Home > Message Board > Home Video > Rear Projection TVs > Color Wheel will not ignite ballast o...
Author Thread: Color Wheel will not ignite ballast once placed in housing.
Username: Captchancey
Cape Coral, Florida
My DLP Samsung 67 had a color wheel go out. So I replaced it. Then I replaced the ballast and the lamp. I followed all of Ovadoggva's instructions and bought from the company's he said to. However the colerwheel will only fire up the ballast outside of it's housing. When I place it in the housing it will not fire up the ballast. Please help me with this.
Thank you very much.
Regards,
Capt Ben
Username: Coolpairpl
Ben, I'm trying to test my color wheel out of the housing, is there anything special you had to do to get it to spin?
Cape Coral, Florida
Joe,
Thank you very much for responding. It really means a lot to me. I have had this TV down for 4 months now because I became frustrated with it. Other than mashing down the little lever without the cover I have not done anything different that I know of. I read under OVA's thread where you can check the color wheel that way. It spins it's little heart out when I test it that way. Thanks for the help.
Regards,
Capt Ben
Post Number: 7
Ben, could you tell me where you found OVA's thread on testing it this way?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Color Wheel will not ignite ballast o... [ « Previous ] [ Next » ]
