Home > Message Board > Home Video > TV Basics > Sony KV35V35 dead!
Author Thread: Sony KV35V35 dead!
Username: Kushballz
My Sony KV35V35 (1996 35" CRT) just wouldn't turn on the other day. I already replaced the 2 2SC4834 power transistors and the fusible resistor on the G (power) board, and also the H.O.T. which usually blows along with the others. I also resoldered every component to the board but no success.
When I plug the tv in, the plug makes a small (normal) pop noise, and the power transistors get warm but not hot. The LED on the front of the unit doesn't light up, and the power button/remote has no effect.
Other than what I said above, there are no other indicators that anything else is going on inside. If you have any ideas as to what is going on, please post your answer! Thanks in advance. I greatly appreciate it!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > TV Basics > Sony KV35V35 dead! [ « Previous ] [ Next » ]
