Thread: How to scan channels on K-box |
New member Username: Bestboy
Post Number: 6 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 08:31 pm: |
I just bought a K-Box pro. How do I go about scanning all the channels. I have 110 on one LNB, and 118.8 and 119 on the circular LNB. Do I perform the scan under Dish Setting and do I need to scan individual satellites or do I use auto scan for each individual satellite. There is also blind scan. Do I need to use this? |
Gold Member Username: Saqeeb9000
Post Number: 5729 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 08:44 pm: |
auto scan for 110 while do a blindscan for 118.8 u will get all channels |
Post Number: 7 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 08:48 pm: |
Thanks Sada. I will try that. |
New member Username: Ricocossan
Post: 1608
Post Number: 8 Registered: Jul-09
| Posted on Wednesday, July 01, 2009 - 08:51 pm: |
that wont work bestbuy sada Is trying to screw up your box. |
Post Number: 8 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 08:53 pm: |
Sada, Do I need to scan 119 at all or when doing 118.8 blind scan it will pick up 119. |
Post Number: 9 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 08:55 pm: |
Can somebody tell me what the right procedure is? |
Post Number: 5730 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 09:05 pm: |
bestboy forget this false rico looser, no each dish need's individual scan just use normal scan for 119 use blindscan for 118.8 |
Post Number: 10 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 09:07 pm: |
Thanks Sada. |
Post Number: 5731 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 09:09 pm: |
u are welcome bestboy |
Bronze Member Username: Bestboy
Post Number: 11 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 09:14 pm: |
Sada, Which switch is better SW21 or or Diseq for K-Box? Does one switch give better signal strength compared to other. |
Post Number: 5732 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 09:20 pm: |
diseqc is better, what kind of signals are u getting 65-70% are ok, u will get all channels on 118.8 it also depends on ur dish atleast 33 inch is recommend |
Silver Member Username: Adave
Post Number: 240 Registered: Jun-06
| Posted on Wednesday, July 01, 2009 - 09:30 pm: |
sada i scan the sat . come out like number, channel number and tp number no channel name.I think i did something wrong on scan the sat. Let me know so i can scan one more time. thax |
Post Number: 5733 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 09:39 pm: |
dave make sure auto tp is on under option, are u getting good signals , which sat are u trying to scan? |
Post Number: 241 Registered: Jun-06
| Posted on Wednesday, July 01, 2009 - 10:20 pm: |
yap 110 118.7 and 119 110 and 119 dish 500 and 118.7 with direct tv world dish and bev 91. Next is 129 for hd thax sada |
Post Number: 5734 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 10:32 pm: |
menu, dish settin, 118.8 lnb type single,lng freq 11250, lnb 22 khz off diseqc ..should be the one u are using..change it to 1, 2,3,4 and see the sat name of top should say 118.8 ( i mean both should match).. diseqc 1.1 off leg switch off for 119 the only thing difference is u just need to change lnb type to universal.. for other dishes just used the normal method |
Bronze Member Username: Tikodogg
Post Number: 11 Registered: Feb-08
| Posted on Wednesday, July 01, 2009 - 11:44 pm: |
sweet |
Post Number: 12 Registered: Jun-09
| Posted on Thursday, July 02, 2009 - 09:32 am: |
Sada, On 118.8, my signal strength is as follows: Strength 90 Quality 47 I noticed last night that I was not able to get NDTV during the cloudy and rain, as the picture was craking up. Is the quality of 47% too low and therefore would I need to realign the dish? Please let me know. |
Post Number: 5740 Registered: Oct-07
| Posted on Thursday, July 02, 2009 - 01:27 pm: |
bestbuy i mean boy lol quality is too low, u need to tweak ur dish from outside, easy way to do is to turn on beep for sound under option, then go out and tweak it u will hear difference in sound so u can easily tell if u have good signal without looking at tv.. |
Post Number: 13 Registered: Jun-09
| Posted on Thursday, July 02, 2009 - 01:32 pm: |
Thanks Sada, I will try that. |
