Thread: Archive through September 14, 2009 |
Bronze Member Username: Alineerodrigo
Post Number: 40 Registered: Oct-07
| Posted on Friday, September 04, 2009 - 06:30 pm: |
ola ! sabes en q canal vai pasar argentina x brasil e cual caja devo comprar para ver o partido? |
Silver Member Username: Mexdss
Monterrey,
N.L.
Mexico
Post Number: 105 Registered: Sep-06
| Posted on Friday, September 04, 2009 - 07:23 pm: |
Reportando nfusion phoenix recien instalado, muy sencilla instalacion y funcionando de maravilla. Ya extrañaba buena television, el cablecito no es para nada un buen sustituto. Saludos a todos, americo. |
Post Number: 41 Registered: Oct-07
| Posted on Friday, September 04, 2009 - 08:32 pm: |
sabes se ppv 454 trabaja en k-box? |
Silver Member Username: Pacha19
Post Number: 272 Registered: Nov-07
| Posted on Friday, September 04, 2009 - 09:21 pm: |
saludos a todo el foro =) |
Bronze Member Username: Alejandramx
Post Number: 88 Registered: Mar-08
| Posted on Friday, September 04, 2009 - 10:43 pm: |
LOS SOPORTES QUE ESTAN TRABAJANDO EN NAGRA 3 ESTAN SOLIDOS (ESTABLES) O PENDEN DE UN HILO ?? DIGO PORQUE TENIA UNA PANSAT3500 Y YA QUEDO EN EL OLVIDO AHORA ME GUSTARIA HACERME DE UNA DE LAS NUEVAS QUE SI FUNCIONAN CON DISH |
Silver Member Username: Lilfred
MEXICO,
D.F.
MEXICO
Post Number: 296 Registered: Oct-07
| Posted on Saturday, September 05, 2009 - 01:11 am: |
hola a todos alguien me podria ecir como hago un search de mis canales, no logro bajar todos del 119 solo 44, y ya he intentado ingresarlos manualmente y tampoco gracias |
Gold Member Username: Mrrasec
Post Number: 1376 Registered: Jul-06
| Posted on Saturday, September 05, 2009 - 03:08 am: |
fred, tus settings de lnb son los correctos? |
Bronze Member Username: Pontyk7
Ottawa,
Ontario
Post Number: 13 Registered: Nov-06
| Posted on Saturday, September 05, 2009 - 08:16 am: |
hola a todos, hace un par de meses compre un Nfusion solo dise asi Nfusion no se si es phoenix o algo asi solo dise Nfusion, ya agarre la señal del 91 pero solo puedo ver el canal donde pasan los cortes de las peliculas de ppv, alguien me puede desir que tengo que hacerle al Nfusion tambien le conecte el cable de internet y no pasa nada. |
Silver Member Username: Colarillo
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 102 Registered: Nov-07
| Posted on Saturday, September 05, 2009 - 01:31 pm: |
Carlos Rosales por eso algunos maestros se enojan con algunos de nosotro (la causa) no leer aqui arrivita estan todos los pasos para hechar a andar los nfusion el tuyo si no me equiboco es un nfucion nuvenio SD y los pasos que tienes que seguir son los mismos que ppara Phoenix o el solaris son los mismos en el post de el maestro JAVY GARZA GONZALEZ EL 2248 Echales una leida y trata ya si no puedes ya cualquiera te ayudamos Orale saludos tu puedes |
Silver Member Username: Titu72
Tecate,
Baja california
Mexico
Post Number: 128 Registered: Nov-06
| Posted on Saturday, September 05, 2009 - 05:59 pm: |
Hola saludos a todos estoy muy empolvado por eso les agradeceria me recomendaran una caja la que consideren mejor para alguien que no sabe mucho gracias de antemano |
Silver Member Username: Gatogt00
Guatemala,
Guatemala
Guatemala
Post Number: 224 Registered: Dec-06
| Posted on Sunday, September 06, 2009 - 08:35 pm: |
RESCATE Buenas tardes la verdad le pido disculpas por haber escrito lo que escribi arriba, no debi escribir ese tipo de comentarios sin antes ponerme a pensar que este foro es de ayuda y nadie esta por un sueldo aqui, y claro sin tampoco tomar en cuenta que todos aqui trabajamos y casi no tenemos tiempo ni para ver television y ahora para estar todos los dias en el foro, nuevamente le pido disculpas RESCATE y siga adelante. |
Guatemala,
Guatemala
Guatemala
Post Number: 225 Registered: Dec-06
| Posted on Sunday, September 06, 2009 - 08:37 pm: |
y si solo a manera de comentario, solo porque me puse a leer en todos lados el procedimiento al fin pude dar con los pasos que encontre en fta bins que fueron de mucha utilidad para mi.
Guatemala,
Guatemala
Guatemala
Post Number: 226 Registered: Dec-06
| Posted on Sunday, September 06, 2009 - 08:38 pm: |
para los que tengan duda con algunas cajas en funcion pues les aconsejo primero que lean y si no logran encontrar lo que buscan pues aqui el foro es para eso para aclarar dudas. |
Guatemala,
Guatemala
Guatemala
Post Number: 227 Registered: Dec-06
| Posted on Sunday, September 06, 2009 - 08:43 pm: |
KBOX PRODIGY para los que les interese en efecto cada vez que el aparato se va la imagen y aparece processing please wait pues lo que tiene que efectuar es apagarlo por 20 o 30 segundos de adelante y atras y listo a seguir disfrutando de la tv |
Gold Member Username: Cavelar
WOODBRIDGE,
ONTARIO
CANADA
Post Number: 1644 Registered: Jul-06
| Posted on Sunday, September 06, 2009 - 11:37 pm: |
Hola a todos/// desde la proxima semana regreso y podre darles soporte a todos los que tienen Nfusion, Nfusion es y lo a demostrado la mejor caja con el mejor soporte y calidad.... no duden en comprar esta marca, saludos... Hasta pronto..... |
Silver Member Username: Luispansat
Irapuato,
Guanajuato
Mexico
Post Number: 144 Registered: Aug-06
| Posted on Monday, September 07, 2009 - 12:09 pm: |
  buenos dias. como les fue este fin de semana. { todos y todas espero que { ok { juan carlos fuentes } que hay de como te fue con tus movimientos en el trabajo. todo en orden. te comentaba que el { amc 9 } solo aparece el nombre y { 2 } canales piloto. mejor me estacione en el { 121.w } = { sky sports } habra un { tp } que se le pueda agregar al { galaxy 19 } para tener + canles. { gracias } = saludos desde la capital de las fresas. * pd : cual es el { LNB } para los canales de { PBS } al lado de que satelite esta.   }} |
Silver Member Username: Alacosta
Toronto,
On
Post Number: 119 Registered: Oct-06
| Posted on Monday, September 07, 2009 - 01:09 pm: |
buenas tardes profes. tengo una KBOX PRODIGY Walter ,la conecte al 91 canadiense ,nimig 1 ,que es el 91.ow y por estesolo entran 400 calanes se ven pocos entre ellos 2 hbo ,nimig 4 82 ow ,sabes si este se puden ver mas canales? gracias profe un feliz dia |
Bronze Member Username: Tadguer
Post Number: 31 Registered: Oct-08
| Posted on Monday, September 07, 2009 - 02:04 pm: |
Saludos A Todo El Foro. Aquí reportando que ya estamos a 07 de Sep. y todavia el Nova puede abrir algunos canales... Sólo es cuestión que aparesca otra versión del Mac & Chess para que el Nova siga Up... Y bueno, si la diferencia entre el Nova y el Solaris es sólo el Chip de seguridad con el que el servidor te dá acceso a la programación y esa seguridad sigue siendo BURLADA, entonces por LÓGICA no le veo mucho futuro al Solaris... nFusión que tanto tiempo tardará en ha*cer del Solaris lo que hizo con el Nova???? El tiempo lo dirá...  |
Silver Member Username: Regio65
Monterrey,
Nuevo León
Mexico
Post Number: 394 Registered: Sep-06
| Posted on Monday, September 07, 2009 - 02:30 pm: |
4º INTENTO Y NADA, YA HICE TODO LO QUE HE ESTADO LEYENDO Y NADA SIGO SIN PODER AGARRAR EL AMC5, TENGO UN PANSAT CONVERTIDO A 2700 Y UNA ANTENA DE CIELITO CON LNB CHAPARRAL ME DA HASTA 81% DE NIVEL Y 0% DE CALIDAD YA NO SE QUE MAS HA@ER YA MOVI EL LNB, CONFIGURE EL SAT EN EL PANSAT DE DIFERENTES MANERAS Y NADA QUE PUEDE ESTAR PASANDO SE HACEPTAN SUGERENCIAS GRACIAS |
Silver Member Username: Rescate
VENEZUELA, M...
Post Number: 408 Registered: Nov-07
| Posted on Monday, September 07, 2009 - 05:31 pm: |
David esto no lo entiendo: ANTENA DE CIELITO CON LNB CHAPARRAL Yo tampoco he podido captar ese sat, parece que la senal es debil. pero parece que esta dificil segun lyngsat http://www.l y n g s a t .com/amc5.html hay un solo canal abierto : Telemundo El otro canal esta en Digicipher y los demas son "feeds" Si observas el transponder de telemundo es el numero 8 con 11900 H. Solo te queda saber que tamano de antena necesitarias en tu ubicacion y el LNB debe ser para KU ya que el AMC5 es linear debes configurar asi: 22khz off frecuency 10750 puerto discqc (el que tengas 1,2,3 o 4) En este site podrias quizas tener una informacion sobre la ubicacion del sat con respecto a otro que ya tengas localizado. Yo estoy por comprarme un LNB invacom a ver si tengo mejor suerte. Saludos |
VENEZUELA, M...
Post Number: 409 Registered: Nov-07
| Posted on Monday, September 07, 2009 - 05:34 pm: |
Curioso amable, aqui estan los canales que se ven: http://www.ftabins.net/showthread.php?t=102033 Saludos |
VENEZUELA, M...
Post Number: 410 Registered: Nov-07
| Posted on Monday, September 07, 2009 - 05:40 pm: |
Carlos Alverlar dijo: *** Hola a todos/// desde la proxima semana regreso y podre darles soporte a todos los que tienen Nfusion, Nfusion es y lo a demostrado la mejor caja con el mejor soporte y calidad.... no duden en comprar esta marca, saludos... Hasta pronto..... *** Si deben dudar en comprar esas cajas, no se sabe cuando van dejar de tener soporte puede ser de un momento a otro como con la Nova, puede ser cualquier momento con cualquier excusa para tumbar la Solaris o la Phoenix o la HD. Saludos |
Silver Member Username: Guanajuatos_best
Post Number: 263 Registered: Jul-07
| Posted on Monday, September 07, 2009 - 06:38 pm: |
Mejor compren una KBox PROdigy |
WOODBRIDGE,
ONTARIO
CANADA
Post Number: 1645 Registered: Jul-06
| Posted on Monday, September 07, 2009 - 07:33 pm: |
Rescate// Tu sí que estas al tanto cuando yo posteo que rápido estas al brinco Repitiendo mis comentarios, mira y desde cuando alguna marca te da Garantía que funcionara para toda la vida, no vez que allí está el negocio, O tú pagas alguna mensualidad por este pasatiempo Esto es como todo, si compras un tv 3 a 5 años tienes que comprar otro, Así sucede con todas las cosas, como los carros las viejas ETC Dime tú si Microsoft jodio a la gente porque ya no da mas Soporte a los cpu Pentium 3 o 4 Kbox es una marca nueva, y la considero muy buena porque está dando La batalla, pero que dirás cundo no den más soporte a sus modelos más viejos. Kbox todavía no está al nivel de Nfusion, nada le quita el buen Soporte que han dado desde que yo tengo, año 2007. Es cierto, no más Soporte para las novas, bueno es tiempo de Actualizar equipos, y nada mas… saludos |
VENEZUELA, M...
Post Number: 411 Registered: Nov-07
| Posted on Monday, September 07, 2009 - 08:47 pm: |
Carlos Avelar: Uff Hoy tengo tiempo esto va a ser largo (no te enojes) *** Tu sí que estas al tanto cuando yo posteo que rápido estas al brinco *** Hoy es dia feriado, no trabajé ***Repitiendo mis comentarios *** Eso es normal en los foros *** Garantía que funcionara para toda la vida *** A veces uno se muere antes que la maquina deje de funcionar ***Esto es como todo, si compras un tv 3 a 5 años tienes que comprar otro *** NO, la mayoria de mis equipos tienen y han durado muchos a#os con buen servicio, tu hablas del CONSUMISMO de Norte America. ***Dime tú si Microsoft jodio a la gente porque ya no da mas Soporte a los cpu Pentium 3 o 4 *** NO, yo utilizo LINUX MINT 7, basado en UBUNTU, y mi Pentium 4 es un AVION al lado de MS Windows, tengo TODAS las aplicaciones que quiera y NO PAGO NADA, se actualiza a DIARIO, NO tengo virus de ningun tipo, NI antivirus, y cuatro en mi casa usamos la misma computadora, cada quien con su espacio propio, que los demas no pueden tener acceso, Lo puedo instalar en el idioma que quiera, NADIE puede da#ar NADA en el sistema, es SUPER solido, un ALTO porcentage de WEB servers utilizan LINUX. ***Kbox es una marca nueva, y la considero muy buena porque está dando La batalla*** Me da lo que necesito, y tanto los coders como el fabricante son A1. ***pero que dirás cundo no den más soporte a sus modelos más viejos. *** Lo leeras a su debido tiempo, cuando yo comente al respecto, paciencia. ***Kbox todavía no está al nivel de Nfusion, nada le quita el buen Soporte que han dado desde que yo tengo, año 2007. *** Solo cambiaria mi kbox por un nfusion HD pero no necesito gastar 300 de mas por un servicio similar, la solaris ni la phoenix son competencia para kbox Puedo colocar mi disco duro de 500GB directo a mi kbox para grabar todo lo que quiera, no necesito un cumputador. ***Es cierto, no más Soporte para las novas, bueno es tiempo de Actualizar equipos, y nada mas *** Solo porque nfusion me OBLIGO a comprar un kbox.
Saludos |
WOODBRIDGE,
ONTARIO
CANADA
Post Number: 1646 Registered: Jul-06
| Posted on Monday, September 07, 2009 - 10:16 pm: |
Eh rescate, nunca me enojo en los foros, no somos niñitos de escuela Déjame pasar sabroso mis vacaciones aquí en tu linda isla margarita La otra semana la seguimos… saludos. |
Toronto,
On
Post Number: 120 Registered: Oct-06
| Posted on Monday, September 07, 2009 - 11:58 pm: |
Rescate muchas gracias ,es verdad que estas cajas son controladas por la intenet , y cobran un dollar mas ,es verdad , o por alarmar gracias profe |
Silver Member Username: Pancholin
Guanatos mex,
Ca
Usa
Post Number: 113 Registered: Jul-06
| Posted on Tuesday, September 08, 2009 - 12:44 am: |
Hola tengo una pregunta en un lnb lineal el sw 22 khz debe de estar on o off porque me fallan algunos canales guacias por la respuesta |
Post Number: 89 Registered: Mar-08
| Posted on Tuesday, September 08, 2009 - 12:54 am: |
hola buenas noches Alguien que me diga cuantas satelites disponibles hay para un pansat3500 y cuales me recomiendan radico al norte de mexico frontera con arizona y porfavor cuales son sus procedimientos configuraciones si algo hay que hacerle extra me quede con el ultimo bin de junio cuando todavia habia nagra2 Bueno me espero su ayuda de antemano gracias |
VENEZUELA, M...
Post Number: 412 Registered: Nov-07
| Posted on Tuesday, September 08, 2009 - 07:21 am: |
Curioso Amable, Los gastos con kbox serian solo estos: 210 $ canadienses, por la kbox y el khub + tax + envio. (yo pague 234$ por todo) Tu conexion internet, lo que pagas mensual, (nada adicional aqui) El cable o el aparato sin hilos (wireless) para conectar la caja a la internet. Un router (si tu modem tiene una sola entrada a la internet. Mi conexion esta asi: kbox+khub=cable ethernet >2wire modem (este modem de B3v tiene 4 entradas y tambien es wireless) funciona de maravilla. Saludos |
Gold Member Username: Javy_gza
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2249 Registered: Oct-06
| Posted on Tuesday, September 08, 2009 - 09:58 am: |
SALUDOS A LA RAZA DAVID EL TELEMUNDO LO AGARRAS EDITANDO EL TP 11900 H Y GIRANDO TU LNB A LAS 7 PM OSEA EL CABLE VA A ESTAR A LAS 7 LAS CONFIG SON LNB ----- UNIVERSAL 1 9750 ---10600 ETC ETC. AQI EN PERROS BRAVOS EL AZIMUT ORIGINAL ES A 50 ELEV Y EL AZIMUT ES A 130 GRADOS. SALUDOS |
Toronto,
On
Post Number: 121 Registered: Oct-06
| Posted on Tuesday, September 08, 2009 - 12:04 pm: |
Hola rescate ,muchas gracias ,hace 1 mes la compre ,el precio fue de 240 ,canadienses ,programada , solo tenia esa inquietud ,de un comentario ,que escuche . un feliz dia ,profe |
Silver Member Username: Rober2154
Miami,
Fl
Usa
Post Number: 599 Registered: Jun-06
| Posted on Tuesday, September 08, 2009 - 02:23 pm: |
Pregunta; Que LNB se usa para HD y si lo puedo instalar en mi dish500???? |
Miami,
Fl
Usa
Post Number: 600 Registered: Jun-06
| Posted on Tuesday, September 08, 2009 - 02:25 pm: |
Miami,
Fl
Usa
Post Number: 601 Registered: Jun-06
| Posted on Tuesday, September 08, 2009 - 02:26 pm: |
Alguien baja Hispasat 30W con una Nfusion???? |
Monterrey,
Nuevo León
Mexico
Post Number: 395 Registered: Sep-06
| Posted on Tuesday, September 08, 2009 - 02:53 pm: |
HOLA PAISANO JAVY GZA SOLO UNA PREGUNTA MAS EL CABLE A LA SIETE VIENDO DE FRENTE A LA ANTENA O DE ATRAS DE LA ANTENA GRACIAS |
Gold Member Username: Juancholagarto
Mexico City,
D.F.
Mexico
Post Number: 1332 Registered: Oct-07
| Posted on Tuesday, September 08, 2009 - 06:52 pm: |
David: Es desde atrás de la antena. Saludos |
Monterrey,
Nuevo León
Mexico
Post Number: 396 Registered: Sep-06
| Posted on Tuesday, September 08, 2009 - 09:36 pm: |
GRACIAS JUAN CARLOS |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2250 Registered: Oct-06
| Posted on Wednesday, September 09, 2009 - 09:42 am: |
SALUDOS A LA RAZA DAVID EL LNB LO VAS A PONER ALAS 7 PERO VIENDO DE FRENTE LA ANTENA OSEA ADELANTE DEL PLATO . SALUDOS |
Bronze Member Username: Cecilia
Cuernavaca,
Morelos
Mexico
Post Number: 81 Registered: Sep-06
| Posted on Wednesday, September 09, 2009 - 09:52 am: |
Hola, creo que en este momento nada mas esta conectado Javy Gza Gzz y te quiero pedir ayuda sobre un ihub que tengo instalado en sv360 e, pero desde hace dias no veo nada, se que es el servidor de sv que esta saturado y que la imagen se frisea sabes si hay algo que pueda ha*cer |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2251 Registered: Oct-06
| Posted on Wednesday, September 09, 2009 - 10:01 am: |
CECILIA SEGUN LO ULTIMO Q LEEI SV NO TIENE SOPORTE O AI Q CAMBIARLE AL ULTIMO BIN PERO MEJOR ESPERA A LA RAZA Q MANEJE ESTE RECIBER SALUDOS |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2252 Registered: Oct-06
| Posted on Wednesday, September 09, 2009 - 10:07 am: |
CECILIA CHECA ESTE LINKhttp://www.ftabins.net/forumdisplay.php?f=314 |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2253 Registered: Oct-06
| Posted on Wednesday, September 09, 2009 - 10:31 am: |
AL RATO NOS ESCRIBEMOS RAZA . |
Cuernavaca,
Morelos
Mexico
Post Number: 82 Registered: Sep-06
| Posted on Wednesday, September 09, 2009 - 11:30 am: |
Muchas gracias Javy |
Bronze Member Username: Fghio
Monterrey
Post Number: 37 Registered: Jan-08
| Posted on Wednesday, September 09, 2009 - 11:56 am: |
Hola a todos Tengo un Nfusion Phoenix y en la ultima lista de Canales aparecen los Networks de California que son los 8000 a 80005 ya escanee los canales 2 veces pero no me aparecen, alguien sabe como hacerle para poderlos ver. Solo veo el 8005. saludos |
Silver Member Username: Sergio_verdugo
Hermosillo,
Sonora
Mexico
Post Number: 956 Registered: Nov-07
| Posted on Wednesday, September 09, 2009 - 02:07 pm: |
buen dia saludos |
Silver Member Username: Nomeloplagies
Post Number: 189 Registered: Apr-06
| Posted on Thursday, September 10, 2009 - 12:46 am: |
Roberto, los LNB son los mismos para HD... saludos |
Post Number: 190 Registered: Apr-06
| Posted on Thursday, September 10, 2009 - 01:16 am: |
Alejandra, No hay hay "bines" para Nagra3... solo encontrarás los canales libres como NASA (213), HomeDN (100) y los religiosos. Lo que está funcionando es IKS (Internet Card Sharing), son equipos habilitados con una interfase a Internet, igual que la conexión de red a tu computadora. No hay equipos estables, la mayoría requieren suscripción para que el equipo se enlace a un servidor privado en Internet, el cuál le dará autorización a tu receptor. Con los equipos nuevos usas tus mismas antenas y LNB's... requieres conexión permanente a Internet. Los satélites son los mismos de BEV y DN... algunos dicen que incluirán DTV. Si buscas orientar tus antenas a otros satélites, en esta página hay información para el "hobby"... http://nomeloplagies.com/satelite/ Salud! |
Guanatos mex,
Ca
Usa
Post Number: 114 Registered: Jul-06
| Posted on Thursday, September 10, 2009 - 03:11 am: |
Hola zorro saludos no dejes de visitarnos desde cal saludo al foro |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2254 Registered: Oct-06
| Posted on Thursday, September 10, 2009 - 10:05 am: |
SALUDOS A LA RAZA EN ESPECIAL AL GRAN MASTER ZORRO CRITICO. SALUD |
Mexico City,
D.F.
Mexico
Post Number: 1333 Registered: Oct-07
| Posted on Thursday, September 10, 2009 - 02:07 pm: |
David: Quiero h@cer una corrección tipo Fe de erratas, jejejejejeje. Y es que checando nuevamente algunos posts, me encontré con que efectivamente tiene razón el Máster Javy Gza. Si miras el lnb como él dice, efectivamente es a las 7, es que yo siempre lo hago por detrás del plato, pero entonces sería como a las 5. Mil disculpas por proporcionar esa info errónea. Saludos Javy Gza. |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2255 Registered: Oct-06
| Posted on Thursday, September 10, 2009 - 05:10 pm: |
SALUDOS JUAN CARLOS FUENTES NO TE PREOCUPES ES DE HUMANOS EQUIVOCARSE Y TMBN ES DE SABIOS EL RECONOCER .SALUDOS |
Silver Member Username: Neox
Tijuana,
Baja California
Mexico
Post Number: 410 Registered: Aug-06
| Posted on Thursday, September 10, 2009 - 05:27 pm: |
Saludos a todos los F.T.Amigos del Forum. Con una molestia y pregunta HAy algo para SonicVeiw 360 con dongly o de donde bajo el bin para el mismo y ponerlo en eternet? De antemano grasias. |
Post Number: 273 Registered: Nov-07
| Posted on Thursday, September 10, 2009 - 07:39 pm: |
Hermosillo,
Sonora
Mexico
Post Number: 957 Registered: Nov-07
| Posted on Friday, September 11, 2009 - 10:49 am: |
BUEN DIA ALGUNA NOTICIA PARA LOS PANSAT
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2256 Registered: Oct-06
| Posted on Friday, September 11, 2009 - 12:01 pm: |
SALUDOS A LA RAZA SERGIO VERDUGO TODO SIGUE IGUAL PURO IKS . SALUDOS |
Hermosillo,
Sonora
Mexico
Post Number: 958 Registered: Nov-07
| Posted on Friday, September 11, 2009 - 12:09 pm: |
NI HABLAR JAVY TKS SALUDOS |
PERROS BRAVOS ,
NUEVO LEON
Post Number: 2257 Registered: Oct-06
| Posted on Friday, September 11, 2009 - 12:28 pm: |
OK SERGIO |
Monterrey
Post Number: 38 Registered: Jan-08
| Posted on Friday, September 11, 2009 - 12:54 pm: |
Hola a todos Tengo un Nfusion Phoenix y en la ultima lista de Canales aparecen los Networks de California que son los 8000 a 8005 ya escanee los canales 2 veces pero no me aparecen, alguien sabe como hacerle para poderlos ver. Solo veo el 8005. saludos |
Silver Member Username: Fpeflo
Juarez Mexico
Post Number: 113 Registered: Mar-08
| Posted on Friday, September 11, 2009 - 01:50 pm: |
Alguno de ustedes sabe cual es la lista de canales abiertos co nfusion solaris ? |
Monterrey,
N.L.
Mexico
Post Number: 106 Registered: Sep-06
| Posted on Friday, September 11, 2009 - 01:53 pm: |
Alguen sabe en que canal pasara el juego de rayados? Gracias, americo. |
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 103 Registered: Nov-07
| Posted on Friday, September 11, 2009 - 04:15 pm: |
Pelon Esos canales son los locales de los Angeles y no se miran solo el canal 5 que es el unico que hay desde que todos los canales emigraron ala ya famosa y no quebrada en su totalidad=== N3 asi que no te quiebres la cabesa y a esperar |
Monterrey
Post Number: 39 Registered: Jan-08
| Posted on Friday, September 11, 2009 - 04:27 pm: |
ok rony muchas gracias |
Monterrey
Post Number: 40 Registered: Jan-08
| Posted on Friday, September 11, 2009 - 04:31 pm: |
Fpeflo creo que es igual para todos los nfusion esta es la lista que tengo yo saludos 100 DISH Home Interactive TV 101 DISH Network Neighborhood 102 Free Preview Guide 104 Satellite Response Interactive (SRI) 105 USA 106 TV LAND 107 COMEDY 108 LIFETIME 109 LIFETIME MOVIE NET 110 FOOD 111 DIY 112 HGTV 113 FINE LIVING 114 E! 115 STYLE 116 GAME 117 TV GUIDE 118 A&E 119 BIO 120 HISTORY CHANNEL 121 HISTORY INTERNATIONAL 122 SCI FI 123 FREE1 124 BET 125 Pirate TV 127 OXYGEN 128 WOMAN'S ENTERTAINMENT (WE) 129 BRAVO 130 AMC AMERICAN MOVIE CLASSICS 131 IFC 132 TCM TURNER CLASSIC MOVIES 133 FOX MOVIES 134 SHOP NBC 135 BBC 136 FX 137 QVC 138 TNT 139 TBS 140 ESPN 142 ESNWS 143 ESPCL 144 ESPN2 146 ESP2A 147 ESPNA 148 ESPNU 149 FSC 150 SPEED 151 VERSUS 152 CBSCS 153 OTDCH 154 NFL 157 OVATN 158 FUSE 159 sitv 160 Mtv 161 Mtv2 162 Vh1 163 Vh1 cl 166 Cmt 167 ac 168 SPIKE 169 NOGGIN 170 NICKELODEON (E) 171 NICKELODEON (W) 172 DISNEY (E) 173 DISNEY (W) 174 TOON DISNEY 175 BOOM 176 Toon 177 NICKG 178 NICKT 179 DKIDS 180 Abc Fm 181 ION 182 Disc 183 TLC 184 APL 185 Hlmrk 186 NTGEO 187 Hmc 188 Soap 189 DHLTH 190 Rlty 191 G4 192 ID 193 Science 194 Green 195 Mil 196 Curnt 197 Doc 198 Slth 199 Chlr 200 CNN 202 Hln 204 Tru 205 Fox news 206 Fox Bs 207 Cnbcw 208 Cnbc 209 Msnbc 210 Cspan 211 Cspan2 212 Dish earth 213 NASA 214 Twc 215 Trv 216 ion 217 218 tjc 200 Sln 201 CH201 202 HNN 203 BITV 204 TRU 205 FXNWS 206 VH206 207 CNBCW 208 CNBC 209 MSNBC 210 CSPAN 211 RNC08 212 CSPN2 213 NASA 214 TWC 215 TRV 216 C&T 218 TJC 219 alive 220 SLTV 221 lshop 222 Hsn 223 SRN 224 SHOP 225 Tjc 226 GEMTV 227 Jtv 228 Shnbc 229 GEMS 230 ictv 231 Rfdtv 238 WWOR 239 wgn 240 INFO 259 INSP 260 TBN 261 EWTN 262 ANGEL 263 DYSTR 264 KTV 265 CCTV9 univision 266 ANGL2 270 UNVSN 271 FTRAE Telefutura West 273 GLVSN Univision West 280 FREE 298 FREE 299 REELZ 300 HBO-E 301 HBO-2E 302 HBO SG 303 HBO-W 304 HBO-2W 305 HBO FAMILY 307 HBO COMEDY 309 HBO LATINO 310 CINEMAX - E 311 CINEMAX - W 312 CINEMAX MOREMAX 313 CINEMAX ACTIONMAX 314 CINEMAX 5-STAR MAX 318 SHOWTIME - E 319 SHOWTIME - W 320 SHOWTIME - 2 321 SHOWTIME SHOWCASE 322 SHOWTIME EXTREME 323 SHOWTIME BEYOND 327 THE MOVIE CHANNEL-E 328 THE MOVIE CHANNEL XE 329 THE MOVIE CHANNEL -W 330 THE MOVIE CHANNEL XW 332 SUNDANCE 333 FLIX 340 Encore 341 ENCORE W 342 ENCORE WESTERN 343 ENCORE ACTION 344 ENCORE MYSTERY 345 ENCORE DRAMA 346 ENCORE LOVE 347 ENCORE WAM 350 STARZ 351 STARZ W 352 Starz Edge 353 STARZ CINEMA 354 STARZ COMEDY 355 STARZ IN BLACK 356 STARZ KIDS & FAMILY 400 tenis 401 golf 404 HRTV 405 tvGAME 467 order 468 order 469 order 470 Service 480 ALOCK 485 ASHOW 486 ASHOW 488 REAL(NEW) 489 PENT(NEW) 490 ALOCK 498 PLBYE Playboy Espanol 500 Pay-Per-View Schedule & Previews/DISH Studio 611 ZEETV 614 SET 642 ART 644 lbc 645 ALJAZ 665 Ziqr Radio 669 ART Music (radio) 758 ART 761 ALJAZ 777 HKYAT 778 ZEETV 787 Zeetv 789 SET 825 Azteca 827 univision 828 univision west 829 CH829 830 FTRAE telefutura East 831 FTRAW telefuturaW 833 GLVSN 834 PSNES 835 Telemundo East 836 Telemundo West 838 mun2 839 CANL1 840 TVE Internacional 841 TV Colombia 843 HITN 844 Televisión Dominicana 845 Discovery en Español 846 V-me 847 TDIS 848 CBeebies en Español 850 History en Español 854 ESPN Deportes 855 Fox Sports en Español 857 Canal Sur 858 TeleFórmula 859 CNN en Español 882 ION 883 SLTV 884 CCTV-E 4120 History HD 5313 The History Channel DH 5333 HD Theater 5816 VOD (Pay Per View Movies!!!) 5817 VOD (Pay Per View Movies!!!) 5818 VOD (Pay Per View Movies!!!) 5819 VOD (Pay Per View Movies!!!) 5820 VOD (Pay Per View Movies!!!) 5821 VOD (Pay Per View Movies!!!) 5822 VOD (Pay Per View Movies!!!) 5823 VOD (Pay Per View Movies!!!) 5824 VOD (Pay Per View Movies!!!) 5825 VOD (Pay Per View Movies!!!) 5828 SOON3 5829 SOON4 5830 SOON 5831 SOON 5832 SOON2 5833 SOON2 8000 KABC (ABC 7) Up(NEW) 8001 KCBS (CBS 2) Up(NEW) 8002 KNBC 4 Up(NEW) 8003 KTTV (FOX 11) Up(NEW) 8004 KTLA (CW 5) Up(NEW) 8005 KCOP (MY 13) Up(NEW) 8100 WABC (ABC 7) Up(NEW) 8101 WCBS (CBS 2) Up(NEW) 8102 WNBC (NBC 4) Up(NEW) 8103 WNYW (FOX 5) Up(NEW) 8104 WPIX (CW 11) Up(NEW) 8105 WWOR (MY 9) Up(NEW) 9060 CH 9060 9134 CH 9134 9213 CH 9213 9252 CH 9252 9287 WTLU 9320 CH 9320 9400 RSRCH 9401 HITN 9403 BYUTV 9404 UWTV 9407 COLRS 9409 CH 9409 9410 LINK 9411 NAUHS 9412 UCTV 9414 V-ME 9415 FSTV 9417 EDUCA 9420 TNT HD East (HD ONLY) 9421 Discovery HD Theater (HD ONLY) 9422 HDNet (HD ONLY) 9424 ESPN HD (HD ONLY) 9431 USA HD East (HD ONLY) 9432 Sci-Fi HD East (HD ONLY) 9456 HBO HD East (HD ONLY) 9460 SHO-E HD 9464 ORDER 9491 The History Channel HD East (HD ONLY) 9530 CH 9539 9575 VERIA 9601 BTV 9602 BTV 9611 BTV 9612 BTV 9645 LF1 9646 CH 9646 9647 CH 9657 9648 CH 9648 9649 CH 9649 9900 DISH 500 Confirmation Channel 9945 DVRDN 9946 DVRVR |
Juarez Mexico
Post Number: 114 Registered: Mar-08
| Posted on Friday, September 11, 2009 - 05:48 pm: |
Pelon Gracias. |
New member Username: Moco
Chicago
Post Number: 1 Registered: Aug-09
| Posted on Friday, September 11, 2009 - 09:38 pm: |
ESCUCHE QUE LAS CAJAS DE TARJETA YA ESTAN FUNCIONANDO. ALGUIEN SABE SI ES VERDAD????? |
MEXICO,
D.F.
MEXICO
Post Number: 297 Registered: Oct-07
| Posted on Friday, September 11, 2009 - 10:08 pm: |
BUENA S NOCHES SI ALGUEIN SABE.. AYUDENME ETSBA VIENDO EL 455 EVENTO DE KOTC Y AL EMPEZAR EL EVNETO DE FUE LA SEÑAL ESO ESTA PASANDO EN EL 455? |
MEXICO,
D.F.
MEXICO
Post Number: 298 Registered: Oct-07
| Posted on Friday, September 11, 2009 - 10:10 pm: |
TENGO NFUSION SOLARIS |
Post Number: 1379 Registered: Jul-06
| Posted on Friday, September 11, 2009 - 10:57 pm: |
no! parece que , como este evento es de medio pelo! no tenemos suerte. espero que ufc siga siendo considerado! |
MEXICO,
D.F.
MEXICO
Post Number: 299 Registered: Oct-07
| Posted on Friday, September 11, 2009 - 11:17 pm: |
creen que solo sea abierto para eventos de mucha audiencia? |
MEXICO,
D.F.
MEXICO
Post Number: 300 Registered: Oct-07
| Posted on Friday, September 11, 2009 - 11:32 pm: |
tambien quiero postear que algubnos canales 300 no tienen audio, alguien mas con este problema? |
Post Number: 274 Registered: Nov-07
| Posted on Saturday, September 12, 2009 - 12:42 am: |
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 104 Registered: Nov-07
| Posted on Saturday, September 12, 2009 - 01:27 am: |
PELON: EN TUS CANALES PORKYS TE FALTAN LOS CANALES MAS GOODS QUE SON EL 492,493 Y EL 496 YO CREO QUE NESECITAS HASER UN REESCAN DE CANALES O AFINAR MAS LA SENAL PARA CUANDO ESCANEES TE LOS BAJE |
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 106 Registered: Nov-07
| Posted on Saturday, September 12, 2009 - 01:37 am: |
PELON: En los canales 800s o latinos te faltan los canales de peliculas son 2 y el de cine latino y los de musica como BANDA MAX y otros mas |
New member Username: Toygirl
Post Number: 5 Registered: Sep-09
| Posted on Saturday, September 12, 2009 - 02:05 am: |
http://www.ftastream.com/viewtopic.php?f=192&t=3007&p=4214#p4214
Gold Member Username: Canada_havana
Post Number: 2079 Registered: Sep-07
| Posted on Saturday, September 12, 2009 - 06:17 pm: |
MUERAN TODOS LOS COMUNISTAS, Y TODOS AQUELLOS QUE ,TRATAN DE PISAR EL EXILIO CUBANO,,, UN CONCIERTO NO CALMA EL DOLOR DEL PUEBLO CUBANO,,,,,,,,,CUBABAJOCERO/. |
Silver Member Username: Jgg
Houston,
Tx
Usa
Post Number: 109 Registered: Nov-06
| Posted on Saturday, September 12, 2009 - 09:15 pm: |
Julio Cesar Chavez vs Jason Lehoullier en el 455 en un infusion hd, quiero suponer que en los demas infusion tambien se ven, saludos..... |
Houston,
Tx
Usa
Post Number: 110 Registered: Nov-06
| Posted on Saturday, September 12, 2009 - 09:20 pm: |
Julio Cesar Chavez jr. |
Bronze Member Username: Cochito
Post Number: 23 Registered: Jan-07
| Posted on Saturday, September 12, 2009 - 11:01 pm: |
hola,tengo problemas con mi nfusion solaris,no puedo solucionar SUNS DISCONNECTED,ya intente algunas cosas pero nada,gracias.... |
Post Number: 191 Registered: Apr-06
| Posted on Sunday, September 13, 2009 - 12:02 am: |
A mis amigos del Foro un poco de historia no les hace mal... quienes no gusten de este hobby, no lean... pero tampoco aprenderán. Este hobby comenzó el mismo día que subieron satélites geoestacionarios con señal de TV para los sistemas de cable... las antenas en “banda C” y los receptores de micro-ondas abundaron cuando se pudo acceder a los equipos que tenían los “cableros” para vender la señal condicionada. En México los servicios de cable ofrecían gratis HBO, Showtime, Cinemax, MTV, etc. Entonces, para proteger la señal, los proveedores cifraron la transmisión y aparecieron los “descramblers” como DigiCipher, luego DigiCipher II, y así empezó la carrera. Debido a los vacíos en la legislación de derechos de autor y falta de acuerdos bilaterales, se siguieron ofreciendo libremente los servicios en los sistemas de Cablevision hasta mediados de los 80’s. En su momento la encriptación fue más compleja, los blackouts fueron más severos, pero siempre hubo un “descrambler” que trabajó en la señal y el bloqueo fue sobreseído con nuevos equipos... allí, en los 80’s, comenzó la venta de otros equipos descifradores y mejores receptores. De pronto cambió todo con DirecTV, SKY, Galaxy LA, etc. con la señal más potente en frecuencia “Ku”... fue entonces que se reemplazó la enorme antena “BUD” (Big Ugly Dish)y los descramblers por las antenas del tamaño de una pizza que se podían comprar fácilmente en un WalMart de EEUUA. Llegaron los programadores de las tarjetas condicionales llamados “loaders” que se hicieron populares con la tarjeta “H”... hasta que llegó el “BlackSunday” que metió todas las tarjetas no registradas en un “loop”, dejándolas inservibles. Fue entonces que llegaron los “Unloopers”, que desbloquearon las tarjetas “H” y permitieron abrir la señal... allí se aprendieron a programar los “tiers” y a evitar bloqueos. Esto obligó al cambio de las tarjetas por otra encriptación más robusta como la “HU”, que fue hábilmente asimilada por los equipos de hackers con la cual se popularizaron nuevos loaders como los “Mikobu”, hasta que llegó el “blacklist”. Las tarjetas que no se activaban en un tiempo determinado pasaban a formar parte de las listas negras... pero, como imaginarán apareció la “clonación”, de modo que los programadores fueron capaces de pasar en segundos sobre los bloqueos y se hicieron populares las imágenes de tarjetas “legalmente” suscritas y con ello la posibilidad de duplicar las autorizaciones. Fue entonces el gran paso en la seguridad de los equipos de DirecTV, porque no solo cambiaron las tarjetas, sino los receptores. Este nuevo equipo se diseñó con un procesador de tecnología privada para DSS que no pudo adquirirse como OEM y los nuevos receptores solo trabajaron con las tarjetas P3 y P5 con mecanismo de encriptación DSS. Esta nueva estrategia obligó a buscar sistemas más débiles como DN que además de las tarjetas permitió la emulación de la condicionalidad del servicio. Las primeras emulaciones dependían de una PC dedicada al servicio y posteriormente aparecieron sistemas operativos que permitieron modificar la operación del hardware en equipos del servicio gratuito conocido como FTA (Free-To-Air). Ahora cambia de nuevo la tecnología, deja de funcionar la emulación y aparece la posibilidad de “compartir” la autorización de las tarjetas vía Internet. El servicio se conoce como IKS (Internet Key Sharing o Internet Card Sharing). Su funcionalidad depende nuevamente de tarjetas suscritas, cuya autorización se comparte mediante servidores dedicados. La señal y conexión son encriptados, y se enlazan con equipos FTA que tienen el hardware y el software adecuado para buscar la autorización vía Internet. El nuevo equipo IKS y su software permanece aún bajo ciertas condiciones de pago, sin embargo ya existen proveedores que libremente ofrecen la posibilidad de compartir la autorización de tarjetas suscritas. En resumen, guarden los equipos FTA que no tienen mecanismos para enlazarse a Internet... esperen cambios en los equipos que dependen de otros procesadores para emular la señal, no compren equipo HD, a menos que deseen correr el riesgo de quedarse con más receptores de colección. Que pasen un buen fin de semana y Salud! |
Post Number: 275 Registered: Nov-07
| Posted on Sunday, September 13, 2009 - 01:39 am: |
Silver Member Username: Korita
FRANCIA,
CA
Post Number: 231 Registered: Feb-08
| Posted on Sunday, September 13, 2009 - 02:49 pm: |
SALUDO A TODO EL FORO AKI REPORTANDO K TODAS LAS (NFUSION) ESTAN CAIDAS ESPERANDO AREGLO DEL CERVIDOR |
FRANCIA,
CA
Post Number: 233 Registered: Feb-08
| Posted on Sunday, September 13, 2009 - 02:58 pm: |
Y X SU PUESTO AAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRRRRRIIIIIIIIIIIIIIIIIIIIIIIBBBBBBBBBBBBBBBBBBBBB BBBBBBBBBBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA EL CCCCCCCCCCCCHHHHHHHHHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAMMMMMMMMMMMMMMMMMMMMMMMAAAAAA AAAAAAAANNNNNNNNNNNNNNNNNN |
FRANCIA,
CA
Post Number: 234 Registered: Feb-08
| Posted on Sunday, September 13, 2009 - 03:01 pm: |
PERO MI SV360 TRABAJANDO AL 100% |
Post Number: 32 Registered: Oct-08
| Posted on Sunday, September 13, 2009 - 03:57 pm: |
Tache por aquí.... Tache por allá.... http://www.nfusionteam.com/index.php?option=com_content&view=article&id=48&Itemi d=56 |
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 107 Registered: Nov-07
| Posted on Sunday, September 13, 2009 - 08:07 pm: |
ZORRO CRITICO: Que buena remembransa para todos y (todas)los companeros que no han vivido esto desde el principio y asi se den cuenta de como ha evolucionado todo esto para tener FREE TV Muchos saludos y no tee olvides de este tu foro |
Mexico City,
D.F.
Mexico
Post Number: 1334 Registered: Oct-07
| Posted on Sunday, September 13, 2009 - 09:06 pm: |
Hola: Totalmente de acuerdo con Rony Milhouse; solamente dos aclaraciones para el buen amigo Zorro Crítico: 1. Los tipos de encriptación (no descramblers) fueron primero Video Cipher, VideoCipher II y VideoCipher RS respectivamente, y no DigiCipher, o DigiCipher II, ya que esos fueron los últimos en salir (encriptación digital). 2. La mejor encriptación surge porque un gringo que no quería pagar por la señal de HBO, pudo bloquear la señal de esta televisora durante aproximadamente 3 minutos para poder poner un anuncio que decía "NO PAGUES POR TENER ESTA SEÑAL", lo cual le valió ser arrestado. Ya con estas aclaraciones, creo que queda más ampliado el comentario del amigo Zorro Crítico. Saludos a todos |
Silver Member Username: Arrollador_de_perras
Post Number: 150 Registered: Apr-08
| Posted on Monday, September 14, 2009 - 12:41 am: |
PARA LOS QUE TENEMOS PANSAT3500,2700 O CLON PUFF QUE SATELITES PODEMOS AGARRAR YA QUE NO EXISTE PROGRAMA DE DISH PARA ESTOS Y SI LOS HAY LES PIDO QUE ME DIGAN CUALES SON LOS PASOS ORIENTANDO DESDE SONORA MEXICO GRACIAS |
Silver Member Username: Jmendozab
Post Number: 318 Registered: Jul-06
| Posted on Monday, September 14, 2009 - 02:00 am: |
Esta es la lista de los canales que se ven en nFusion. Estoy buscando un Nuvenio Barato. Alguien sabe donde lo consigo en Mexico? nfusion Official Channel List Dish: (Updated September 12 8:46 PM EST) 100 DISH Home Interactive TV 101 DISH Neighborhood 102 Free Preview Guide 104 Satellite Response Interactive (SRI) 105 USA 106 TV LAND 107 COMEDY 108 LIFETIME 109 LIFETIME MOVIE NET 110 FOOD 111 DIY 112 HGTV 113 FINE LIVING 114 E! 115 STYLE 116 GAME 117 TV GUIDE 118 A&E 119 BIO 120 HISTORY CHANNEL 121 HISTORY INTERNATIONAL 122 SCI FI 123 FREE1 124 BET 125 Pirate TV 127 OXYGEN 128 WOMAN'S ENTERTAINMENT (WE) 129 BRAVO 130 AMC AMERICAN MOVIE CLASSICS 131 IFC 132 TCM TURNER CLASSIC MOVIES 133 FOX MOVIES 134 SHOP NBC 135 BBC 136 FX 137 QVC 138 TNT 139 TBS 140 ESPN 142 ESNWS 143 ESPCL 144 ESPN2 146 ESP2A temp down 147 ESPNA 148 ESPNU 149 FSC 150 SPEED 151 VERSUS 152 CBSCS 153 OTDCH 154 NFL 155 Fuel 157 OVATN 158 FUSE 159 sitv 160 Mtv 161 Mtv2 162 Vh1 163 Vh1 cl 166 Cmt 167 Gar 168 SPIKE 169 NOGGIN 170 NICKELODEON (E) 171 NICKELODEON (W) 172 DISNEY (E) 173 DISNEY (W) 174 TOON DISNEY 175 BOOM 176 Toon 177 NICKG 178 NICKT 179 Discovery Kids 180 Abc Fm 181 ION 182 Disc 183 TLC 184 APL 185 Hlmrk 186 NTGEO 187 Hmc 188 Soap 189 DHLTH 190 Rlty 191 G4 192 ID 193 Sci 194 Green 195 Mil 196 Curnt 197 Doc 198 Slth 199 Chlr 200 CNN 202 Hln 203 BITV 204 Tru 205 Fox news 206 Fox Bs 207 Cnbcw 208 Cnbc 209 Msnbc 210 Cspan 211 Cspan2 212 Dish earth 213 NASA 214 Twc 215 Trv 216 ion 217 DISH 218 tjc 219 alive 220 SLTV 221 lshop 222 Hsn 223 SRN 224 SHOP 225 Tjc 226 GEMTV 227 Jtv 228 Shnbc 229 GEMS 230 ictv 231 RFDTV 232 KTLA 234 WPIX 235 KWGN 236 WSBK 238 WWOR 239 wgn 240 INFO 259 INSP 260 TBN 261 EWTN 262 ANGEL 263 DYSTR 264 KTV 265 CCTV9 univision 266 ANGL2 267 CTN 270 UNVSN 271 FTRAE Telefutura West 273 GLVSN Univision West 280 FREE 298 FREE 299 REELZ 300 HBO-E 301 HBO-2E 302 HBO SG 303 HBO-W 304 HBO-2W 305 HBO FAMILY 307 HBO COMEDY 309 HBO LATINO 310 CINEMAX - E 311 CINEMAX - W 312 CINEMAX MOREMAX 313 CINEMAX ACTIONMAX 314 CINEMAX 5-STAR MAX 318 SHOWTIME - E 319 SHOWTIME - W 320 SHOWTIME - 2 321 SHOWTIME SHOWCASE 322 SHOWTIME EXTREME 323 SHOWTIME BEYOND 327 THE MOVIE CHANNEL-E 328 THE MOVIE CHANNEL XE 329 THE MOVIE CHANNEL -W 330 THE MOVIE CHANNEL XW 332 SUNDANCE 333 FLIX 340 Encore 341 ENCORE W 342 ENCORE WESTERN 343 ENCORE ACTION 344 ENCORE MYSTERY 345 ENCORE DRAMA 346 ENCORE LOVE 347 ENCORE WAM 350 STARZ 351 STARZ W 352 Starz Edge 353 STARZ CINEMA 354 STARZ COMEDY 355 STARZ IN BLACK 356 STARZ KIDS & FAMILY 400 tenis 401 golf 402 NBATV 403 NHL 404 HRTV 405 tvGAME 410 ALTUD 412 MSG 413 MSG+ 420 FOXS 425 FOXOH 435 CSNNE 438 SNY 439 BIG10 NETWORK 455 Event PPV new 467 order 468 order 469 order 470 Service 480 ALOCK 485 ASHOW 486 ASHOW 487 TEEZ 490 ALOCK 491 JENNA 492 XCESS 493 FRESH 494 REAL (working on 488) 495 PENT 496 XTSY 498 PLBOY 490 ALOCK 498 PLBOY Playboy Espanol 500 Pay-Per-View Schedule & Previews/DISH Studio 574 NDTV Imagine 575 SAB TV 576 Zee Sports (good channel for those who like cricket) 579 Inter+ 583 Radio CitWorks 584 Sahara SamaWorks 585 AAJTK Aaj Tak 586 HT Headlines TodaWorks 601 ARTSP Art Sports 602 - Punjjabi TV 606 BBC Arabic 611 ZEETV 612 SET Max 613 TV Asia 614 SET Asia 617 Zee Cinema 618 B4U Music 619 B4U Movies 622 - Alpha ETC Punjab 623 - Zee Gujarati 624 Sahara One 642 ART America 643 ART movies 644 LBC America 645 ALJAZ Al Jazeera 646 ESC 1 647 Nile Drama 648 Future TV America & Australia 649 Dubai TV 652 KBS World 659 Dubai Sports 663 The Musik 665 Al Zikr Radio 669 ART Music (radio) 670 MBC 674 Indus Music 678 Indus Vision 702 Global One 712 Russian Extreme Sport 716 - Star Plus 718 - Star One 738 RTVI 740 NTV 741 TV Centr International 744 PTV Global 745 Geo TV 746 ARWorks Digital 747 ARWorks One World 749 TV1000 Russkoe Kino 750 EkusheWorks TV 755 Banglavision 758 ART America 759 ART Movies 760 LBC America 761 ALJAZ Al Jazeera 762 EGYPTIAN SATELLITE ESC 1 763 Nile Drama 764 Future TV America & Australia 765 Dubai TV 766 MBC MIDDLE-EAST BROADCAST 767 Alalrabiya 768 Abu Dhabi TV 769 Dream 2 770 NBN NATIONAL BROADCASTING 772 AL ARABIYA TV 774 NewTV Sat 776 Al ArabiWorksa 777 HKYAT HKWorksAT 778 NBN 779 NewTV Sat 780 Al Zikr Radio 781 ART Music 784 Euronews 787 Zeetv 788 - TV Asia 789 SET Asia 790 - Zee Cinema 791 - B4U 793 - SET Max 794 Aaj Tak 795 Sun TV 796 KTV 797 Sahara 798 Samay 805 RTV 806 Channel i 810 Radio CitWorks 818 ATN Bangla 825 Azteca 827 Univision East 828 univision west 829 DN FYI 830 FTRAE telefutura East 831 FTRAW 833 GLVSN 834 PSNES 835 Telemundo East 836 Telemundo West 838 mun2 839 CANL1 840 TVE Internacional 841 TV Colombia 843 HITN 844 Televisión Dominicana 845 Discovery en Español 846 V-me 847 TDIS 848 CBeebies en Español 850 History en Español 854 ESPN Deportes 855 Fox Sports en Español 857 Canal Sur 858 TeleFórmula 859 CNN en Español 863 PCLAS 865 CINEL 867 BDMAX 868 telehit 870 HTV 873 BOOM 874 Sí TV 876 DIY Network 877 Fox Soccer Channel 878 FX 879 BBC America 880 Bravo 881 WGN America 882 ION 883 SLTV 884 CCTV-E 885 Discovery Health Channel 886 National Geographic Channel 887 Animal Planet 888 Discovery Kids 889 WE tv 890 AMC 891 Speed 892 CNBC World 893 Bloomberg Television 894 IFC 895 Chiller 896 Hallmark Channel 897 Fox Movie Channel 898 The Movie Channel West 899 The Movie Channel Xtra West 900 Euronews 901 Euronews 981 CD32 - Hawaiian Music 988 DISH6 - Interactive sales guide 4120 History HD 4264 5313 The History Channel DH 5333 HD Theater 5771 IAD2 5772 IAD3 5773 IAD4 5774 IAD5 5778 IAD9 5816 VOD (Pay Per View Movies!!!) 5817 VOD (Pay Per View Movies!!!) 5818 VOD (Pay Per View Movies!!!) 5819 VOD (Pay Per View Movies!!!) 5820 VOD (Pay Per View Movies!!!) 5821 VOD (Pay Per View Movies!!!) 5822 VOD (Pay Per View Movies!!!) 5823 VOD (Pay Per View Movies!!!) 5824 VOD (Pay Per View Movies!!!) 5825 VOD (Pay Per View Movies!!!) 5828 SOON3 5829 SOON4 5830 SOON 5831 SOON channel down then back up to view 5832 SOON2 5833 SOON2 7083 CH7083 - ION 7113 CH7113 - ION 7217 INFO - Ion 7273 CH7273 - ION 7298 CH7298 - ION 7326 CH7326 - ION 7389 CH7389 - ION 7632 CH7632 - ION 7777 CH7777 - ION 8038 CH8038 - ION 8061 CH8061 - ION 8087 CH8087 - ION 8100 WABC (ABC 7) 8101 WCBS (CBS 2) 8102 WNBC (NBC 4) 8103 WNYW (FOX 5) 8104 WPIX (CW 11) 8105 WWOR (MY 9) 8120 CH8120 - ION 8167 WMGM - Ion 8193 CH8193 - ION 8204 KWGN - 8287 CH8287 - ION 8438 CH8438 - ION 8467 CH8467 - ION 8482 CH8482 - ION 8524 CH8524 - ION 8562 CH8562 - ION 8584 CH8584 - ION 8722 CH8722 - ION 8762 CH8762 - ION 8787 CH8787 - ION 9060 CH9060 - ION 9134 CH9134 - ION 9213 CH 9213 9252 CH9252 - ION 9287 WTLU - ION 9320 CH 9320 9399 ch 9399 9400 RSRCH 9401 HITN 9403 BYUTV 9404 UWTV 9407 COLRS 9409 CH 9409 9410 LINK 9411 NAUHS 9412 UCTV 9414 V-ME 9415 FSTV 9417 EDUCA 9420 TNT HD East (HD ONLY) 9421 Discovery HD Theater (HD ONLY) 9422 HDNet (HD ONLY) 9431 USA HD East (HD ONLY) 9432 Sci-Fi HD East (HD ONLY) 9456 HBO HD 9460 Showtime HD 9464 ORDER 9491 The History Channel HD East (HD ONLY) 9530 CH 9539 9575 VERIA 9601 BTV 9602 BTV 9611 BTV 9612 BTV 9645 LF1 9646 CH 9646 9647 CH 9657 9648 CH 9648 9649 CH 9649 9801 SPORT - DN season ticket logo 9900 DISH 500 Confirmation Channel 9945 DVRDN 9946 DVRVR 19000 OPENTV - DN setup channel 19010 OPENTV - DN setup channel 19059 OPENTV Music 19060 OPENTV Music Bev: (Updated august 08 1:09 AM EST) 48 TAC 49 vPRNT - VoicePrint DR 50 DvEPG - Audio EPG 51 CBC - East 52 CBC - West 53 CTV - East 54 CTV - Vancouver 55 GLBDv - East 56 DvGLB - West 57 CTYDv - Citytv East 58 DvCTY - Citytv West 59 E! - East 60 E! -West 61 MCTV - Sudbury 62 CTV - Winnipeg 63 CBC - Winnipeg 64 CBC - Atlantic 65 Vison - Vision TV 66 BARDv - ABC East 67 VICDv - ABC West 68 GLSDv - NBC East > no audio 69 GLCDv - NBC West 70 CTMDv - CBS East 74 PBS - East 75 DV DvPBS - West 76 CTV - Calgary 77 CTV - Edmonton 78 GLB - Winnipeg 79 ONEDv 80 WEA - Weather Network 81 MET - MétéoMédia 82 TREDv - Treehouse 83 HGTV 84 HSTDv - History TV 85 TTeDv - Teletoon East 86 TTwDv 88 COMDv - Comedy Network East 89 DvCom - Comedy Network West 90 SPCDv - Space 91 TRPDv - PRIME 100 SRC-A - Moncton 110 TVA-Q - Québec 111 SRC-Q - Québec 112 SRC-M - Montréal 115 TVA-M - Montréal AC-3 118 SRC-W - Winnipeg 119 SRC-E - Edmonton 82W SD/DS 120 SRC-V - Vancouver 121 TVA-O - Ouest 122 Vu-F - French Vu! Info Channel 125 SRC-O 126 RDI - Réseau d'information 130 METEO - MétéoMédia 149 CPACQ - La chaîne politique Canada 155 VuCOM 159 Vu-F 160 VuFr - Pleins feux sur Vu! 184 ALRT 188 iHELP - Interactive Self-serve 195 DLRHD 82W HDTV AC-3 196 NEWS1 - CJOH Local News Ottawa 197 NEWS2 - XPRS News 198 XPRS2 - ExpressVu Info 199 NTV - CTV St. John's 200 CBC - Atlantic 201 ATV - CTV Saint John 202 ASN - Atlantic Sat Network Halifax 203 CBC - Halifax 204 GLB - Halifax 205 CTV - Montreal 206 CBC - Montreal 207 E!MTL - Montreal 82W SD/DS 208 CBC - Ottawa 209 A-OTT - A Channel Ott./Pembroke 210 CBC - Toronto 211 GLB -Toronto 212 CTV - Toronto 213 SUN TV AC-3 214 CITYT - Toronto 215 OMNI1 216 OMNI2 217 CHEX - CBC Peterborough 218 E!ONT - Hamilton 219 A-BAR - A Channel Barrie/Toronto 220 A-LON - A Channel London 221 MCTV - CTV Sudbury 225 CTV - Winnipeg 226 CBC - Winnipeg 227 GLB - Winnipeg 228 CITYW - Winnipeg 229 230 XPRS 231 iHELP 232 XPRS 233 CKWS TV 82W SD/DS 235 CTV - Regina 236 GLB - Saskatchewan 239 CTV - Edmonton 240 GLB - Edmonton 241 CITYE - Edmonton 242 CBC - Northern Arctic 243 CTV - Calgary 244 GLB - Calgary 245 CBC - Calgary 246 CITYC - Calgary 249 CBCaa 250 CTV - Vancouver 251 CBC - Vancouver 252 GLB - Vancouver 253 CITYV - Vancouver 254 OMNBC - Vancouver 82W SD/DS 255 E!BC - Vancouver Island 256 A-VIC - A Channel Victoria/Vancouver 259 CFJC - CBC Kamloops 260 CKPG - CBC PrinceGeorge 8W2 SD/DS 261 VISON - Vision 264 SWAP 265 TVO 266 SCN AC-3 267 ACCES - Education Station 268 KNOW - Knowledge Network 269 APTN - Winnipeg 270 APTNn - North AC-3 274 GTV - CGTV 82W SD/DS AC-3 275 iTV - Launch Pad 280 NBC - East 281 ABC - East 282 CBS - East 283 Fox - East 284 PBS - East 287 NBC - West 288 ABC - West 289 CBS - West 290 Fox - West 291 PBS - West AC-3 294 PEACH - Peachtree TV 295 WGN - Chicago 296 WSBK - Boston AC-3 297 CW11 - WPIX - New York 298 KTLA - Los Angeles 300 M - Movie Network AC-3 301 MFEST - Movie Network AC-3 302 M-XS - Movie Network AC-3 303 M-FUN - Movie Network AC-3 304 MPIX AC-3 305 MRPIX - Morepix 306 HBO1 - East 307 HBO2 - West 308 MC1 - Movie Central 309 MC2 - Movie Central 310 MC3 - Movie Central 311 EA1 - Encore Avenue 312 EA2 - Encore Avenue 325 SUPRi 326 SUPR1 - Super Channel AC-3 327 SUPR2 - Super Channel AC-3 328 SUPR3 - Super Channel AC-3 329 SUPR4 - Super Channel AC-3 330 IFC AC-3 331 MVOLA - Movieola AC-3 332 SCRM - Scream AC-3 333 DRVin - Drive-In Classics AC-3 334 ACTN - Showcase Action AC-3 335 DIVA Showcase Diva AC-3 336 DOCU - Documentary Channel AC-3 337 SLVSC - Silver Screen Classic Movie 82W SD/DS AC-3 387 VuBuy 388 GolSP - GOLTV Spanish Audio AC-3 389 WLDTV - Wild TV AC-3 390 FIGHT - Fight Network 400 TSN - EXTRA 401 TSN2 402 TSN A - Regional 403 PPVu 404 GolTV - GOLTV AC-3 405 SNETO - Rogers Sportsnet Ontario 406 SNETE - Rogers Sportsnet East 407 SNETP - Rogers Sportsnet Pacific 408 SNETW - Rogers Sportsnet West 409 ESPN Classic Canada AC-3 410 SCORE - Score 411 OLN - Outdoor Lifestyle Network 412 FOXSP - Fox Sports World Canada AC-3 414 PPVu - Info 415 RAPTR - Raptors NBA TV AC-3 416 GOLF - Golf Channel 417 SPEED - Speed Channel 419 WFN - World Fishing Network AC-3 420 SETNA - Setanta 421 NHL - Network AC-3 423 424 NHLVu - NHL Centre Ice Extra 426 NHL1 - NHL Centre Ice 440 NCAR - NASCAR HotPass 441 NCAR1 - NASCAR HotPass 442 NCAR2 - NASCAR HotPass 443NCAR3 - NASCAR HotPass 444 NCAR4 - NASCAR HotPass 448 NFL - NFL Network AC-3 451 NFL1 - Sunday Ticket 481 VuPPV 500 CNN 501 CTVNN - NewsNet 502 CBCNW - NewsWorld 503 CP24 504 BNN - Business News Network 505 WEA - Weather Network 507 FOXNC - Fox News 508 HLN - Headline National News 509 CNBC 510 BBCWN - World News 512 CPAC - Cable Public Affairs 514 ISSUE - i Channel AC-3 515 TECH - G4 Tech TV AC-3 516 SLN - Sask. Legislative Network 82W SD/DS 519 MOVIE2 520 DISC - Discovery Channel 521 TLC - Learning Channel 522 HIST - History TV 523 CIVIL - Discovery Civilization AC-3 524 GEO - National Geographic AC-3 525 ANIML - Animal Planet AC-3 526 VIVA 527 TRAVL - Travel + Escape AC-3 528 COURT - CourtTV Canada AC-3 529 BOOK - BookTelevision AC-3 530 BITE - Bite TV 82W SD/DS 549 PHDIS - Playhouse Disney AC-3 551 YTV - East 552 YTV - West 553 TREE - Treehouse 554 TOONE - Teletoon East 555 TOONW - Teletoon West 556 FMLY - Family Channel East 557 FAM-W - Family Channel West 558 BBC - Kids 559 D-KDS - Discovery Kids AC-3 570 MUCH - MuchMusic 571 MMM -MuchMoreMusic 575 CMT - Country Music Television 576 BET - Black Entertainment Television 577 MTV2 - Razer AC-3 578 PUNCH - PunchMuch 82W SD/DS AC-3 579 BPM - bpm:tv AC-3 580 VIBE - MuchVibe 581 MTV 599 TOONR - TELETOON Retro AC-3 600 HGTV 601 SLICE - Slice 602 W Network 603 FOOD - Food Network Canada 604 HLTH - Discovery Health AC-3 605 FTV - Fashion Television AC-3 606 ONE - Body, Mind & Spirit AC-3 607 FineL - Fine Living 608 COSMO - Cosmopolitan 609 OUTTVOUTtv AC-3 615 A&E 616 SHO-E - Showcase East 617 SHO-W - Showcase West 618 TROP - TVtropolis East 619 TROPW - TVtropolis West 620 BRAVO - Bravo! 621 STAR - Star! 622 BIO - The Biography Channel AC-3 625 CMDY - Comedy Network East 626 CMDYW - Comedy Network West 627 SPACE - Imagination Station 628 Spike TV 629 MENTV - mentv AC-3 630 MTIME - Movie Time AC-3 631 MILIT - Military 82W SD/DS 635 BBC Canada AC-3 636 DEJA - DejaView AC-3 637 TVLND - TV Land AC-3 638 MSTRY - Mystery AC-3 639 GAME - GSN, Network for Games 641 BOLD AC-3 651 CTS - Crossroads Television 652 MIRCL - Miracle 660 TSC - Shopping Channel 670 VuS32 671 672 XPRS2* 690 BINGO 82W SD/DS 700 TELAT - Telelatino 702 ATN Zee 82W SD/DS AC-3 705 TAMIL - ATN Tamil 82W SD/DS 706 B4U - ATN B4U 82W SD/DS 715 PHNIX - Phoenix 82W SD/DS 716 FAIRM - Fairchild - Toronto (some Mandarin) 82W SD/DS 717 FAIR - Fairchild - Toronto 82W SD/DS 718 FAIRW - Fairchild West 82W SD/DS 719TALNT - Talentvision 82W SD/DS 727 NDTV82W SD/DS 728 ARY 82W SD/DS 729 Sony TV 82W SD/DS 730 CBN 82W SD/DS 731 ALERT 732 LOCK 742 VNUS - Info 745 SEXTV AC-3 779 SSrv6 780 PLBOY 781 AOV 791 LOCK 792 SUPRi 794 ITVBz 795 GAMES 800 CTV HE - East 82W HDTV AC-3 801 GLB HE - Toronto 82W HDTV AC-3 802 CBC HE 82W HDTV AC-3 803 CTY HE - Citytv 82W HDTV AC-3 804 CBC HW - HD 2 82W HDTV AC-3 805 HD-Vu 82W HDTV AC-3 806 CTV HW - West 82W HDTV AC-3 807 GLB HW - West 82W HDTV AC-3 808 APTNH 82W HDTV AC-3 811 RUSH - Rush 82W HDTV AC-3 813 A&E 82W HDTV AC-3 814 HD NET - Net 82W HDTV AC-3 815 NBC HE - East 82W HDTV AC-3 816 ABC HE - East 82W HDTV AC-3 817 CBS HE - East 82W HDTV AC-3 818 FOX HE - East 82W HDTV AC-3 819 PBS HE - East 82W HDTV AC-3 820 NBC HW - West 82W HDTV AC-3 821 ABC HW - West 82W HDTV AC-3 822 CBS HW - West 82W HDTV AC-3 823 FOX HW - West 82W HDTV AC-3 824 PBS HW - West 82W HDTV AC-3 825 WGN 82W HDTV AC-3 828 GEOHD - National Geographic 82W HDTV AC-3 829 VuHD - Barker Channel 82W HDTV AC-3 836 HBO1 - East 82W HDTV AC-3 837 HBO2 - West 82W HDTV AC-3 838 SHW - Showcase 82W HDTV AC-3 839 MPX - MPix 82W HDTV AC-3 839 MPX - MPix 82W HDTV AC-3 840 M - Movie Network 82W HDTV AC-3 842 MC - Movie Central 82W HDTV AC-3 843 HD1 - SCHD1Super Channel 82W HDTV AC-3 844 HD2 - SCHD2Super Channel 82W HDTV AC-3 845 SCRHD Score 82W HDTV AC-3 846 SNH-O - Rogers Sportsnet Ontario 82W HDTV AC-3 848 SNH-P - Rogers Sportsnet Pacific 82W HDTV AC-3 850 TSN 82W HDTV AC-3 851 TSN2 82W HDTV AC-3 853 GLFHD - Golf Channel 82W HDTV AC-3 860 SRCHE 82W HDTV 861 TVA 82W HDTV 862 TQS 82W HDTV 864 TV5HD 82w 872 SNHD5 82W HDTV 875 NSCH1 82W HDTV 876 NSCH2 82W HDTV 890 COMM SD/DS |
VENEZUELA, M...
Post Number: 413 Registered: Nov-07
| Posted on Monday, September 14, 2009 - 07:52 am: |
emilio: *** MUERAN TODOS LOS COMUNISTAS, Y TODOS AQUELLOS QUE ,TRATAN DE PISAR EL EXILIO CUBANO,,, UN CONCIERTO NO CALMA EL DOLOR DEL PUEBLO CUBANO,,,,,,,,,CUBABAJOCERO/. *** Que es esto??? eres el mismo que dice esto??? *** BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,, *** Creo que o es una cosa o la otra... amigo creo que estas confundido, este no es un foro para desearle la muerte a nadie. LARGA VIDA PARA TODOS (Y CON BASTANTE SALUD!) Saludos. |
VENEZUELA, M...
Post Number: 414 Registered: Nov-07
| Posted on Monday, September 14, 2009 - 07:55 am: |
Bueno tambien se pueden publicar listas de canales sin llenar toda la pagina. Como los de KBOX Los DN http://www.ftabins.net/showthread.php?t=101088 Los B3v http://www.ftabins.net/showthread.php?t=102033 Los internacionales http://www.ftabins.net/showthread.php?t=103648 Saludos |
Miami,
Fl
Usa
Post Number: 602 Registered: Jun-06
| Posted on Monday, September 14, 2009 - 08:09 am: |
ALGUIEN QUE ESTE AL TANTO SI SE LEVANTA EL SERVER DE NFUSION !!! hasta ahora esta todo caido . |
Silver Member Username: Elparrandero
Los angeles,
Ca
Los angeles
Post Number: 298 Registered: Dec-07
| Posted on Monday, September 14, 2009 - 12:38 pm: |
hola saludos a todos ,espero ke tengan un buen dia ,,,aki reportando ke mi nfusion solaris ,aun sige sin nada de nada ,,esperemos ke esto se resuelva lo mas pronto ,,asta la proxima ..pasenla bien todos |
FRANCIA,
CA
Post Number: 235 Registered: Feb-08
| Posted on Monday, September 14, 2009 - 01:07 pm: |
ROBERTO Y SOLO UNO: LAS NFUSION ESTAN TRABAJANDO AL 100% DESDE AYER Y AUN ESTAN UP SALUDOS |
Irapuato,
Guanajuato
Mexico
Post Number: 145 Registered: Aug-06
| Posted on Monday, September 14, 2009 - 01:54 pm: |
  que tal. como estan todos y todas. en este comienzo de semana. que planean para el dia de mañana. { hoy en la mañana esta viendo. mis correos. en uno tenia un aviso de un amigo. quien es el que me manda. el archivo para ver la tv. que me dice que en este mes de sep. tendremos luz. espero sea { ok por lo pronto las { 2 antenas. que tengo una la deje en el { galaxy 19 } = globe cast que se los recomiendo son canales iternacionales que tienen muy buena programacion en su idioma. la otra ya la regrese al { 119 } = echostar/ku 7 saludos desde la capital de las fresas * pd : juan carlos fuentes habra algun sitio donde este la programacion del { globecast } o algun magazine.   }} |
Monterrey,
Nuevo León
Mexico
Post Number: 397 Registered: Sep-06
| Posted on Monday, September 14, 2009 - 02:38 pm: |
YA ME DESESPERE, TENGO 4 SABADOS(POR QUE SON LOS DIAS QUE PUEDO) TRATANDO DE BAJAR EL AMC5, NO ENTIENDO POR QUE ME DA 0% DE CALIDAD YA PROBE TODO LO ESCRITO Y LEEIDO Y POR HABER MUCHAS HORAS MOVIENDO LA ANTENA Y NADA, SEGUI LAS INDICACIONES DE ALGUNOS MASTERS Y NADA, NUNCA HABIA BATALLADO CON UN SATELITE, PERO NO ME DOY PORVENCIDO NI TAMPOCO PAGARE POR QUE ME LO BAJEN. ALGUIEN QUE YA LO BAJO CON UN PANSAT Y ME DE LAS CONFIGURACION QUE TIENE,PARA VER SI EL SATELITE ESTA MAL CONFIGURADO EN LA LISTA QUE TENGO DE SATELITES QUE LE PUSE YA HACE UN BUEN RATO CON EL CHANNEL MASTER. GRACIAS |
Gold Member Username: Jorge_luis
Post Number: 2704 Registered: Jul-06
| Posted on Monday, September 14, 2009 - 02:39 pm: |
ics, iks, server privado 16 dlls. x mes solo los equipos: Dreambox, Iorion, CaptiveWorks cualquier modelo,ILINK, DVBCards,NEOSAT y NEUSAT LISTA DE CANALES.- -http://ftaup.com/vb/attachments/discusiones-generales-del-ics/8841d1252685761-li sta-de-canales-canales_con_sat.jpg registrate en la pagina www.ftaup.com/vb y diles que ERROR te recomendo para darles atencion personalizada. |
Los angeles,
Ca
Los angeles
Post Number: 299 Registered: Dec-07
| Posted on Monday, September 14, 2009 - 02:50 pm: |
dicen ke ya esta funcionando la nfunsion ,,bueno boy a chekar alrato,,y acaso tego ke aser algo para ke funcione o solo tengo ke apagarla de atras ,,bueno ahi les encargo porfas ,,gracias de antemano |
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 108 Registered: Nov-07
| Posted on Monday, September 14, 2009 - 03:05 pm: |
COMENTARIO: TENGO UN NUVENIO SD Y TRABAJANDO AL 100% Y DESDE AYER ESTOY LEYENDO QUE LOS ENFUSION ESTAN DOWN Y YO CHEQUEO Y CHEQUEO Y TODO UP AL 100% |
Bronze Member Username: Ravim
Post Number: 65 Registered: Jan-08
| Posted on Monday, September 14, 2009 - 04:48 pm: |
Buenas tardes a todos los ft@migos de este gran foro, en especial un gran saludo al zorro critico uno de los grandes masters de este foro, una pregunta a todos, ahora que esta esto de los iks, como es que se tiene uno que conectar para lograr ver la tv?,tiene uno que conectar el aparato a la pc?, al comprar cualquiera de los aparatos hay que estar pagando alguna mensualidad para recibir los archivos que necesita el aparato?, por sus atenciones gracias |
