Home > Message Board > Home Video > Satellite TV > Archive through May 08, 2004 > My HU card is in yhr Mikobu III an...
Author Thread: My HU card is in yhr Mikobu III and it tells me to insert card
I have a MIkobuIII , and then using extremeHU3.5a when I try to clean the card I received a message that says please insert card!?
At the bottom . it tells me COM 3 ready and device detected? I have reinserted this card at least 20 times and still get the same response
Is there anyone who can help me . please please please
DNKS
Even though this post is an old one I thought I'd respond to it for any future lookers.
The issue you are having is due to not inserting your card properly in the card slot of the loader. You must insert the card with the chip facing upwards.....or towards the sky. This will solve your issue.
DNKS
CodeHacks.com
Username: Jasonofjwc
Cincinnati, Ohio
i have a t911 loader which was working fine when i recieved it.while unlooping HU card, message appeared and said insert card into loader. the card is in right,but i only get one message to insert the card no matter what i do.i'm pretty much confused and aggitated.can anyone help???
look under system in control panel and check to see that your com on your computer is the same as on programmer. if not then change it and this should fix the problem!!!!
Home > Message Board > Home Video > Satellite TV > Archive through May 08, 2004 > My HU card is in yhr Mikobu III an... [ « Previous ] [ Next » ]
