Home > Message Board > Home Video > Rear Projection TVs > Convergence - Panasonic
Author Thread: Convergence - Panasonic
Username: Codemaster2008
Hi;
Firs't off all here are the manuals for this model:
USER MANUAL:
http://www.devicemanuals.com/guide/Television/Panasonic/Panasonic-PT51HX41E-51-P ROJECTION-TV-TkRJMk53PT.html
SERVICE MANUAL:
http://schematicsforum.com/schematics//TV/Panasonic/PT-51HX41ENASVC.zip
My TV started this convergence problem, I found some helpful information on the internet and tried to fix it myself.
BEFORE I CHANGE ANY PARTS
When i went to the "Setup" menu and try to adjust the convergence ('convergence 2' menu - page 21 of user manual), i couldn't get those red crosses to align with the white ones.
WHAT I CHANGED
Following the instructions i found online, i changed the two STK392-110 (ref # IC7001 and IC7002). Somebody else told me i had to change the resistors R7048, R7049, R7050, R7053, R7056, R7059 (2,2 Ohms x 2 wats) so i did.
These resistors are not on the replacement part list of the manual but their values are available on the scematics (A-Board).
WHAT I GOT
After i put everything back on place i turned the TV on, went to the same 'convergence 2' menu (user manual page 21) I was able to align the crosses.
THE BIG PROBLEM IS the lines are not straight.
I'm not sure how to explain it but the 2 lines that make the cross are a little bit curved, rounded, waving, something like that.
So, i can get the center of the two crosses on top of each other (before the new STK's i couldn't) but the lines wont align because they are not straigh lines, I end up with a picture that looks like this one:
http://www.fixya.com/uploads/Images/701CB04.jpg
(the above picture is not from my tv but one i found online with the same problem)
I went to the service menu and got something like the picture bellow but a lot worse:
http://www.dioldesign.com/imon/Ser_area.jpg
I follow the instructions from page 22 to 23 of the service manual (Fine Adjustment Mode - FINE - Convergence) but didn't get luck.
The lines are too curved.
So, is there a way i can reset all changes i made on the service menu to factory default?
And is there anything else i can do fix it?
I hope somebody can help me with that.
Thanks in advance.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Convergence - Panasonic [ « Previous ] [ Next » ]
