Thread: Your Views on Sonicview 360 Elite /iHub |
Bronze Member Username: Hardwarecrazy
Post Number: 66 Registered: Dec-07
| Posted on Saturday, July 04, 2009 - 05:40 am: |
It appears that it is time to drop VS and move on to SV Elite or Premium with iHub, since it is one of the very few that functions in this era of N3. SV also was one of the receivers which required fewer updates during N2, as compared to say VS. Some of you must have jumped to this fta and experienced it. Would you let us know your experience, quality and support for the same? TIA. |
Platinum Member Username: Plymouth
Post Number: 10042 Registered: Jan-08
| Posted on Saturday, July 04, 2009 - 10:56 am: |
It appears that you can keep your VS, SV doesn't have a solution for N3, VS have a solution that is why they doesn't put a IKS solution. In 3 years average VS had the best support of all, VS work on N3 solution since Bev put it in force, SV worked on short time solution. Wait and see!  |
Bronze Member Username: Enough_said
Post Number: 22 Registered: Aug-04
| Posted on Saturday, July 04, 2009 - 11:11 am: |
You should wait. You will be disappointed in the SV I-Hub. It has yet to go a full day without having problems and even when they show it as green, it is still freezing. Keeping the ipcongiguration is also another on going problem. Realizing it is a beta verion things may improve. |
Post Number: 67 Registered: Dec-07
| Posted on Saturday, July 04, 2009 - 05:06 pm: |
Thanks Guys. Nalin, you have anything to say? |
