Home > Message Board > Home Video > Satellite TV > Archive through November 03, 2009 > How do I configure 2 TVs on dish 522 ...
Author Thread: How do I configure 2 TVs on dish 522 receiver?
Username: Edpdx
OR
I had two of the 522 in my house. One receiver upstair- one downstairs. I upgraded to a Dish HD receiver that only supports one TV in the family room. The master bedroom upstairs in now without a receiver. Now I want to eliminate one of the sets from the other 522 and run the master bedroom UHF from the 522 that ran 2 downstairs sets. What is the correct way to set the 522 up?
Username: Nydas
Post Number: 16435
The Dish Network 522 does require some special wiring considerations. There are four methods used to provide signal to this receiver and carry signal to the 2nd television.
Option 1
Use three coax cables from the outside to the satellite receiver location. Use two coax cables to provide satellite signal to the dual tuners and another coax to carry the signal back out to the 2nd television.
Option 2
Use two coax cables from the outside to the satellite receiver location. Use two coax cables to provide satellite signal to the dual tuners and use diplexers to piggy back the 2nd television signal on to one of the two coax cables.
Option 3
Use DISH Pro Plus upgrade equipment to reduce the two cable requirement for the dual tuners to one coax cable. A second coax should be used to carry the signal back out to the 2nd television.
Option 4
Use DISH Pro Plus upgrade equipment to reduce the two cable requirement for the dual tuners to one coax cable. Use diplexers to piggy back the 2nd television signal on to the one coax cable.
Username: Chumley
Post Number: 646
Plymouth ,
This troublemaker has copied it from this site:
www.dbsinstall.com/Dish_network/Receivers/Dish_Network_522_Receiver.asp
Username: Cheap_trick
Post Number: 25
Username: El_toro_the_great
NC
Post Number: 190
Option 1
Option 2
Option 3
Option 4
Good work Chumley old boy
Took the old B!tch out and shoot her.
Home > Message Board > Home Video > Satellite TV > Archive through November 03, 2009 > How do I configure 2 TVs on dish 522 ... [ « Previous ] [ Next » ]
