Thread: Kbox freezing |
New member Username: Great2009
Post Number: 1 Registered: Jun-09
| Posted on Monday, June 22, 2009 - 11:28 am: |
Kbox is freezing from today morning. Is anybody has same problem and why. any new file |
Gold Member Username: Saqeeb9000
Post Number: 5487 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 11:30 am: |
yep sam, i wonder how many people switched to kbox in last few days.. rumors are that they are adding more channels... |
Bronze Member Username: Topy
Post Number: 66 Registered: Jan-07
| Posted on Monday, June 22, 2009 - 11:37 am: |
They should add channels without interuption, isn't ? |
Post Number: 67 Registered: Jan-07
| Posted on Monday, June 22, 2009 - 11:40 am: |
looks like kbox down after lots of freezing |
Post Number: 5490 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 12:39 pm: |
back up now |
Bronze Member Username: Dj_prince
Post Number: 35 Registered: Feb-08
| Posted on Monday, June 22, 2009 - 12:43 pm: |
yea all channels are backing up one by one slowly slowly |
Bronze Member Username: Dxv1988
MA
Post Number: 77 Registered: Feb-06
| Posted on Monday, June 22, 2009 - 01:04 pm: |
Where can I learn how to use KBOX? |
Post Number: 69 Registered: Jan-07
| Posted on Monday, June 22, 2009 - 01:10 pm: |
Ask Sada.com,,, lol he is my fav |
Bronze Member Username: Waqarkhan1971
Post Number: 63 Registered: Mar-09
| Posted on Monday, June 22, 2009 - 01:22 pm: |
a quick question please ? I have K1 pro digy now and not getting GEO NEWS and AAG TV with TP 11806 R adn freq 20000 with FEC 7/8 I am not able to get signal. I tried puttinng it as manual add but still not working. In this K1 pro digy I cnt find where to put FEC ? |
Post Number: 5493 Registered: Oct-07
lol Rk. david did u just buy the rec? let me know if u need any help.. |
Post Number: 64 Registered: Mar-09
| Posted on Monday, June 22, 2009 - 02:17 pm: |
a quick question please ? I have K1 pro digy now and not getting GEO NEWS and AAG TV with TP 11806 R adn freq 20000 with FEC 7/8 I am not able to get signal. I tried puttinng it as manual add but still not working. In this K1 pro digy I cnt find where to put FEC ? Someone please help thnks |
Post Number: 5494 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 02:48 pm: |
menu ,inst, mannual scan sat name 118.8 freq if it is already there first check it if its not then add tp by pressing green button symobol rate is 20000 pol h or ver where u will get signals is the one u use search type all channels network san on now if u say both level and quality waqar then u shouldn't have any problem scanning it\ but if u don't have signal i already told you waqar then there is problem with ur dish, ur dish is not rec good singnals because of not big enought or if its slightly moved.. |
Post Number: 65 Registered: Mar-09
| Posted on Monday, June 22, 2009 - 03:22 pm: |
thanks sada, I think the other channels I am getting but this prob needs better signals. currently I am getting 50-51% I think thats the issue |
Post Number: 36 Registered: Feb-08
| Posted on Monday, June 22, 2009 - 04:44 pm: |
so is kbox up fully? |
MA
Post Number: 78 Registered: Feb-06
| Posted on Monday, June 22, 2009 - 04:46 pm: |
Hello Sada, I have a Viewsat Ultra but its not working. I'm thinking to buy a working receiver. Please advise which one? I just want a couples kid channels for my children. Thank you in advance. |
Post Number: 5498 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 05:17 pm: |
david where is ur dish pointed at? which degrees sat? |
Silver Member Username: Snagovac
Post Number: 132 Registered: Nov-06
| Posted on Monday, June 22, 2009 - 08:14 pm: |
hello want to buy KBOX K1 prodigy gave should still buy something with it or not ate can watch DN with this reseivers |
Post Number: 37 Registered: Feb-08
| Posted on Monday, June 22, 2009 - 11:36 pm: |
anyone getting indian channels on kbox? i have connected the black cable from khub to the kbox and getting the green light but when i connect the cream color serial cable i dont get the green light instead gets solid orange light, am i using the right color,? before i use to get the channel with the black wire |
Post Number: 5504 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 11:37 pm: |
Dj why don't u use black cable? |
Post Number: 38 Registered: Feb-08
| Posted on Monday, June 22, 2009 - 11:40 pm: |
i am using black cable now and then khub has green light but no single indian or pakistani channel ,  |
Post Number: 5505 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 11:52 pm: |
menu, int, network connection what does it says if it says "ok" then it should be fine if it says module not connected reboot the khub make sure u have latest file, latest file is 200 also under setting it should be network, no standalone.. |
Post Number: 39 Registered: Feb-08
| Posted on Monday, June 22, 2009 - 11:53 pm: |
i have the latest file 200 it says connection ok its on network not stand alone |
Post Number: 5506 Registered: Oct-07
| Posted on Monday, June 22, 2009 - 11:55 pm: |
i think u have 118.8 dish right? can u check level and quality on the dish, just check under dish setting.. |
Post Number: 40 Registered: Feb-08
| Posted on Monday, June 22, 2009 - 11:57 pm: |
yes its 75 to 80 percent its 33inch 118W, all channels were coming yesterday |
Post Number: 5507 Registered: Oct-07
| Posted on Tuesday, June 23, 2009 - 12:01 am: |
Dj all hindi channels are working fine here, just watching dhamal on zee cinema. one thing u can do is that reload the bin 200 again,after downloading u have to change the mode to network, and see if that helps, |
Post Number: 41 Registered: Feb-08
| Posted on Tuesday, June 23, 2009 - 12:04 am: |
ok nvm sada dish was moved due to wind i got it working thx for the hint much appreciated  |
Post Number: 5509 Registered: Oct-07
| Posted on Tuesday, June 23, 2009 - 12:11 am: |
np , level is always up, its just quality under setting that matter, glad that u got it working.. |
Bronze Member Username: Brampton_on
Post Number: 26 Registered: Nov-06
| Posted on Tuesday, June 23, 2009 - 04:51 am: |
i think black cable is for activating the hub only it is not full 9 pin null, maybe has only some pin connections just enough to load activation files to hub white/grey cable is the regular null cable sada is the aytullah for kbox info verdict is awaited |
MA
Post Number: 79 Registered: Feb-06
| Posted on Tuesday, June 23, 2009 - 09:58 am: |
Hello Sada, I'm using 110 & 119.degrees. According to your previous posts, I may have to buy 33" dish and point to 118 degree right? what about bin file? How can I get N3? Thank you in advance. |
Post Number: 5513 Registered: Oct-07
| Posted on Tuesday, June 23, 2009 - 12:07 pm: |
sam yeo black cable is for activation/ loading the files if u don't have usb grey is for khb, b.w wen i bought the rec few yrs ago it only came with grey cable which i tested for using hub and loading and it worked fine, david yes u need to get atleast 33 inch dish to get 118.8 and special lnb . dowload the latest bin 200, u need to buy a khub , and k1plus, u need to have an internet connection and router,plug in ur network cable from ur router to kbox and enjoy dn international nagra 3 channels.. |
Bronze Member Username: Tausif
Post Number: 65 Registered: Jul-07
| Posted on Tuesday, June 23, 2009 - 12:19 pm: |
This site is claiming to have N3 for all boxes but asking for $99.00 for lifetime membership. Are they right in their claim or it is just a scam? Your thoughts please. www.ftarelease.com |
Post Number: 5516 Registered: Oct-07
| Posted on Tuesday, June 23, 2009 - 12:51 pm: |
scam total scam............. |
Post Number: 66 Registered: Mar-09
| Posted on Tuesday, June 23, 2009 - 01:21 pm: |
Anyone experiencing any problem with QTV, PTV Just showing PLEASE WAIT CONNECTING since last night.. Rest of channels are OK |
Post Number: 5517 Registered: Oct-07
| Posted on Tuesday, June 23, 2009 - 01:26 pm: |
waqar those channels are down, they will be up when coder's feels like that those channels to be up, there is nothing u can do about it.. |
MA
Post Number: 80 Registered: Feb-06
| Posted on Tuesday, June 23, 2009 - 02:16 pm: |
Hello Sada, What one is special lnb? Do you have a name & model? Did you mean satellite 117.7W Anik F3 ? Please tell me where to get the N3 bin? Sorry for too many questions. Thanks. |
Post Number: 5524 Registered: Oct-07
| Posted on Tuesday, June 23, 2009 - 02:26 pm: |
david to catch 118.8 u need 33 inch and circular lnb, sat 148.110,,61.5 all use linear, ask any sat dealer or where u buying it from they will tell u about circular lnb, just ask for special lnb for 118.8 i will post the link .. www.dssrookie.com ( there is no nagra 3 bin),its workaround , channels are up through iks, innovative key sharing, ur box is connected to internet and coders get subcription to those channel and send it throught card share, www.dssrookie.com is official site for k1plus |
Post Number: 28 Registered: Nov-06
| Posted on Tuesday, June 23, 2009 - 03:22 pm: |
david any place that sells lnb's dishes will give you that lnb it is different from the ones that u use for 119, 11o,or 61.5 whole set with 33 dish is selling for around 5o-6o in toronto area only lnb is around 1o bucks some places are selling for 6-7 bucks there is no way around it u have to have these to get 118.8 |
MA
Post Number: 81 Registered: Feb-06
| Posted on Wednesday, June 24, 2009 - 09:23 am: |
Sada and Sam, Thank you very much for your help. I'm not sure that I can do it, but I'll try my best to make it work. Thanks again. David |
Post Number: 84 Registered: Jan-07
| Posted on Wednesday, July 01, 2009 - 01:22 pm: |
Freezing |
Post Number: 5718 Registered: Oct-07
| Posted on Wednesday, July 01, 2009 - 01:34 pm: |
Rk not here..which channels? question for waqar are u able to get all those indian channels u were missing by using the method i mentioned.. david u are welcome.. |
Post Number: 81 Registered: Mar-09
| Posted on Wednesday, July 01, 2009 - 01:36 pm: |
Sada I will be doing it tonight I do appreciate it though salam |
