Home > Message Board > Home Video > HDTV Reception > SAMSUNG 50"DLP 1INCH GREY BAR AT LEFT...
Author Thread: SAMSUNG 50"DLP 1INCH GREY BAR AT LEFT SCREEN
Username: Citylites
mY SAMSUNG DLP 50" developed a 2 inch grey transparent bar at the left screen. I got a spare bulb and put it in and still did not solve annoying bar. Is this a menu configuration adjustment issue? Tks to all your help.
Username: Xedlos
This might be a problem with your color wheel
Username: Citylites
If it is, I guess I'll have to wait till it dies down. I'll live with it for the time being and decide what to do with this technically challenged TV model. Tks. so much for your help..
Username: Citylites
Bringing this thread to a closure., the problem was the LIGHT TUNNEL. It was apparently a design defect. There were a lot of threads i came across in other forum sites with the same subject. The defective part should have been recalled by Samsung. Well the good news was mine was replaced by Samsung free of charge albeit my tv had 2,550 lamp life (bought mine in 2005). So folks out there with same issue, just call samsung. You,re gonna get free replacemnt if indeed it was the defective LIGHT TUNNEL. tks.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > HDTV Reception > SAMSUNG 50"DLP 1INCH GREY BAR AT LEFT... [ « Previous ] [ Next » ]
