Home > Message Board > Home Video > Rear Projection TVs > WD 52525 - Purple Static in Dark Images
Author Thread: WD 52525 - Purple Static in Dark Images
Username: Zthorson
I have been ignoring this problem for a few months now since it has not been a high priority, but I figured I would at least check this forum to see if anyone had any ideas on fixes.
Problem:
- On dark images, a purple static is visible. This static used to only be in a ~4" band ~6" in from the left side of the screen.
- The static tend to "pulse". By this I mean that it is not constantly present but seems to disappear and reappear.
- The location and static pattern seems more or less constant.
- The problem is either not present or not visible when the image is brighter
Current Status:
- Relatively new lamp < 5 months, light usages (had one go out)
- Removed and cleaned filter
Current Suspects:
- Could it be caused by dust or particulates on the color wheel?
- Electronics cause?
Does anyone have any idea on a solution or experience with this problem. The TV has worked great other than this problem.
I am perfectly comfortable soldering/resoldering connections on circuit boards if it comes to it.
Thank you
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > WD 52525 - Purple Static in Dark Images [ « Previous ] [ Next » ]
