Thread: KBOX buying suggestions |
Bronze Member Username: Junkyfunky1234
Post Number: 15 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 04:31 pm: |
Guys, After reading lot of threads, I think kbox have better support for international channels.. so I am going to buy it.. Can I buy it online from any one of the listed authorized dealers at kboxteam.com? Also is buying KBox w/khub enough.. e.g.: http://hellosatusa.com/index.php/fta-receivers/kbox-k-1-plus/kbox-k1-prodigy-w-k -hub.html/?SID=908884bd19654fb4ed700f25ed1d07d9fta-receivers/kbox-k-1-plus/kbox- k1-prodigy-w-k-hub.html I already have a router and can connect the box to internet using an ethernet cable. |
Silver Member Username: El_tora_the_great
Post Number: 174 Registered: Sep-09
| Posted on Tuesday, October 27, 2009 - 04:45 pm: |
Just dont buy it from www.kboxsales.com very poor service. |
Silver Member Username: El_toro_the_great
NC
Post Number: 170 Registered: Jul-09
| Posted on Tuesday, October 27, 2009 - 04:49 pm: |
junky funky if you are located in Canada buy from a Dealer in Canada. Too much to ship from Canada to USA. |
Post Number: 16 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 04:53 pm: |
Nope... Not in Canada I was looking in kboxforum and found suggestion about buying from kboxsales: http://www.kboxforum. com/forums/showthread.php?t=1593 Can you please suggest some other authorized dealer? |
NC
Post Number: 171 Registered: Jul-09
| Posted on Tuesday, October 27, 2009 - 04:55 pm: |
junky funky listen to my twin brother he has forgot more then Nydass will ever learn. |
Bronze Member Username: Dibblydooda
Post Number: 11 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 05:14 pm: |
Do you guys use a proxy server when getting on an IKS site or just hope your ISP doesn't log your ip lease? IKS sounds pretty good but I'm not so sure about the security end. |
Post Number: 17 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 05:16 pm: |
@Ole Mcdonald Why do think getting on an IKS site is insecure? |
Post Number: 12 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 05:54 pm: |
Your box has to connect to the card sharing site via an IP lease from your ISP right? If some goverment or private agency monitors connections to this site and audits IP address that made connections this would lead them to an ISP that would be glad to provide them with names and billing addresses of individuals who acquired the IP leases from them. Maybe they would send you a letter slapping your hand or maybe they would send you a subpeona who knows. If you use a proxy server in located another country I would think your chance of getting fined or worse would go down quite a bit. If the card share site is in another country it maybe safe also but I'm not sure. |
Post Number: 18 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 06:54 pm: |
@Ole_McDonald Okay... let them send me letter.. u don't worry.. and don't hijack the thread please... @others any suggestions for online dealers selling kbox plz |
Gold Member Username: Gregraf
Post Number: 3817 Registered: Dec-07
| Posted on Tuesday, October 27, 2009 - 08:04 pm: |
Its too bad Nfusion did not have the channels you want. They might have in the future. Kbox has lousy support and is down way more than Nfusion. As far as getting busted don't let anyone scare you. These guys just cant afford one LOL. Better chance of seeing Nalin Nyda in a skirt. Ive been using IKS for over a year and i love it |
Post Number: 19 Registered: Oct-09
| Posted on Tuesday, October 27, 2009 - 08:15 pm: |
@greg Its not like nfusion doesn't have channels I want.. If I read the channel list that you provide: http://spreadsheets.google.com/pub?key=to8OFgfam7eXbwTGo2VkyXg&output=html those channels Isouth asian/indian channels) are listed as up.. but I am reading messages here that say that nfusion freeze on channels too much even though it is up.. I don't know what to believe.. I guess I have to buy a receiver to see it myself... do you have a suggestion for nfusion online authorized dealer? and regarding those scary messages don't worry I wont be scared.. what he has written doesn't make much sense.. so I ignored that instead of telling him why he is wrong.. he should start a different thread for that |
Post Number: 3818 Registered: Dec-07
| Posted on Tuesday, October 27, 2009 - 08:31 pm: |
Not sure where to buy in the states. My Nfusion freezes very rarely or sometimes once an hour and only for about 4 seconds sometimes 10. Id rather have that than a receiver that is always down for so called weekly maintenance. Peoples have complaints about both. But from what i read here on a daily basis Nfusion is better. Good luck. |
Post Number: 3819 Registered: Dec-07
| Posted on Tuesday, October 27, 2009 - 08:35 pm: |
N3 is here and you should be happy with anything that works. Kbox team is still learning but they might catch up to nfusion soon. |
Platinum Member Username: Plymouth
Post Number: 11452 Registered: Jan-08
| Posted on Tuesday, October 27, 2009 - 08:55 pm: |
junky funky Nfusion work very well since Nova is not supported, we experimented few freeze when the promise of bin on 10-22-09 was not found but it seems to be OK now. With Kbox you have to reset your receiver and the Khub but on Nfusion you only power off with remote to reset the connexion and the channels come back.
