Home > Message Board > Home Video > Satellite TV > SOLO HISPANOS--2 > Archive through July 07, 2009
Author Thread: Archive through July 07, 2009
Username: Canada_havana
Post Number: 2032
tomado de otra page,,, tratenlo a su propio riesgo,,, y posten informacion,,,,,, Member Join Date: Aug 2007
Confirmed 177 CN working..chirp method VS ULTRA
confirmed by me.
VS ULTRA
Delete all channels by going to:
Menu and selecting:
Edit channels:
Right arrow to select delete:
and hit f3 to delete all channels.
exit and save
Now goto Channel Scan
Satellite ( Pick ********110*)
Network Search (OFF)
Scroll down to edit transponders
Hit F3 button on remote & DELETE ALL TRANSPONDERS
After deleting hit F1 on remote to add user transponder.
Freq = 12486,S/R = 20000,Pol = V,FEC = 5/6,TV & Radio will be zero because I'ts not saved yet. NOW EXIT on Remote.
HIT F4 to manually add user channel
VIDEO PID = 6946
AUDIO PID = 6947 (always one up from video no matter what!!)
PCR PID = 6946
HIT ENTER on remote
Now hit exit & save !!!
NOW WATCH Cartoon Network!!!
This is for bird 110*
Alot more testing is under way for other channels and wondering if channel editor can be used to manually enter tp's and channel pids for each bird!
Will post results at a later time for other channels
__________________
testing
viewsat ultra
pansat 2700 n2
lifetime classic na
co-olsat 5000
vs platium
vs extreme
cw 800
vs ul
cs 6100
Sponsored Links
Tired of waiting days for fixes? Click here to get 3000 channels.. NO DOWNTIME, Guaranteed!
musky
View Public Profile
Send a private message to musky
Find all posts by musky
Add musky to Your Contacts
#2 (permalink) Today, 03:19 AM
daveo4567
ViP Member Join Date: Nov 2007
Works, Thanks for sharing.
daveo4567
View Public Profile
Send a private message to daveo4567
Find all posts by daveo4567
Add daveo4567 to Your Contacts
#3 (permalink) Today, 03:25 AM
Shinano-1
ViP Member Join Date: Jul 2006
It Work on xtreme
I tried work on xtreme just 1 channel
Shinano-1
View Public Profile
Send a private message to Shinano-1
Find all posts by Shinano-1
Add Shinano-1 to Your Contacts
#4 (permalink) Today, 04:21 AM
rockyj
ViP Member Join Date: Oct 2007
hello I tried it on my ultra got picture no audio is their something I can do for audio thanx rocky
rockyj
View Public Profile
Send a private message to rockyj
Find all posts by rockyj
Add rockyj to Your Contacts
#5 (permalink) Today, 05:37 AM
wipf30
ViP Member Join Date: Apr 2008
hi everyone, i tried what Musky is offering on my viewsat platium lite and it worked for me , i got 2 channels now it's better then not having any, i got channel 11399 (CTN) and ch. 09979 ( ion t.v.) good luck to everyone,
wipf30
View Public Profile
Send a private message to wipf30
Find all posts by wipf30
Add wipf30 to Your Contacts
#6 (permalink) Today, 05:53 AM
SmittyKool
ViP Member Join Date: May 2009
Job Well Done!
SmittyKool
View Public Profile
Send a private message to SmittyKool
Find all posts by SmittyKool
Add SmittyKool to Your Contacts
#7 (permalink) Today, 01:40 PM
The Wufman
ViP Member Join Date: Apr 2009
Try this for up to 6 channels
I can confirm this to be currently working for these channels on sat 110 on all my receivers:
7/03/09 These Channels Confirmed Working At Present
C & P
6 channnels have become available by manually inputting PID info into your TP information menu. To do this, go to your Channel Scan Menu for DN 110. Select TP 12486, then select 'Add user channel' (F4) on some units. You must then fill in the V, A and P lines with the following information. When finished each entry..hit the OK button. For the moment it is best to keep Auto TP OFF but keep your normal EPG as you can use this as reference for programming guide for these channels. A 'User Channel List' will be created below channel 100 in your EPG. These channels will have no numbers on them....so the list below will give you their associated channels for reference.
If any further channels are acquired, please advise in this thread and I will add them on...thanks.
Important Announcement: These channels are all coming FTA. No bins required. This means that these channels should be available on every receiver that is getting DN 110.
177 - Cartoon Channel West
V6946
A6947
P6946
181 - N (Nogin channel)
V4130
A4131
P4130
217 - ION W - Alternative Time selection to ION Channnels on FTA
V6434
A6435
P6434
267 - CTN (Religious Programming)
V6690
A6691
P6690
867 - BDMAX - Spanish Language Channel
V6178
A6179
P6178
Also one channel working for DN promo
NOTE:Not all receivers work the same way as far as how to input this info manually;refer to your receiver section to find out any info for your brand/model if unsure of how to do this.
Username: Rocas
Humble, Tx
Harris
Post Number: 131
hola a todos tengo una pregunta estube tratando bajar algunos otros pajaros y tube exito gracias a ustedes pero la pregunta es la siguiente les a pasado a ustedes que la barra de calidad en su reciever se va de 0 a 100 para ariba y para abajo? bueno ese es el problema que tengo porque ahora ni siquiera puedo agarrar los pajaros mas facil (110,119) es un vs exremme necesito ayuda por favor nota estoy usando los lnb correctos para cada pajaro ise defaul para borrar todo y aun asi nada gracias y ojala algun maestro me pueda ayudar
Username: Oldgreen
Post Number: 202
Hello Underground Community:
Quisiera saber si alguien que se encuentre en Canadá está captando señal de Hispansat.....
Gracias de antemano
Oldgreen
Username: Dilan
GUADALAJARA, JALISCO
MEXICO
Post Number: 128
juan loeza,,te dejo esta info,,de los lnbs....200 pesos usados,,,es lo que dice,,,si quieres nuevo ve a cp electronics esta por americas y pablo neruda,,,o tres w punto cpelectronics punto com
Username: Dilan
MEXICO
Post Number: 129
Lnb amazonas de mayoreo
Lnb dms internacional es el lnb mas fuerte da 10% mas de calidad que cualquier lnb y tiene 2 salidas por si quisieran agregar un 2do decodificador a su casa
Uno solo $450 y mas de 10 $300
Tambien tenemos lnb lineal para amazonas o cualquier satelite
Uno solo $200 y mas de 10 $100
Si compra mas de 10 lnbs les voy a pasar informacion que vale oro
Un transponder para buscar amazonas que da 100% de nivel y 100% de calidad hasta con antena de 1.80 para que no les cueste nada de trabajo encontrar el satelite solo con dms internacional ademas de 7 tps para abrir todos los canales con 5 puntos mas
Ademas tenemos decodificadores antenas de todos tamaños tambien vendemos moldes de channel master equipos ikas
y tambien tenemos una maravilla de antena para mazonas que da de nivel 70% en el transponder mas fuerte y 65% en el tp mas debil esta muy fuerte queda 40 puntos arriba antes de cuadricular el canal, suporta lluvias, la antena es original y mide 2.40 mts vale $5000 ademas de que abre cualquier satelite fta (free to air) que se le ponga enfrente le saca el mayor nivel posible y se le puede agregar un 2do brazo para ver un satelite libre que tiene el canal de telemundo para ver futbol
Precio: 100 pesos
Nombre: Hashfta
Celular: 3314194653
Username: Sergio_verdugo
Hermosillo, Sonora
Mexico
Post Number: 929
JAVI
BUENA APORTACION
Username: Javy_gza
PERROS BRAVOS , NUEVO LEON
Post Number: 2189
SALUDOS A LA RAZA
OK SERGIO VERDUGO . SALUDOS
Username: Portero_bc
Post Number: 12
Dilan muy completa tu inf. gracias y tomare encuenta toda esta, disculpa mi pregunta: tu te dedicas profesionalmente a esto de fta o simplemente lo ejerces de joby? gracias.
Username: Dilan
MEXICO
Post Number: 130
juan loeza,,,yo no me dedico,,a eso es puro pasatiempo,,la circustancias del terreno donde vivo,,no me dejan agarrar la señal de la tv abierta,,estoy muy abajo,,ni con 15 mts de altura agarro la señal libre...pero es bonito este joby
Username: Pacha19
Post Number: 251
Saludos a todo el foro =)
Username: Oldgreen
Post Number: 203
Para Juan gonzalez
Una vez tuve ese problema.....
Tuve que cambiar un condensador dañado en la placa electronica del receiver.
Puede ser o no lo que te genera el problema.
Apaga y desconecta todo....
Abre la caja y revisa si alguno de los condensadores se encuentra quemado o se ve un poco "inflado"...... si es asi, debes cambiarlo.
Esto ocurre porque el medio ambiente donde se encuentra el receiver es muy seco. Normalmente ocurre en invierno por la calefacción.
Suerte
Oldgreen
Username: Elparrandero
Los angeles, Ca
Los angeles
Post Number: 286
hola saludos ,a todos ,,alguien save cuantos canales se ven en ,, nfusion solaris,,,por ke no tengo idea por el momento,,,de antemano gracias
Username: Fletes
Montreal, Quebec
Post Number: 28
Hola A todos! como estan? alguin me podria informar sobre el satelite satcom c4 quisiera saber si hay canales en espanol y si lo puedo captar en canada. gracias de antemano por cualquier information util que me puedan proveer. Gracias!
Username: Oldgreen
Post Number: 204
Jesus:
Puedes encontrar toda la información en:
http://www.lyngsat(punto)com/
reemplaza punto por .
Oldgreen
Username: Viejo_pedro
Post Number: 208
buenas a todos del forun, esto es un mensaje para los amigos que les gustaria ver tv en internet canales ecuatoriano colombiano cubanos y argentinos, no hay que registrarse es gratris
hay como 12 canales de deportes peliculas y noticias
en www.elastillero.com hasta que venga la luz
Post Number: 209
disculpa son 21 y hay un canal brasilero y 4 emisora de radio
Username: Juancholagarto
Mexico City, D.F.
Mexico
Post Number: 1205
solo uno:
Son 48 canales en DN. Esta es la lista que puso hace días el buen Fred Olavarría:
106 TVLND
108 LIFE
109 LMN
120 HIST
121 HISTI
122 SCIFI
125- PIRATE TV
127 OXYGN
128 we
129 BRAVO
130AMC
131 IFC
132 TMC
136 FX
168 SPIKE
169 NOG/N
170 NICK
171 NICKW
172 DISE
173 DISW
174 TDIS
175 BOOM
213 NASA
216 C&T
240 INFO
262 ANGEL
280 FREE
298 FREE
300 Hbo-E
301 Hbo-2e
302 Hbost
303 Hbo-w
304 Hbo2w
305 Hbofm
307 Hbocy
309 Hbolt
329 TMC-W
330 TMCXW
341 ENCRW
342 EWSTN
343 EACTN
344 EMYST
345 EDRAM
346 ELOVE
347 EWAM
350 STARZ
351 STRZW
353 SCINE
354 STZC
355 SBLCK
356 SK&FM
Y si apuntas al Nimiq 1, vas a tener muchísimos más canales.
Saludos
Username: Javy_gza
Post Number: 2190
WENO RAZA
AHORA VOI X EL HISPASAT 1 C , D NOMAS
Q ME DIGAN CUAL TP TIENE MAS SEÑAL
PA LA RAZA DE MTY O DE DDE SEA . SALUDOS
NOTA
LO Q PASA Q TENGO UN ARBOLOTE ENFRENTE
DE MI CASA A VER SI NO ME ESTORBA. SALUDOS
Mexico City, D.F.
Mexico
Post Number: 1206
Aquí pueden encontrar el listado completo de los canales de DN y BEV que se están viendo actualmente con Nfusion Solaris para arriba.
Lista actualizada al día de hoy.
http://www.ftatalk.com/showthread.php?t=296878
Saludos.
Mexico City, D.F.
Mexico
Post Number: 1207
Javy Gza:
El Tp con más fuerza para el Hispasat es el 12052.
Saludos y suerte.
Username: Javy_gza
Post Number: 2191
OK JUAN CARLOS TOMO NOTA Y ME AVENTURO
A BAJARLO
SALUDOS Y GRACIAS .
Mexico City, D.F.
Mexico
Post Number: 1208
Un verdadero placer poder ayudar a los demás compañeros del mismo pasatiempo.
Saludos.
Username: Oldgreen
Post Number: 205
Para los interesados en Hispasat y Amazonas pueden encontrar algo de informacion en:
http://www.hispasat.com
Saludos
Oldgreen
Username: Borinick
Post Number: 520
tengo una pregunta mi queridos de este foro feliz dia de independencia a todos es que canales se ven en las amazonas ?
Username: Negro2tity
Post Number: 57
Emilio, confirmo que trabaja tu aportacion en el VS Platinium...si tienes mas, con todo te agradeceria compatriota...
Roger out, desde winnipeg
Post Number: 2033
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,,
Post Number: 58
Emilio trabajara los mismos settingdel VS para el Pansat 27k00? los voy a probar hay te aviso..
Post Number: 2034
MANNY,,, ESTOS SON LOS RECIVER QUE SE TESTEARON,,,,,, ALGUNOS CAMBIAN LOS SETTING , PERO ES LO MISMO.....testing
viewsat ultra
pansat 2700 n2
lifetime classic na
co-olsat 5000
vs platium
vs extreme
cw 800
vs ul
cs 6100
Post Number: 60
Emilio, garcias pero cuando trato de agregar otro canal, solo cae encima del anterior, es decir no puedo agregar mas que uno, me puedes dar el manner way como lo puedo h@cer...gracias.... Winnipeg out
Post Number: 210
buenos dias a hesa jente linda del forun .
disculpe que puse mal la direccion de los canales en
internet tv, en especial para los ecuatorianos por que
hay como 8 canales del ecuador.
http;//www.elastillero.tv
Username: Joseluis
MeXiCaLi
Post Number: 59
buen dia estimados foristas
quisiera saber que equipo IKS funciona mejor con internet telnor, o mas bien dicho modem/router 2WIRE que es el que proporciona telnor con el servicio inalambrico este tiene 4 puertos ethernet como algunos de ustedes saben.
ya he hecho algo de lectura sobre los equipos en si, estoy un poco inclinado hacia kbox o quizas CNX nano con dongle pero quiero saber que tal funcionan con este modem/ router 2WIRE.
les agradezco sus opiniones , su experiencia.
Username: Espartano
Post Number: 73
buenos dias a todos, tenfo un Fortec (Flu) convertido a PUFF, despues de todos estos cambios ya no tengo senal, puedo seguir utilizandolo? que debo de h@cer para ver canales? tengo una antena Pish Pro con un LNB. espero sus comentarios.
saludos a todos.
Username: Joseluis
MeXiCaLi
Post Number: 60
parece que conaxsat nano esta apenas haciendo pruebas, creo que le falta un poco, sin embargo tiene muchos canales.
kbox parece que tiene mucha estabilidad.
si alguien de mexico los ha probado a ver si puede compartir su experiencia
Username: Joseluis
MeXiCaLi
Post Number: 61
joshua
los flu soportan hasta hoy solo n2
por lo pronto no hay fixx para n3 tu flu no podra abrir nada ahora.
solo hay que esperar o buscar un sistema iks
Mexico City, D.F.
Mexico
Post Number: 1209
Joshua:
Como dice José Luis, no hay nada en DN ni BEV para tu caja, pero por qué no pruebas como FTA? Te lo recomiendo mucho, ya que hay muchos canales libres, solamente es cosa de buscarle.
No nos quedemos con la idea de que si no hay ND o BEV no hay nada que ver.
SEAMOS CREATIVOS POR FAVOR.
Saludos
Mexico City, D.F.
Mexico
Post Number: 1210
Fred:
Tendrás un número telefónico donde te pueda contactar?
Necesito que me ayudes con un problema que tengo sobre la Solaris.
Saludos
Username: Nikk_mty
Post Number: 100
Como lo posteo Emilio mas arriba, hay alrededor de 5 a 7 canales que no estan codificados y que se pueden ver en cualquier receiver...
Pueden usar el Channel master para crear una lista de canales en el sat 110 o Echo 8.1, manualmente agregan un TP con frec 12486, polaridad vertical, 20.000 Msps, luego agregan uno por uno manualmente los canales:
V6946
A6947
P6946
V4130
A4131
P4130
V6434
A6435
P6434
V6690
A6691
P6690
V6178
A6179
P6178
Luego esa lista se la bajan a su receiver
Username: Espartano
Post Number: 74
y que tengo que h@cer para ver FTA? esta antena y equipo me sirven? tengo que cambiar la orientacion de la antena? bajar algun bin especial? en que me puedo apoyar disculpen mi ignorancia
saludos a todos
Username: Tetuscosmicus
Post Number: 513
Espartano...
Lo unico que tienes que aser es ir donde esta tu antena y mover....para esto tienes que estar informado de que sat, vas a vajar..o como dices la orientacion del sat. bin en especial no hay...
talves as leido arriva que bins no hay ...solo
para siertas cajas....yo te recomendaria que leas mas arriba para informarte mas.
haaaaaaaaaaa..te recomiendo las yaves necesarias para tus tornillos de la antena...importante heeeeeeeeeeeee...
Saludos mi amigaso y mucha suerte con los Sat,,
Post Number: 514
Y ablando de amigasos..
Saludos Maestro..que Dios lo cuide
en union de su familia...
y gracias por la lista...............
Username: Lesi
Post Number: 114
buenas tardes y saludos a todos los del foro feliz dia de la independencia a todos
Username: Mcd500
Post Number: 141
senores maestros me pueden
ayudar como agarar la senal las amasonas
en los angeles en cw650 clasic
acaba de salir un bin 179
para las amasonas oalguen espligue
para gue es ese bin grasias
Mexico City, D.F.
Mexico
Post Number: 1211
mario h:
Ese bin es efectivamente para el Amazonas, pero la verdad dudo que puedas captar ese satélite desde tu ubicación, ya que está mucho más hacia el sur su huella. A menos que tengas una antena de entre 2.4 y 3 metros.
Saludos
Mexico City, D.F.
Mexico
Post Number: 1212
Joshua:
Para poder captar señales FTA, vas a necesitar un lnb lineal o universal, y revisar primeramente la página de lyngsat, para que cheques los canales y las huellas de los satélites.
Saludos
Username: Lilfred
MEXICO, D.F.
MEXICO
Post Number: 276
juan carlos
56575641
Username: Oldgreen
Post Number: 206
Aqui está la huella del Amazonas en América del Norte
Username: Oldgreen
Post Number: 207
La huella muestra que es más fuerte la señal en California que en México......
Asi es que adelante Mario H. Busca la antena y el LNB adecuados y agarra ese pájaro.
Oldgreen
Username: Oldgreen
Post Number: 208
La misma huella dada por Lyngsat:
Username: Oldgreen
Post Number: 209
Tamaño de antenas para Amazonas en América del Norte, según Lynsat:
dBW------- Diametro (cm)
48 ------- 60-75
47 ------- 65-85
46 ------- 75-95
45 ------- 85-105
44 ------- 95-120
43 ------- 105-135
42 ------- 120-150
41 ------- 135-170
40 ------- 150-190
Username: Espartano
Post Number: 75
ok, desenme suerte con la pesca de los sats, ahi les comento como me fue. muy agradecido con sus comentarios.
abur!
Username: Juanchg
Post Number: 212
estoy por comprar un nfusion, y quisiera saber cual es el mejor de los diferentes tipos que hay en el mercado.
Saludos cordiales,
Username: Oldgreen
Post Number: 210
Hola a todos nuevamente:
Debo realizar algunas aclaraciones al respecto del Satélite Amazonas 61 grados.
Aunque existe una huella bastante potente en América del Norte, este servicio no emite por ahora ninguna señal de televisión.
Para lograr captar alguna señal de televisión del Amazonas 61 en Norteamérica se requiere una antena entre 2.5 y 3 metros de diámetro. Puesto que las señales de TV emitidas actualmente están enfocadas hacia América del Sur.
Trascribo algo encontrado en otro foro:
"Note: Use the "America" map, NOT the "North America" map. The North America map is meant for future service in the Ku Band. The "telefonica" signal is KU band but meant for Brazil and South America. You can see in the map that it gets ridiculously weak north of there. People in the Caribbean with 10 ft+ dishes manage to get it. The "Beam" column in the frequency chart at Lyngsat tells you which beam (and thus which map) carries what channels, you'll see there's no current North America beam in the Ku band."
Por tanto es bastante complicado lograr algo de señal de este pájaro en América del Norte.
Username: Mcd500
Post Number: 142
olgreen senal encontrada pero
no abre ningun canal estoy usando
pajaro 3metros biejo gue se usaba
antes espero lograr mi objetibo
grasias a todos los maestros
Username: Oldgreen
Post Number: 211
Mexico City, D.F.
Mexico
Post Number: 1213
Oldgreen:
Precisamente a eso me refería. La huella que pusiste es para América del Norte, sí, pero para banda C, no para Ku.
Y sip, también, Telefónica transmite con dos huellas, una para Brasil (que no llega ni siquiera a Guatemala) y otra para América del Sur (que es la que se promueve en el foro).
Cuidado con confundir a los demás. Ah, y no me lo tomes a mal, no es para molestarte.
Saludos
Mexico City, D.F.
Mexico
Post Number: 1214
Para el Amazonas:
En el D.F. se puede bajar con un plato a partir de 1.2 metros, con solamente el 35 a 38 % de canales. Todos los transponders a partir de un plato de 1.8 metros. Solamente deben tener cuidado con el skew del lnb (IMPORTANTÍSIMO).
Mi problema con mi antena de 2 metros es que los soportes no son originales, por lo que lo más seguro es que estén de mal tamaño. Mañana voy a conseguir unos clonados de los originales y haré pruebas nuevamente, para poder reportar resultados.
Saludos
Username: Huizarjchr
Tijuana , Baja califor...
Mexico
Post Number: 12
hola se dice que el viusat se ven 6 o 7 canales y tambien en 650 pansat que estan libres acabo de verlo en otro foro sera cierto llagando a la casa checo en mi c.v 800 sino en clon de panson
Post Number: 2035
Post Number: 2036
MANNY,,,AQUI TE VA,,,,,,,DESPUES DE AGREGAR UN CANAL APRIETA EL ,,, OK ,,, Y DRSPUES EL ,,, F4 ,,,,, Y ASI ASTA QUE TERMINE....BENDICIONES.
Username: Ritchie_betanzos
Montreal, Quebec
Post Number: 62
hola alguien sabes si hay noticias sobre nuevos bins para sonicview 4000 para poder abrir los canales en nagra 3? alguien tiene alguna informacion?
Username: Mdcmdiez
Miami, Fl
Dade
Post Number: 9
Saludos companeros. Por favor alguien me puede decir sin aun nada de nada...tengo mi pansat convertida a puff lezma...Ya existe algo?, que tanto hay que esperar? no veo television desde hace semanas. Por favor me podrian actualizar???
Post Number: 2037
asta el momento no hay nada tendremo que seguir esperando..........saludos jose ricardo,,,, BENDICIONES.
Post Number: 2038
CARLOS M,,,, solamente asta el miomento ahy esta occion,,,,,,con 5 canales free. #1 (permalink) 3rd July 2009, 02:13 AM
musky
ViP Member Join Date: Aug 2007
confirmed by me.
VS ULTRA
Menu and selecting:
Edit channels:
exit and save
VIDEO PID = 6946
PCR PID = 6946
HIT ENTER on remote
Username: Vianche
Montreal, Quebec
Post Number: 1047
buenos dias una pregunta todo eso que dice de buscar el tp y poder ver cartoon sirve para la caja pansat convertida lzma puff puedo hac er eso en mi caja?
Post Number: 2039
CARLOS M,,, SON PARA ESTOS RECIVER QUE SE TESTEARON,,,,,viewsat ultra
pansat 2700 n2
lifetime classic na
co-olsat 5000
vs platium
vs extreme
cw 800
vs ul
cs 6100
Username: Juancho
CANADA
Xx
Post Number: 747
vivian diaz, puedes ver cartoon network en esa caja, se hace asi
Menu--->Installation--->Advance scan--->Choose Exho 8.1/KU en los satellites
110w sat
En Down frequency, entra 12486 o busca este TP' con el remote
Symbol Rate y Polarity, leave como esta (20.000 Msps y Vertical)
ejemplo
Video PID, entra 6946
Audio PID, entra 6947
PCR PID, entra 6946
#151 - V6690 A6691 P6690
#177 - V6946 A6947 P6946 cartoon n
#181 - V4130 A4131 P4130
#233 - V4146 A4147 P4146
#267 - V6690 A6691 P6690
en los pansats cada canal que actives, tienes que ir a canal edite y renombrarlo o de otro modo te cambiara de un canal al otro y no pasara de un solo canal,
Username: Rocas
Humble, Tx
Harris
Post Number: 132
hola a toda la raza perdonen lo ignorante una pregunta ,esto de los canales (escondidos) que cambiando el video etc.y se logran ver podria ser que de alguna manera se pueden ver otros sin tener estas cajas sin n3? otra pregunta para bajar el hispasat ya tengo el plato necesario el lnb tambien ya se que esta a 30:w lo unico que necesito es saber de alguien que ya lo tiene funcionando es si tengo que mover el skew y para donde tomando en referencia a el reloj muchas gracias de antemano.
Username: Pasis
Leon, Guanajuato
Mexico
Post Number: 899
buenas tardes a toda la banda
aqui regreso con mas ignorancia cada vez,y con mas verguenza por tantas mentiras de este partido en el poder y sus maranadas, ademas del miedo q les esta metiendo a la poblacion para q ellos sean los salvadores de la nacion, jajajajajajaja en fin, pasemos a lo nuestro
nikk
oye necesito volver a un convertido lzma a puff y es q quiero usarlo para bajar el amazonas, si m puedes orientar te lo agradeceria y si tienes el fix para bajar el amazonas pues mejor, o si alguno sabe como ha cer lo q necesito les agradeceria su amable colaboracion, es q ya estoy bien aburrido con el megacable, q aun q el sistema m da el internet gratis pues esta muy aburrida su programacion, bueno de ante mano muchas gracias al q conteste
y
aribaaaaaaaaa la razaaaaaaaaaa
Username: Korita
FRANCIA, CA
Post Number: 198
SALUDOS A TODO EL FORO EN GENERAL AL GUIEN MEPODIA CONFIRMAR SILAS NFUSION ESTAN TRABAJANDO SELOS AGRADECERIA MUCHO
Username: Jgg
Houston, Tx
Usa
Post Number: 106
PIMP.......
si estan trabajando las nfusion. cuando menos la solaris, con los pocos canales que se ven. pero estan trabajando.
Username: Mcd500
Post Number: 143
senores maesros me podia cofirmar
si esta trabajando sonic view elite
grasias
Username: Korita
FRANCIA, CA
Post Number: 199
jgg.....
GRACIAS YA LA PUSE A FUNCIONAR
Username: Rescate
VENEZUELA, M...
Post Number: 369
Por ahora solo funciona IKS, todas las demas cajitas, vendanlas o utilicenlas en FTA por el momento, comprense una con IKS (necesita coneccion internet cuando estan viendo tv)
Todas las que estan trabajando con IKS son estas:
nfusion - menos la NOVA
sonicview
kbox
ilink
conaxat
Yo espero recibir mi kbox el lunes proximo o el martes.
Escogi este porque tiene muchos canales latinos y ademas por el buen servicio a los clientes.
Saludos
Post Number: 515
Saludos mi moi...gusto de leerte
cuidate....y cuidado con las cahuamas
jejejeje....mass si es en el techo...
cuidate......
Username: Rocas
Humble, Tx
Harris
Post Number: 133
hola a todos tengo una molestia para cualquier viewsat owner necesito saber el code para una television hitachi ya que yo perdi mi manual del viewsat gracias.
Username: Guillo54
Montreal , P,Q.
Post Number: 50
emilio que bin le pongo a una life time ultra, gracias
Username: Jgg
Houston, Tx
Usa
Post Number: 107
Juan Gonzales......
005. 006. 007. 016. 018. 067. 068. 069. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 119. 123. 124. 143. 151. 161. 171. 179.
esas son para hitachi
espero te sirvan,
saludos......
Username: Rocas
Humble, Tx
Harris
Post Number: 134
jgg muchas gracias ya funciono eres de houston?
Username: Leonazulkrema
CHICAGO, IL
Post Number: 17
ando un poquito fuera de onda por que andube de vacaciones. alguien me podria decir si la pansat 3500 esta trabajando o simplemente no esta trabajando ninguna? estube en mexico por 3 meses y no la he podido arreglar por favor alguien que me pueda orientar. se los agradesco. muchas gracias.
Username: Rober2154
Miami, Fl
Usa
Post Number: 579
Alguien ha testeado las Kbox, aqui en Miami se estan vendiendo, dicen que abrio los latinos y los 300 y PPV....
Post Number: 2040
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,,,,
Username: Dilan
MEXICO
Post Number: 131
saludos a todos los de este foro,,,
reportando,,, desde guadalajara,,decirles que ayer caze este pajaro hispansat 30 w con 49 canales la mayoria latinos y 5 arabes solo tarde en bajarlo una hora aprox..gracias a la alarma sonora con la que cuenta el pansat 2700a muy buena herramienta,,,y una brujula,,saludos antena sky y lnb lineal chaparral,,en gdl el lnb no ocupa screw...
Username: Delgado258376
Monterrey
Post Number: 318
Quien en Monterrey ya pesco el Amazonas, de favor para que me den algún tip.
Username: Vikosolis
Monclova
Mexico
Post Number: 298
buenas tardes! si no sera mucha molestia, kiero bajar el hispasat con mi pansat convertido 2700, pero ke bin necesito y con que tipo de lnb lo puedo captar? de antemano agradezco, saludos
Username: Neox
Tijuana, Baja California
Mexico
Post Number: 403
Antes que nada Buenos dias a todos los F.T.A-migos del foro por el bin comun.
DILAN DELGADO
Una pregunta el LNB que usaste para para el Hispa es el mismo del SKY y en que tipo de lnb configuraste el P2700 universal 1 o 2 o como standar.
De ante mano grasias
Username: Dilan
MEXICO
Post Number: 132
VIKTOR SOLIS
NO NESECITAS NINGUN BIN,,YA QUE LA MAYORIA DE LOS CANALES ESTAN LIBRES,,
EL LNB ES LINEAL STANDAR,,Y CON TU PANSAT SI LO BAJAS
SALUDOS
Username: Dilan
MEXICO
Post Number: 133
NEO X
SI... EFECTIVAMENTE ES EL MISMO DE SKY,
STANDAR...
AQUI EN GDL ME DIO HASTA 84% DE CALIDAD
SALUDOS
Username: Alejandramx
Post Number: 87
Tengo un pansat3500 con una antena dish500 doble lnb , me gustaria saber que satelites podria orientar ?
Username: Jorge125
Mexico, Tonala
Jalisco
Post Number: 32
Saludos al foro
alguien sabe si esta funcionando el pansat 2700
para agarrrar amazonas y si no que codificador me recomendarian, y como utilizan la alarma del pansat 2700 para localizar satelites ya que pues soy novato en esto de tratar de localizar satelites
y cualquier ayuda me seria muy util se los agradeceria mucho
Saludos
Username: Rescate
VENEZUELA, M...
Post Number: 370
Ya me llego el kbox, como prometido por Transat Electronics, lunes 6 de julio, me llego a las 3:30, me preparo para instalarlo.
Continuare informando del resultado del "testing"
Nadie quiere comprar mi nfusion nova???
Cuanto dan... jejeje
Ni los que dicen que tienen fe en nfusion lo quieren comprar
Saludos
Username: Elmoxp
Ottawa, Ontario
Post Number: 300
Que bien muchacho, ahora para los que tienen el Kbox, salen todos los canales Latinos? y bev?
si se puede poner la lista de los canales seria fabuloso, estoy pensando en hacerme de uno, ahora se puede usar como FTA tambien? tiene Sonido Optical para esos canales que no se pueden escuchar?
Gracias
Username: Vikosolis
Monclova
Mexico
Post Number: 299
muchas gracias dilan con ke TP lo puedo encontrar y cual es su ubicacion (del hispasat)??? tengo 2 antenas con las ke captaba los 110 y 119 los LNB kreo ke son de dish americano me sirven esos?
Hermosillo, Sonora
Mexico
Post Number: 930
ESTOY FRITO NI COMPIU NI TV
Username: Rescate
VENEZUELA, M...
Post Number: 371
Ŀa caja es similar a la nfusion las mismas conexiones exepto el puerto ethernet que no tiene, ya que se comunica con el khub.
Ademas tiene la entrada USB.
Ok ya esta instalada, facil de instalar solo cargar tres bines lo cual se hace con la USB que viene incluida, hay un poco de friseo que dura entre 1/2 segundo y 10 segundos pero es muchiiiisimo mejor que nada.!
Creo que para los que vivieron la transision de n1 a n2 que dicen que duro tres meses en negro y ahora que por lo menos dicen que kbox saco canales a las 3 horas, ha habido un gran avance.
Por ahora nfusion nova se queda en su caja, y la pansat solo con cartoon networks.
Saludos
Username: Rocas
Humble, Tx
Harris
Post Number: 136
raza como dijo (kiko) me doy ya probe con pansat,viewsat y nada no agarro calidad para encontrar HISPASAT cualquiera que ya tubo exito podria ser tan amable y poner una grafica de como estan todos los settings please , please no les cuesta nada no sean malos de antemano gracias.
Username: Colarillo
Xxxxxxxxxxxxxxxxxx, Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 93
senores a quien pueda alludarme nesecito agarrar univision solo quuisiera me dijeran a que pajarraco
debo de apuntar,que tamano de plato y que lnb yo nesecito por aca ando ahora en el are de CA USA
DE ANTEMANO SE LOS AGRADESCO
.........................GRACIAS..........................
Post Number: 2041
Username: Vianche
Montreal, Quebec
Post Number: 1048
buenos dias a todos hola juan muchas gracias por tu respuesta pero tengo un problema mas cuando entro a tratar de canbiar el video pid y el audio y el pcr, al lado de cada uno de ellos dice auto y no puedo cambiarlos el control remoto no hac e nada cuando llego a ese punto sera que hay otra manera para que yo pueda agarrar eso canales ya hice todo lo demas ya tengo el tp 12486 pero no puedo continuar cfon la otra parte, hay algo que pueda yo ha cer, perodona que me demoro en contestar no siempre tengo tiempo pero igual muchisimas gracias
Post Number: 2042
vivian... que reciver tiene, porque yo tengo un viewsat extren,,,, y no me salen los canale,,, tambien lo ice en un co-olsat 5000,,,kl y me pasa lo mismo no me salen los canales.
Username: Vianche
Montreal, Quebec
Post Number: 1049
okey ya logre cambiar eso del video el pcr y todos eso meti esos numeros pero no pasa nada sola scan 0chy-a que no se k es es pro no me sale mas dime porfa que hago
Home > Message Board > Home Video > Satellite TV > SOLO HISPANOS--2 > Archive through July 07, 2009 [ « Previous ] [ Next » ]
