Home > Message Board > Home Video > Satellite TV > Archive through July 04, 2009 > Connect Cable TV through SV 8000 Rece...
Author Thread: Connect Cable TV through SV 8000 Receiver?
Username: Varius
Post Number: 35
Hi all,
I was wondering if it's possible to connect my regular cable tv (coaxial) through my SV 8000 receiver? I tried sticking it in the RF IN but doesn't seem to be any way to watch it.
Any thoughts?
Username: Shenanigans
Post Number: 90
connect it to 'antenna in'. then connect 'tv out' to your tv set. it will work then.
Username: Plymouth
Post Number: 9931
Like Shenanigans says hook your coaxial out from receiver in TV coaxial, the receiver doesn' t convert RF signal to Video signal.
Username: Varius
Post Number: 36
Shenanigans:
By antenna in, do you mean UHF in? On my receiver all I have is RF in, UHF in and LNB in.
Basically, here is my situation:
I have a HD Projector setup. I also have a HDMI switch with multiple HDMI inputs. My satellite receiver, PS3 and DVD are all connected to it by HDMI, everything works great.
I have cable tv I'd also like to be able to watch when needed; all I have is the cable, no cable box. Regardless, my cable company doesn't have HD boxes with HDMI output yet so wouldn't matter.
I'm trying to put the cable in to my SV 8000 HD so it will be output to the HDMI switch and thus, the Projector.
Is this at all possible ?
Alternatively, could I get some kind of coaxial-to-hdmi switch/adaptor to use for my situation?
Username: Plymouth
Post Number: 9935
Keith
You must use the input RF for the cable provider.
UHF/VHF is RF.
The receiver can't convert RF to HDMI
Put the cable in RF input of your HD projector(if available) or use a old VCR for selected channels and use S-Video or video out.
Username: Varius
Post Number: 37
Plymouth,
Yeah I guess I will need to pickup an old VCR - my projector doesn't have an RF input, only has HDMI, S-Video and Component inputs.
Username: Plymouth
Post Number: 9936
Keith
I don't see any other solution, VCR or DVD recorder with built-in tuner sold in Walt-Mart store for 100$ or less.
Post Number: 91
If you buy a dvd recorder with a QAM tuner it will pass through any unencrypted channels (including HD channels in HD) on your cable system. This possibly includes some channels you cannot even receive with the digital cable box.
Home > Message Board > Home Video > Satellite TV > Archive through July 04, 2009 > Connect Cable TV through SV 8000 Rece... [ « Previous ] [ Next » ]
