Thread: Is kplus worth for N3 |
New member Username: Maya1
Post Number: 1 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 12:54 pm: |
hi, is kplus worth for n3? |
Gold Member Username: Saqeeb9000
Post Number: 5670 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 01:19 pm: |
yes desi grl, grl looks good nick instead of gal all desi channels are up with k1plus... except ptv, qtv, zeesports. |
Silver Member Username: Sjain80
Post Number: 157 Registered: Jun-06
| Posted on Monday, June 29, 2009 - 01:37 pm: |
hey everyone, I am looking for suggestion. is it worth spending money in k1plus. also plz advice which receiver is better to be used now and a good website to buy it from. thanks for the help |
Post Number: 2 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 01:44 pm: |
Thanks Sada for advice, and i changed it to grl from gal, wat i wanna know that , as kplus is connected wth internet, will it be safe to use kplus? B/c one of my cousin in mississauga said that bell can easily catch u if u r using kplus and can send u bill !!!??? |
Post Number: 5672 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 01:49 pm: |
this is peronal stuff i wanna share with u guys.. > hi transat electronic team. > i bought my k1 hero and khub about 1 and half yr ago from local > sattelite shop in > i was quite new to fta at that time and i didn't know about authorized > dealers etc, > my k1hero was upgraded from kboxteam by transat electronics ( i think > was the name of guy).. > my khub is 8001 model and its giving me lots of hiccups , (weather feature ain't working) > contacting kbox team and contacting local dealers there is nothing can > be done here and i was told by kbox team to contact you guys. > i hope you guys will workout something with me. > the other thing is i don't wanna loose tv viewing by sending the khub > so i am willing to buy new khub/ some kind of security deposit , for > time that transat electronics send me new khub and i can send the old > one back > please let me know thanks reply from transat electronic... Hi, Please confirm your shipping address with us and we'll end out a replacement for you. You can send back the older model KHUB next week. Kindest regards, ---- this is what i called support, and the delaer that care about customers even if u are not a customers, and reciever support that is worth it, sada doesn't lies, doesn't tell b.s all simple and truth (which the way it should be)..
Post Number: 3 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 04:45 pm: |
but i still did'nt get my answer though!, thats ok. i m not in a hurry. |
Silver Member Username: Frobi
Post Number: 380 Registered: Aug-06
sada, I have problems with my khub as well. I have to reboot it every hour or so. sometimes when the receiver is OFF, the hub GREEN light stays on instead of turning to red. I am not happy at all. |
Gold Member Username: Oleg1474
Florida
Usa
Post Number: 1285 Registered: Aug-06
| Posted on Monday, June 29, 2009 - 05:01 pm: |
IKS are fta receivers with add ons that allow them to connect to the internet. When doing this you must be connected all the time and there is much more legal issues with going down this route. IKS receivers are boxes like nfusion neosat and kbox. Nfusion has had a lot of legal issues and nfusion nova no longer is supported which has leftmost IKs users unsupported. IKS is not FTA and NO IKS is working on all of nag3 only a very small amount of channels are working on IKS. Some bev and dish channels are working on IKS systems. IKS systems are not as good as standalone fta . IKS has legal issues IP address is exposed IKS does not have NAG3 fix IKS is not100% working or bug free , IKS needs internet plugged into the receiver at all times.Thanks Oleg Ph.D |
Bronze Member Username: Tulipe
Post Number: 19 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 05:05 pm: |
HERE WE GO .. neil this is the kind of problem we wanna know . i wanna ask question . when u change channels is it fast enough or like nfusion u got to wait 5 second |
Florida
Usa
Post Number: 1287 Registered: Aug-06
| Posted on Monday, June 29, 2009 - 05:08 pm: |
FTA Site Scams Updated Warning: New T(o)talFTA Website Has Auto Loading Spyware/Virus Now Stay away from t(o)talfta.com it will infect and corrupt your pc.Thanks Oleg Ph.D |
Post Number: 5674 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 05:13 pm: |
desi grl New member Username: Maya1 Post Number: 2 Registered: Jun-09 Posted on Monday, June 29, 2009 - 01:44 pm: Edit Post Thanks Sada for advice, and i changed it to grl from gal, wat i wanna know that , as kplus is connected wth internet, will it be safe to use kplus? B/c one of my cousin in mississauga said that bell can easily catch u if u r using kplus and can send u bill !!!??? iks receivers are quite safe, now all companies are switching to iks, nfusion was first one k1plus then sonicview, captiwe work soon other companies will join them, ccc change change is little bit faster than nfusion, but it still take 4 sec atleast, nothing is perfect in life, if u wanna get everything perfect this goes for every body, then u should get subcription } |
Post Number: 20 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 05:39 pm: |
dont keep saying bla bla subscriptionnn. do u owne iks??????????/ so what u get pffendended. who is talking about perfection ? if this is the case why yopu poeple keep echanging information???????????????. something is wring with you sada. dont deffend the companies jusat answer question if u can . if u can not pass. |
Post Number: 5676 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 05:51 pm: |
ccc u are talking about perfection, u can't wait few sec's for channel to get up, ali wanna see epg to be perfect, if ain't freezing, then u guys are talking about when they are going to get more channels, the thing is u guys are just begging for more, and more, did u try the k1plus? why are u keep asking, just buy it and try it urself.. yes i do own iks, u think nfusion was always perfect , it never had problems, did u forgot it was down for 2 weeks way back, again k1plus team told us this is temporary solution to get until nagra 3 is cracked, and then there will be standalone bin, if u are not buying k1plus, then u should wait, or buy sonicview and expereince freezing buy nfusion phoneix and wait for them to get inter buy conaxsat and let them figure out how does iks works.. buy neosat ipro 2000 and get private subcription for another $ 100. buy a dn rec, buy slinger and then get private subcription,............ there are no of choices out there, none of them are perfect, their are ups and down with all boxes, i am not sure why are u complaining about k1plus tell me the reasons to back ur statement.. |
Gold Member Username: Plymouth
Post Number: 9940 Registered: Jan-08
| Posted on Monday, June 29, 2009 - 06:43 pm: |
Oleg Phd Many sites was hijack by a hacker and give you false site when you try to enter. Read on web and you can see it.
Post Number: 4 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 09:26 pm: |
Thank u sada, i did'nt mean to upset u, just needed to improve my knowledge about fta!!!! |
Post Number: 5679 Registered: Oct-07
| Posted on Monday, June 29, 2009 - 09:56 pm: |
desi grl , buy k1plus or prodiology, u won't regret it.. both are same model, u need to have internet , a router to make it work, if u know about nfusion its similar to nfusion but better, |
