Thread: Connecting PC to 50" Rear Projection LCD Display... Possible? |
New member Username: Drulz
Post Number: 1 Registered: Jun-04
| Posted on Saturday, June 19, 2004 - 03:01 pm: |
While doing research I came across the Sony KF-50WE610 50-IN HDTV Grand Wega™ rear-projection LCD TV... dot pitch is .155 mm or something like that, which is great for computer use I think... (via the DVI) SOoo... I began to wonder if I could use this as a computer monitor as well and was curious to know all of your thoughts... The monitor may have to sit back far away on my desk so it's not ON my face... but other than that... ? Thanks. Jason PS If 50 is too big I can also go with the 42" option...
| Posted on Tuesday, June 22, 2004 - 12:08 pm: |
I think there is a way with the sony but it isn't supported by Sony. I know several other model of LCD rear projection does come with a computer input...Panasonic comes to mind |
New member Username: Georgiag
Post Number: 2 Registered: Aug-04
| Posted on Monday, August 02, 2004 - 09:33 pm: |
I can't find the answer to this question anywhere and I've been searching for days. No one knows. |
New member Username: Cluelesspa
Pittsburgh,
PA
Post Number: 4 Registered: Jul-04
| Posted on Monday, August 02, 2004 - 10:21 pm: |
if it has component in you can use a VGA to component converter (like $100) and it will convert. Thats HDTV Analog... you will be limited to the native resolution of the set which is probably 720P or 1020x720 on your PC or the screen will not line up on the TV. if you have DVI on your computer and DVI on the HDTV you may be able to if the TV supports Digital DVI connect those directly and go digital for HDTV digital. |
Unregistered guest |
| Posted on Saturday, October 02, 2004 - 03:40 pm: |
I recently purchased the Sony 50" LCD projection TV (KF-50WE610). It has a DVI-HDTV video input, but in the manual it states "..is not intended for use with personal computers." I purchased the extended warranty, so Im going to give it a try anyway. I will let you know what happens. |
Schlepp Unregistered guest |
| Posted on Tuesday, October 05, 2004 - 07:14 pm: |
here's the deluge of info I've found about this situation as I'm also trying to get a PC (Notebooks are even harder) to talk to this TV (groan): Massive background here - just read the first couple of pages then go to the solutions in the next link ... http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=321968&perpage=20&high light=1304x734&pagenumber=1 Next link http://www.avsforum.com/avs-vb/showthread.php?postid=3326925#post3326925 and finally, more answers from a fellow named Aborro... http://forum.ecoustics.com/bbs/messages/2/103815.html The skinny version is IF you have a DVI output from a recent Nvidia DVI-D video card output, you can get great picture going into the Sony KF-50WE610 (or 620) TV's, but with some overscan. The problems arise because you have to be able to set your Computer to the same video resolution as the TV's native resolution something like (1386x788). The above links show the mucking around necessary to make this ideal native resolution actually happen. Moral of the story is, this Sony TV is not setup out of the box to allow a PC to be viewed right out of the box. Good luck! |
