Home > Message Board > Home Video > Satellite TV > Archive through July 04, 2009 > More movie channels added with k1plus..
Author Thread: More movie channels added with k1plus..
Username: Saqeeb9000
Post Number: 5678
329,330,341,342,343,344,345 and 346.
these channels are available on 110 degree west.
Username: Imars99
Post Number: 252
Thanks for info.
Username: Grnnc
Post Number: 56
Thanks!!!!
Username: Tulipe
Post Number: 22
do u have the list of all channels sada budy :-)
Post Number: 5681
u are welcome guys,
james just posted the complete list,
here u go bro
http://forum.ecoustics.com/bbs/messages/2/577482.html
Username: Grnnc
Post Number: 57
313,318,319,320,321,322,323327,328,332,340,350,351,352,353,354 got just added to the existing list.
Post Number: 5687
wow , awesome news girish,
thanks a lot..
Username: Waqarkhan1971
Post Number: 76
SO whenver new channels add...DO WE HAVE to do anthr scan ?
or these channels are up on existing scanned K1plus
Post Number: 5688
they should be already up, no need to scan ,
waqar ptv global is also up..
Post Number: 77
thanks sada
By the way , I am still unable to get the TP 12033 which has all INDIAN channels.
Pakistani channels are OK and quality 67% with 33 inch dish
I did Factory rest - file 186 and still just PAK channels
Help me Sada. I know u are the best and can get me a solution
Post Number: 5690
waqar what kind of switch are u using?
Post Number: 78
I am not using any switch - direct from lnb to rcvr as all dishes I have removed except 33 inch fo 118.
Post Number: 5691
waqar khan there can be multiple issues with ur setup,
firs of all lets try step by step
go to menu, dish setting,
post all ur setting,
Post Number: 5692
waqar i want u to try all steps, one for all
pls download all this and do step by step as instructed, and pls don't miss any step,
let me know if it still doesn't work
do u have pro or plus?'
Rep Points: 11
hinkey is known to some
Star KBox PROdigy - How-To Setup the KBox PROdigy
Step #1: Extract files from these posts onto a memory stick
http://www.ftabins.net/showthread.php?t=90878
http://www.ftabins.net/showthread.php?t=98879
http://www.ftabins.net/showthread.php?t=96910
Step #2: go to Menu --> Configuration --> System Recovery and select delete all channels, then select factory set. This will ensure that loading works properly.
Step #3: go to Menu --> Utilities --> Data Transfer --> Data Download from USB Storage, then select the factory bin(version 1.76)
Step #4: go to Menu --> Configuration --> System Recovery and select factory set.
Step #5: go to Menu --> Utilities --> Data Transfer --> Data Download from USB Storage, then select the latest bin(version 2.01 at time of writing)
Step #6: go to Menu --> Configuration --> System Recovery and select factory set.
Step #7: Plug the khub into the receiver using the black serial cable, also plug in the power adaptor and the network cable running to your router.
Step #8: go to Menu --> Utilities --> Data Transfer --> Data Download from USB Storage, then select the khub activation bin(khub.rom)
Step #9: go to Menu --> Installation --> Option and make sure all AU options are set to off and Mode is set to Network
Step #10: go to Menu --> Installation --> Dish Settings and configure the satellites you have setup the dishes for then press the red button on each satellite to scan in the channels.
Step #11: go to Menu --> Installation (maybe Configuration?) --> Network and change the mode to DHCP then press the green button on the remote and wait for it to complete
Step #12: Once the previous step has completed turn the receiver off with the remote, then from the back. Wait 30 seconds then turn the unit back on and everything should be working.(everything being all the currently working channels, not necessarily every channel in your list)
P.S. Please let me know if i got anything wrong or if i mislabeled any menu's/menu items.
Post Number: 79
LNB single with 118 and 11708 TP
Username: Maharaja6000
Surrey
Post Number: 30
sada, does 118 comes in vancouver??pl tell
Post Number: 80
Ok I will try . thnx and I will let u know
Post Number: 5694
harchan singh
i think so,
go to www.dishpointer.com
put any vancouver adress and see if u can see it there,
if i was you i would see any "desi" pages, newspaper,
make few calls to installer,
to ask some question, but i am sure its avaialble.
Username: Tulipe
Post Number: 23
SADA something very strange happen . my friend ordered kbox pro from a site nfusion.ca . i tought nfusion has nothing to do with kbox. is it just site used by on line dealer ? or i dont know
Username: Tulipe
Post Number: 24
is it necessary to flash with the factory bin 1.76 before flashing 201.file?
Post Number: 5696
ccc nfusionteam.com, is official site for nfusion, i mean manafacture site,
same as kboxteam.com
is the manafacture site for k1plus,
ask ur freind to go to kboxteam.com
look at authorized dealer and buy it from them
if its already bought that's ok..
Post Number: 5697
ccc, not necssary which model pro?
factory file is not necessary cc,
just download latest file 201,
did u activate ur hub?
that is first thing to do...
Username: Tulipe
Post Number: 25
im still waiting for my box. cuz this nfusion is pissing me off . nothing much to watch.
Post Number: 5698
ccc, hold on , let me download the bin
i will post the results,
Username: Grnnc
Post Number: 58
401,402,403 are up...
Home > Message Board > Home Video > Satellite TV > Archive through July 04, 2009 > More movie channels added with k1plus.. [ « Previous ] [ Next » ]
