Thread: RTPi on AMC4 |
New member Username: Sowee
Post Number: 1 Registered: Jul-09
| Posted on Friday, July 03, 2009 - 09:08 am: |
Hi! I installed a bellexpressvu 18" dish with a bsna5-506a LNB. I used dishpointer.com to point it to AMC4 101.0W. I also used a satellite signal tester to adjust the dish. My FTA receiver is a FORTEC Lifetime Classic NA. I first tried the antenna setup option: I've set the satellite AMC4Ku 101W, LNB type 10750 (I've also tried SINGLE-S and U) and went to full power FTA scan. I got like 20 channels but they all are dish promotional channels or channels where I need to order a movie. I even have a channel where it congratulates me for my dish 500. But no RTPi. I then try to add the precise TP freq for RTPi. So I added a new TP 12.033 GHz with symbol rate 3.003 Ms. I wouldn't lock to that. I then went to the manual scan to scan a single channel and tried TP 12.033 GHz w/ SR 3.003Ms: still no lock (or luck, as you see fit . Any idea what I'm doing wrong? Thank you very much! |
Gold Member Username: Riconissan
Post Number: 1624 Registered: Feb-09
| Posted on Friday, July 03, 2009 - 09:40 am: |
I think your dish is too small.  |
Bronze Member Username: Silvermir
Post Number: 90 Registered: Dec-07
| Posted on Friday, July 03, 2009 - 09:47 am: |
30" + dish & a single linear LNB |
Post Number: 2 Registered: Jul-09
| Posted on Friday, July 03, 2009 - 09:48 am: |
I'm wondering if I was on the right satellite (I don't understand how I would get dish network channels on amc4?) Supposing I am on the right satellite, it would make sense to say that I can get channels on vertical polarization with my dish but less channels on horizontal polarization? Then, what is the minimum dish diameter I would need? Thanks again! |
Post Number: 3 Registered: Jul-09
| Posted on Friday, July 03, 2009 - 09:54 am: |
If I get a 30" dish, can I use the same stand as the current dish I have (to avoid to unscrew the current stand from the roof). When you say a single linear LNB, you mean one that has only one coax output? The one I have right now would be a dual linear LNB? (it has two coax outputs) Thanks for your info. |
Platinum Member Username: Plymouth
Post Number: 10021 Registered: Jan-08
| Posted on Friday, July 03, 2009 - 09:57 am: |
Alexandre Horizontal signal is very harder to get, this is why many dish are oval, in regard with your position you can get few TPs with a 18" dish but a 33" will be much better. You must set the skew LNB inclination with your position.
Post Number: 4 Registered: Jul-09
| Posted on Friday, July 03, 2009 - 10:13 am: |
I am at Latitude: 46.8871°, Longitude: -71.1938°, dishpointer recommends a LNB skew of 25d. So I'll check my skew and would you also recommend that I switch my dual linear LNB for a single linear LNB? (I think my current LNB is linear). I am curious: how would you explain I am currently getting dish networks promotional channels? just curiousity... Thanks again guys. |
Post Number: 10024 Registered: Jan-08
| Posted on Friday, July 03, 2009 - 10:19 am: |
Alexandre If you get Dish not encrypted, this is because your LNB is a circular, buy a Linear LNB and try to get AMC4 again.
Post Number: 5 Registered: Jul-09
| Posted on Friday, July 03, 2009 - 10:25 am: |
I'll try that, would you also recommend a single linear or dual would be ok? I guess the signal strenght is split if it's dual? Many thanks  |
Post Number: 10028 Registered: Jan-08
| Posted on Friday, July 03, 2009 - 10:38 am: |
Alexendre On a dual LNB your signal is not split but you have 2 straight LNB in one. The reason is, if you get a horizontal channel you can get a vertical channel on the other, which you can't on single LNB. Dual LNB is need if you want use 2 or more receivers.
