Thread: While changing color wheel, wires pulled loose on male plug! |
New member Username: Blonde_repairwoman
Tampa,
Fl
Usa
Post Number: 2 Registered: Oct-09
| Posted on Monday, October 12, 2009 - 09:35 pm: |
Ok guys I REALLY need your help. I tried to replace my color wheel on my Samsung HLN5065wx DLP using the link from an older post (sept 23 2005). I got everything apart - I already purchased color wheel, went to unplug the color wheel plug (3 wires, 2 white, 1 blue) and all the wires pulled out!!!! The male plug is still attached to the female part in the outlet in the board. I've tried for an hour to gently pull out the plug without loosening it front he board using needle nose, tweezers, pocket Knife- no luck. There is another outlet under that one - nothing was plugged into it, do you think i can use that one? Could it be possible that samsung was generous enough to give us anouther outlet in the event this happened? |
