Home > Message Board > Home Video > Rear Projection TVs > Installing the poer board on hl r6167w
Author Thread: Installing the poer board on hl r6167w
Username: 99johnny99
needing help again! i have a new power board, not sure of 3 out of 5 connections. i figured out the large clips, i have a negative ground wire, but the board has 2 posts, 1 towards the rear of the board and 1 above the 2 large clips, second, the new board came with a pair of wires(blue&brown) with a weight, the original 2 wires with a weight (white&Blk) are still in the set,should i use the new wires? I see a 2 wire from the outlet from which the external plug connects to but not sure where these 2 wires connect on the power board. Are ther any photos availabe to help with connecting this board?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Installing the poer board on hl r6167w [ « Previous ] [ Next » ]
