Thread: Reccommended tv? |
Silver Member Username: Noob101
Taylorsville,
Utah
Post Number: 192 Registered: Jul-07
| Posted on Tuesday, October 27, 2009 - 02:48 am: |
Hi i'm looking to buy a new LCD or Plasma TV but i'm not sure on what to get. It would be used mostly for gaming and normal tv but i would like it to still be 1080P for gaming purposes. Also, looking for it to be anywhere around 37" but bigger the better Price Range: looking to spend around $700 at the most maybe up to 800 but cheaper the better. Thanks in advance. |
Bronze Member Username: Damageinc
Post Number: 44 Registered: Jul-06
| Posted on Tuesday, October 27, 2009 - 03:16 am: |
do we look like a bunch of TV salesmen? this is high tech stuff we're talkin' here about satelites and FTA's and other fancy crap. try 2 floors down,first door on the left, tell'em Neilbob sent ya'...
Platinum Member Username: Plymouth
Post Number: 11443 Registered: Jan-08
| Posted on Tuesday, October 27, 2009 - 07:08 am: |
Flawl3$$ Post your request on this forum: http://forum.ecoustics.com/bbs/messages/2/37.html
Gold Member Username: Tapeman
New York Citay in-HD,
NY
Post Number: 4498 Registered: Oct-06
| Posted on Tuesday, October 27, 2009 - 08:26 am: |
Panasonic best quality at best price LG and Sharp next to Panasonic Stay away from Samsuck and Sony Crap See your Sunday newspapers King Certified |
Silver Member Username: El_toro_the_great
NC
Post Number: 163 Registered: Jul-09
| Posted on Tuesday, October 27, 2009 - 08:40 am: |
Flawl3$$-----Try Sam's Club Lot to choice from and best price. Tell Sam that Whiskey send you.
Silver Member Username: Sump
Post Number: 795 Registered: Aug-09
| Posted on Tuesday, October 27, 2009 - 09:56 am: |
i'll tell ya seen few of the Visio's and there are really nice for the $$ about 1200 for 53" |
Platinum Member Username: Nydas
Post Number: 16397 Registered: Jun-06
| Posted on Tuesday, October 27, 2009 - 10:33 am: |
Within the budget you mentioned, you should get many choices. Look at Future Shop or similar catalogue on line and look at the reviews posted. |
Taylorsville,
Utah
Post Number: 195 Registered: Jul-07
| Posted on Tuesday, October 27, 2009 - 03:05 pm: |
Thanks for the advice everyone. |
