Thread: Nfusion HD set up problems |
New member Username: Ytofmaisyachev
Brrrrrrrrr Siberia
Post Number: 2 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 05:59 pm: |
I just got a Nfusion hd.I install the latests bin V1.3sr 25F via the uploader 1.7 using a serial cable. I did a scan of 110 & 119/118.8 + 91 & 82 and nothing is on right now. Did I did wrong somewhere,mist something in the install process ??? somebody ?? HELP MY OUT!! THANKS |
Bronze Member Username: Dibblydooda
Post Number: 13 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 06:32 pm: |
I don't know too much about Nfusion, but are you sure your dish is pointed at the correct sat when running your scans? Did you have another receiver before Nfusion that picked up the sats? |
Platinum Member Username: Plymouth
Post Number: 11448 Registered: Jan-08
| Posted on Tuesday, October 27, 2009 - 06:46 pm: |
Ytofmaisyachev After loading a bin you must do a factory default then scan your satellites to assigned each channels to a server adress.
In French: Après que tu as mis la bin tu dois faire un factory default puis scanne les satellites pour assigner les cannals au adresses des servers. Si tu as des problèmes ne te gêne pas, demande!
Brrrrrrrrr Siberia
Post Number: 3 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 06:47 pm: |
All the sats gives me strong signal (85 & up ) except for 118.8 (around 50 percent),I was using a extremeview box before n3 came. |
Brrrrrrrrr Siberia
Post Number: 4 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 06:53 pm: |
Thanks plymouth for the advice.I'll give a try right now Merci Plymouth pour ton conseil. Je vais l'essayer de tout de suite. |
Post Number: 11450 Registered: Jan-08
| Posted on Tuesday, October 27, 2009 - 07:03 pm: |
Ytofmaisyachev Bienvenue! Yé ben drole ton nick!
