Thread: LH-R5500W not reading DVD-RW disk's free time |
New member Username: Awc
Post Number: 1 Registered: Aug-09
| Posted on Monday, August 17, 2009 - 08:03 am: |
My old man's LG LH-R5500W recorder is not reading the free time available on DVD-RWs properly. An initialized disk is not showing the proper amount of free time on his machine yet on mine its fine. Any ideas why this happening? |
Gold Member Username: Samijubal
Post Number: 4150 Registered: Jul-04
| Posted on Monday, August 17, 2009 - 09:03 pm: |
Is the record time set the same on both recorders, XP, SP, LP, etc.? |
Post Number: 2 Registered: Aug-09
| Posted on Tuesday, August 18, 2009 - 05:33 am: |
Oh my dad's SP it shows only 19 minutes or something whereas mine shows the regular 2 hours or whatever it is. |
Post Number: 4151 Registered: Jul-04
| Posted on Tuesday, August 18, 2009 - 07:04 am: |
Try resetting the recorder. Everything digital needs reset somewhere down the line. Try pressing the power on the unit for 10 seconds. If that doesn't work you'll probably have to contact the manufacterer. They all have a certain method for resetting. |
