Thread: Samsung 5067 freezes, green lines, tunes only HD cable channels, etc... |
New member Username: Jburgoon
Post Number: 1 Registered: Nov-09
| Posted on Sunday, November 01, 2009 - 12:08 am: |
My 5067 freezes randomly and often has green lines or blocks in the picture. Sound comes and goes along with the image. This is only in TV mode, picture is fine with other sources. I can usually fix this temporarily by unplugging the tv and plugging back in until it works correctly, but it is totally random and REALLY annoying. Also, problem #2 - even with no freezes or green lines, the digital HD channels with a dash one ending (5-1) seem to work much better than standard cable channels. Often, if I try flipping to a standard channel like 39, I get nothing and my tv starts acting irradically. At other times, they work just fine. Interestingly, they always seem to have a perfect image if they are just in the Picture-in-Picture and not the main channel. I am using a coax straight to the tv with no box or other instrument in between. Once any of these issues occur, my tv starts acting completely irradically (can't change channel, adjust volume, use remote...I just have to unplug it and try again). Other tv's work just fine from this outlet. Any and all of your help is much MUCH APPRECIATED! |
