Thread: Samsung DLP - Bad shading contours |
New member Username: Weaponstheyfear
Post Number: 1 Registered: Oct-09
| Posted on Sunday, October 11, 2009 - 12:08 pm: |
Hi all, I recently ran into a problem with my Samsung DLP HLP5063WX. It seems the shading and highlights of a scene are having bad contour. Bright white scenes are often blotchy and overly bright, and adjusting settings didn't help. With shading, for example in Will Smith's face in I Am Legend, you can make out contours of the shading, often looking really bad. I have tried using HD channels, SD and even going to DVD player with the same results. I earlier had cleaned the color wheel, and not sure if this would be a problem if it doesn't sit right or if the wheel has become mis-aligned. Also, the wheel in the yellow spectrum has a slight, very shallow scuff. It has always been there and never caused any problem before. Really not sure what the problem could be, any help? |
