Thread: Kbox plus or Kbox prodigy |
Silver Member Username: Getmo96
Post Number: 134 Registered: Jul-08
| Posted on Tuesday, June 30, 2009 - 06:46 pm: |
Is there any type of wireless networking equipment for either of the two? Also which is preferred? I see that prodigy with Khub costs more than plus with khub. |
Gold Member Username: Saqeeb9000
Post Number: 5706 Registered: Oct-07
| Posted on Tuesday, June 30, 2009 - 06:56 pm: |
both are same, none of them is built with wireless k1plus is replaced with pridelogy, both are equally supported and have same software features, if u can get hands on with plus model, it would be 20-30 dollars cheaper then pro.. u must need to buy khub and k1plus or pro, model in order to watch nagra 3 channels, there is option for standalone which was available during nagra 2 and it will be available once nagra 3 is cracked (if u don't wanna use iks)... but for now until nagra 3 is cracked u must need to use iks in order to watch channels. |
Post Number: 136 Registered: Jul-08
| Posted on Tuesday, June 30, 2009 - 10:44 pm: |
What is the Kbox heros? |
