Thread: Sammy DLP - metallic noise? Picture and sound still perfect |
New member Username: Arrowhead
Post Number: 1 Registered: Sep-09
| Posted on Tuesday, September 08, 2009 - 05:52 pm: |
My Samsung HLN467W is 4 y.o. and generates a metallic whirring noise upon startup that alternates between noticable and downright loud. Here's the catch: picture and broadcast sound remain flawless. The metallic sound remains nearly constant from the TV enclosure. What is the most likely cause of this issue? Thanks in advance. |
New member Username: Jaymora2009
San Diego,
California
United States
Post Number: 4 Registered: Sep-09
| Posted on Wednesday, September 23, 2009 - 01:38 pm: |
Hi Mike Do you see or feel any vibrations on the TV when this occurs? Do you hear any winding, whirling or screeching noise on the TV, if this is the case it could be an issue with your color wheel and definitely and needs to be replaced but I advise to check this with a technician in your area or through an authorized service center too. If you need the color wheel here is the one you need according to samsungparts.com info http://www.samsungparts.com/part_detail.asp?catalog_name=Parts+and+Accessories&p roduct_id=BP96-00250A&search_model=HLN467W Good Luck |
New member Username: Samuel11
Post Number: 2 Registered: Sep-09
| Posted on Thursday, September 24, 2009 - 12:31 pm: |
Hi Mike, If you are hearing this noises,that's your Color Wheel. The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out. Grinding= Most probably the color disc is broken and you need to replace it. Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake. The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it. You can check DM they have very good prices http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l I hope this will help,please keep us posted. |
