Thread: What Channels on Sat 148 up? |
Bronze Member Username: Mailbox4you
Post Number: 22 Registered: Dec-07
| Posted on Monday, June 29, 2009 - 03:19 pm: |
can someone please tell me if satellite 148 is till working fine........I have Captive works 800 which Bin i need??? |
Silver Member Username: Bazuka2020
Post Number: 820 Registered: Oct-05
| Posted on Monday, June 29, 2009 - 03:21 pm: |
None |
Post Number: 23 Registered: Dec-07
| Posted on Monday, June 29, 2009 - 03:23 pm: |
How Come ... I have a friend watching 2 international channels ....are u sure Bazuka |
Gold Member Username: Satgrl
Ðïl Mêïñ ÐårÐ §å Jågå ...
Post Number: 1824 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 03:24 pm: |
on 148 im getting 5 channels SAHARA b4u HT SAMAY AAJTAK on satellite 148 west with a sonicview4000 |
Post Number: 1825 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 03:27 pm: |
here u go MC manually input the PID's and ull get these channels then..hope that helps Aaj Tak tp 12575 vpid 5410 apid 5411 pcr 5410 B4U Movies tp 12224 Vpid 4898 apid 4899 pcr 4898 Headlines Today TP: 12574 20000 v 5/6 Video: 5666 Audio: 5667 Pcr: 5666 Sahara One TP: 12603 20000 v 5/6 Video: 5922 Audio: 5923 Pcr: 5922 Sahara Samay TP: 12574 20000 v 5/6 Video: 6178 Audio: 6179 Pcr: 6178 |
Post Number: 24 Registered: Dec-07
| Posted on Monday, June 29, 2009 - 03:33 pm: |
No Arabic channels , anyone please Thanks satgrl ...... do u have Arabic channels |
Post Number: 1826 Registered: Oct-07
| Posted on Tuesday, June 30, 2009 - 01:56 pm: |
i dont watch arabic channels but im only getting these 5 i deleted all the rest lol....umm i thought u said ur already getting 2 arabic channelS? MC Bronze Member Username: Mailbox4you Post Number: 21 Registered: Dec-07 Posted on Friday, June 26, 2009 - 03:39 pm: -------------------------------------------------------------------------------- so far I got 2 Internationals channels UP ( MAsriya and AbouDabi) without any changes....... I have CAptiveworks 800s ... any one knows????? |
New member Username: Tinku
Post Number: 4 Registered: Mar-09
| Posted on Wednesday, July 01, 2009 - 04:33 pm: |
satgrl, The 5 channels you are getting are encrypted with N2 ? If so, I will try to get them with my Pansat 2700. Please confirm if on N2 ? Thanks |
Post Number: 5 Registered: Mar-09
| Posted on Wednesday, July 01, 2009 - 04:38 pm: |
satgrl, Aaj Tak 20000 V or H ? tp 12575 vpid 5410 apid 5411 pcr 5410 B4U Movies tp 12224 20000 V or H ? Vpid 4898 apid 4899 pcr 4898 -------------------------- Thanks |
Post Number: 1828 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 07:48 pm: |
the are V not H and yes it is N2 |
New member Username: Theone_60626
Post Number: 7 Registered: Jun-09
| Posted on Wednesday, July 01, 2009 - 08:10 pm: |
Do you know which bin is working for the fortec? |
Silver Member Username: Imauser
Post Number: 195 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 08:19 pm: |
I've a same question, which bin is working for fortec (LZMA)? |
Post Number: 7 Registered: Mar-09
| Posted on Thursday, July 02, 2009 - 10:40 am: |
Thanks satgrl for transponder info. I am using Pansat 2700A and can only do: 12224 20000 V. That is, set these 3 parameters only ! Cannot set the remaining: Vpid 4898 apid 4899 pcr 4898 Any idea ? Thanks. |
Platinum Member Username: Nydas
Post Number: 15485 Registered: Jun-06
| Posted on Thursday, July 02, 2009 - 12:51 pm: |
You can set one channels. Scan it. It comes in as CH-A. You then go ahead to rename it in channels edit. Then repeat procedure for the next one. If the TP is missing, you can manually add the TP or modify an existing one. |
Post Number: 8 Registered: Mar-09
| Posted on Thursday, July 02, 2009 - 01:40 pm: |
Nalin, It's good to hear from you. In Installation -> Edit TP/Satellite, I only can change: Down Frequency, Symbol Rate and Polarity. That is also the case for creating a TP. So how can I define VPID, APID and PCR for a Transponder ? Thanks. |
Post Number: 15486 Registered: Jun-06
| Posted on Thursday, July 02, 2009 - 02:28 pm: |
Did you look at advanced scan? Also in Edit Tp you can a dd a TP and then in Advanced scan, you change its Vpid, apid, pcr from Auto to the number you you enter from your remote. |
Post Number: 8 Registered: Jun-09
| Posted on Thursday, July 02, 2009 - 02:30 pm: |
which bin is working for pansat 2700 |
Post Number: 15489 Registered: Jun-06
| Posted on Thursday, July 02, 2009 - 02:42 pm: |
It is BIN 218. At future-fta.info it is mislabelled 214. It is dated 9th June or thereabouts. you can also get it as a 218 from many sites. It is only of limited use now for a few Pakistani channels on 148W still under N2. |
Bronze Member Username: Derrymalton
Post Number: 28 Registered: May-06
| Posted on Thursday, July 02, 2009 - 02:47 pm: |
Hi All, I have CP600P, could any one please suggest about bin#, and what location. I have 2 dish one at 61.5 and other 119. Thanks for help. Derry |
Post Number: 15490 Registered: Jun-06
| Posted on Thursday, July 02, 2009 - 03:07 pm: |
There are no new valid BINs, except that the current BIN will give a few Pakistani channels still under Nagravision 2 if you are pointing to 148W. At Derry Rd in Malton, I am doubtful if you can change the sat direction to get 148W. If you want the current BIN, go to www.currentbins.com |
Post Number: 29 Registered: May-06
| Posted on Thursday, July 02, 2009 - 03:33 pm: |
hi Nalin, I tried to get 148 but no quality.Could you suggest where and how to find exact 148 and what angle please. Thanks, Derry |
Post Number: 15492 Registered: Jun-06
| Posted on Thursday, July 02, 2009 - 03:46 pm: |
http://www.dishpointer.com/ It is not easy to get it in Toronto unless you have a large dish (36") and are lucky with your pointing. |
Post Number: 10 Registered: Mar-09
| Posted on Friday, July 03, 2009 - 12:48 am: |
Thanks Nalin Nyda, you are the man. Advanced Scan has it. I get 148 from Ottawa with 36" dish but slight rain kills the signal. |
New member Username: Jdf
Post Number: 2 Registered: Sep-07
| Posted on Friday, July 03, 2009 - 02:24 am: |
Just remember, in SW Ontario the dish is pointing slightly down towards the ground to hit 148. I get over 85% with a 24", neighbour gets high 70's with an 18". |
Bronze Member Username: Patels_kp
Post Number: 11 Registered: Nov-06
| Posted on Friday, July 03, 2009 - 03:22 pm: |
What about the other local channels on 148. I can get 75% quality and it scans 100 channels but none of them work. I added the above 7 channels with manual PIDs and it worked. Does any body have or know where to find VPID, APID and PCRPID info for local channels or any other channels on 148. this is in ohio thank you |
