television Network (RTV, previously branded RTN). It scans as RTN EAST AND WEST at 83w - when I had signal. |
New member Username: Somi
Post Number: 6 Registered: Feb-07
| Posted on Sunday, November 08, 2009 - 04:16 pm: |
I just buy K Box PRo and 36" dish, please some one help me for indian and english chanals witch satellite i can select, Thanks Somi |
Post Number: 11597 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 04:21 pm: |
Somi Tom You aim your dish on 118.8W! Do you have a LNB for 118.8?
Post Number: 48 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 04:26 pm: |
I'm curreny watching The Rifleman on RTNWest 83W the signal is weak. Right now I'm getting 0 to 35% quality. Its still there along with RTNEast. Somi Tom you might try 97W they have a lot of foreign stations that free and in the clear. |
Post Number: 11598 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 04:34 pm: |
Cumley You are a joke, on 93W RTN is Russian Television Network which is Dicipher! Take your pills!
Post Number: 672 Registered: Dec-08
| Posted on Sunday, November 08, 2009 - 04:45 pm: |
Playmouth , you brought 93w into the discussion. Read the thread again ! |
Post Number: 7 Registered: Feb-07
| Posted on Sunday, November 08, 2009 - 05:05 pm: |
Yes, i have lnb for 119 and 118 for both and other for 110 thnks |
Post Number: 11599 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 05:17 pm: |
Somi OK aim your dish on 118.8W first, 119 must work, then aim your 110W LNB. Use this to aim your dish: www.dishpointer.com
Post Number: 8 Registered: Feb-07
So its mean i select 97 W (Galaxy 19) for 119 and 118 or (119 echo 7) ? Anad how about 110...? |
Post Number: 11600 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 05:41 pm: |
Somi Forget 97W with your LNB you can't get this bird.
Post Number: 11601 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 05:47 pm: |
Ole McDonald Give me all info for RetroTV, Tp,SR,FEC, polarity and PID. I will check it! Thanks!
Post Number: 676 Registered: Dec-08
| Posted on Sunday, November 08, 2009 - 06:08 pm: |
Somi Tom, It may be best to start another thread or post your questions in a kbox thread http://forum.ecoustics.com/bbs/messages/2/601409.html |
Post Number: 53 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 06:13 pm: |
Plymouth here is what my system scanned. My system picks up best on low scan, if yours likes hi scan better then add 1000 Hz to the TPs RTNEAST Sat AMC 9 / 83W TP 11738 Polarity H Symbol Rate 4440 FEC 3/4 Vpid 32 Apid 33 PCR 32 RTNWEST Sat AMC 9 / 83W TP 11738 Polarity H Symbol Rate 4440 FEC 3/4 Vpid 37 Apid 38 PCR 37 |
Post Number: 54 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 06:16 pm: |
forget what I said hi and low scan I already added the 1KHz in for the normal 10750MHz scan. |
Post Number: 11602 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 06:18 pm: |
Ole McDonald Thanks! I will check it after Nascar!
Post Number: 16545 Registered: Jun-06
| Posted on Sunday, November 08, 2009 - 06:21 pm: |
Somi Tom - new member: Go to the following thread. http://forum.ecoustics.com/bbs/messages/2/601574.html |
Post Number: 11605 Registered: Jan-08
| Posted on Sunday, November 08, 2009 - 07:39 pm: |
Ole McDonald Ok Just found both on scanning the Tp 11738. Thanks |
Post Number: 62 Registered: Oct-09
| Posted on Sunday, November 08, 2009 - 07:48 pm: |
No problem, Plymouth. I'm glad you found it. It was pretty weak this morning, seems to be OK at the moment. |
Post Number: 265 Registered: Sep-06
| Posted on Sunday, November 08, 2009 - 08:46 pm: |
This has turned out to be another top notch thread! Thanks guys!  |
