Home > Message Board > Home Video > Rear Projection TVs > Samsung DLP shuts off after 30 seconds
Author Thread: Samsung DLP shuts off after 30 seconds
Username: Cleonard73
Chesapeake, VA
I have a Samsung HLSA4676SX 46 Inch DLP, when I turn the TV on I get a picture for about 30 seconds then the picture disappears and I still have sound for another 10 seconds or so. Once the picture and the sound are gone I have 3 flashing lights on the front of the TV. I want to replace the bulb but before I do I was wondering if this could be something else. The TV is 2 and a half years old.
Username: Trece
Tijuana
Mexico
Hi Chris,
Well, the normal lifespan of this UHP lamps are about 3500hrs to 4500hrs on generic lamps, the Philips lamp is around 6000hrs to 8000hrs, you can read how this lamps works at
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?Click=48426
"The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp."
Is similar as the front lights of your car, with halogen gas instead, with the time and use, this gas runs out and they get dimmer. Same thing with this ones, until it reaches some point where there is no enough gas inside to keep and maintain the lamp on. I am sure that if you continue to use it, it will get into a point where the lamp is not going to even ignite.
Your Lamp's Model # is on the back of your left speakers on a sticker, I believe is a BP96-01653A but double check I found them on ebay and here
http://www.discount-merchant.com/Samsung-BP96-01653A-p/samsung-bp96-01653a_lamp_ oem.htm?Click=48426
Chesapeake, VA
Thanks for your explanation in this matter Jake, I went ahead and ordered the bulb from discount-merchants and I made sure to order the phillips bulb in the samsung housing, hope it fixes my problem, as soon as I hook it up i will let you know.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Samsung DLP shuts off after 30 seconds [ « Previous ] [ Next » ]
