Thread: SONY RDR-VX525 Please help |
New member Username: Mudpie
LAKE WALES,
FL
United States
Post Number: 1 Registered: Jun-09
| Posted on Wednesday, June 10, 2009 - 02:51 pm: |
I have a sony RDR-VX 525 NO REMOTE FOR THIS i have a sony dvd player with remote RMT-D165A I HAVE A HARMONY ONE REMOTE My sony rdr-vx with no remote is having a issue that I have pushed the wrong button, it is somehow on dv8 and I can not record to DVD now. the dvd remote RMT-D165 A works some on the RDR-VX525 but I can not get into the program/setup screen need help  |
Bronze Member Username: Numan2good
Post Number: 16 Registered: May-09
| Posted on Wednesday, June 10, 2009 - 05:20 pm: |
hello SAUNDRA S so actually the problem is with the RDR-VX 525 or the DVD player? |
LAKE WALES,
FL
United States
Post Number: 2 Registered: Jun-09
| Posted on Wednesday, June 10, 2009 - 05:41 pm: |
I was able to get into program once with the harmony one remote and there i highlighted the dv8 by mistake at this point I have not been able to find the set up program again. Like it is hidden since I screwed up!!! If or when I ever get this figured out I promise not to ever go to program again |
Post Number: 17 Registered: May-09
| Posted on Wednesday, June 10, 2009 - 05:59 pm: |
lolz.... for that you first have to find some solution for your problem... anyways i guess you should each and every button on remote or the set y pressing and see if any button works with this problem.... |
LAKE WALES,
FL
United States
Post Number: 3 Registered: Jun-09
| Posted on Wednesday, June 10, 2009 - 07:14 pm: |
I have pushed every button and then some, and thought about making more buttons to push. Maybe I will just have to purchase the correct remote this harmony one is cool but i am close to throwing it in the lake. |
Post Number: 19 Registered: May-09
| Posted on Thursday, June 11, 2009 - 01:00 pm: |
ah do not throw please in the lake at least just put it under the type of your car:D |
Gold Member Username: Samijubal
Post Number: 4132 Registered: Jul-04
| Posted on Friday, June 12, 2009 - 08:22 pm: |
You need to reset the recorder. Try holding the power on the unit itself for 10 seconds. If it doesn't work contact Sony and ask them how to reset it. |
LAKE WALES,
FL
United States
Post Number: 4 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 07:09 pm: |
bought the remote and still can not figure this one out darn thing is on my nerves |
LAKE WALES,
FL
United States
Post Number: 5 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 10:47 pm: |
called sony had to push enter and then the one to get the remote to work and then that messed up then went to enter and the number 3 now it all works after I was able to get into settings and do a factory reset. Two shots of tequlia for me :-) |
