Thread: Scanning for B*V |
New member Username: Xhounddog66
Post Number: 1 Registered: Aug-08
| Posted on Friday, July 03, 2009 - 03:29 pm: |
Hi, when scanning for B*V what tp do you start with? 12224? I have nfusion phoenix and I am not getting all the channels that are up and was wondering if that was why. I was getting them before. I live in Canada and am aiming at the 91. Any help is appreciated. thnx. |
Platinum Member Username: Nydas
Post Number: 15524 Registered: Jun-06
| Posted on Friday, July 03, 2009 - 03:47 pm: |
You should do a scan using the first TP as 12224. You can also have the full list of TPs added and do a scan all. Look up Lyngsat*com for the list of TPs |
Post Number: 2 Registered: Aug-08
| Posted on Friday, July 03, 2009 - 03:57 pm: |
I will try this. Thanks! |
Post Number: 3 Registered: Aug-08
| Posted on Friday, July 03, 2009 - 05:02 pm: |
Is there anywhere to find which TP goes with each station? I see it on Lyngsat with Sat 119 where channels are listed and it says the TP. Can't find it with Nimiq 91. Thanks! |
Post Number: 15527 Registered: Jun-06
| Posted on Friday, July 03, 2009 - 08:09 pm: |
For 91W http://www.lyngsat*com/packages/bell1.html For 82W http://www.lyngsat*com/packages/bell2.html |
