Home > Message Board > Home Video > Rear Projection TVs > Blue spots
Author Thread: Blue spots
Username: Ronjones
Sony KDF-60XS955, manufactured in March 2005, have blue spots and blotches on screen....have anyone experienced this?
Username: Tvshopper
Post Number: 220
A bunch of listings.
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4DKUS_enUS220US22 1&q=blue+spots+Sony+KDF-60XS955
Username: Jaymora2009
San Diego, California
United States
The issue that you are reporting relates to an issue with the optical block of your tv and which for some reason (probably time) could show those blue spots in the tv, the question here is exactly where do you get the blue spot? in the middle? on a corner? but I can assure that the problem will be the optical block, click on the link that explains the ongoing issues that Sony has dealt with in the past 5 years: http://www.tvlampsnbulbs.com/2008/08/sony-optical-block-issues-addressed/
Good Luck
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Blue spots [ « Previous ] [ Next » ]
