Home > Message Board > Home Video > Satellite TV > SOLO HISPANOS--2 > Archive through April 22, 2009
Author Thread: Archive through April 22, 2009
Username: Canada_havana
Post Number: 1871
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,
Post Number: 1872
----EchoStar 7 119.-----EchoStar 8,10 - 110.0W
LNB Power------ON-------------------ON
LNB Type-----Standard-----------Standard Dish Pro change to OCS-DP
LNB Freq---------11250-------------11250
22kHz-------------ON--------- -------Off If you don't have a 22kHz switch both can be off. A DP34 don't work well.
TP Freq----------12224--------------12224 Or one that is close. This TP is just a starting point.
Search option-----All----------------- All
DiSEqC 1.0------Port 1--------------Port 2 This should match the cables on the switch.
Motor-------------Off----------------Off
Legacy SW------None---------------None
This is with the above two
Satellite: any other
LNB Power-------ON
LNB Type-----Standard Dish Pro change to OCS-DP
LNB Freq--------11250
22kHz-------------OFF you can't use a 22kHz switch with more then two Satellites. A DP34 don't work well.
TP Freq----------12224 Or one that is close. This TP is just a starting point.
DiSEqC 1.0------Port 3 This should match the cables on the switch.
Legacy SW------None
THIS IS WHAT MOST SETTINGS ARE. You can start here then change them later.
MENU, OPTIONS
Close Caption---------OFF
Sort by SID------------ON
AUTO TP--------------ON
AUTO ROLL------------ON
EPG Hours-------------12
Full Channel Name-----ON
Installation, Parental Control
Receiver lock------------Off
Menu Lock---------------ON
Information timeout-------3
Maturity Rate-------Unblocked
Change PIN Code--------????
MENU, SYSTEM SETTINGS
System Settings----Letter Box
Screen Type-----------63
Menu Language-------English
Audio Language---- --English
Channel Mode---------Normal
KATIA ,, CHEQUEA QUE TODOS LOS SETTING ESTEN ASI,,,,BENDICIONES.
Post Number: 1873
Howto: Flash Viewsat XTREME
This document is intended to provide a Viewsat VS2000 XTREME owner with a comprehensive set of initial configuration steps. The goal is to have the receiver operational as quickly as possible with the least amount of difficulty.
This document assumes that one or more antennas with appropriate LNB's and any required switches has already been properly installed for receiving one or more satellites. Only settings which are crucial for proper operation are covered.
Once the unit is operational, the user should review the remaining settings and adjust them to suit personal needs or preferences.
Begin by downloading the latest firmware.
http://www.dssfeedback.com/forums/showthread.php?t=15833
The file name will be DBPSW-yyddmmX.ZIP, where yy is the year, mm is the month, and dd is the day.
This file is a ZIP archive containing the actual firmware file which is named DBPSW-yymmddX.PGM.
If you are not using Windows XP or Windows Vista, you will have to use a program such as WinZIP or WinRAR to extract the PGM file to your hard drive.
LOAD the PGM file to your receiver using the VS Loader.
http://www.dssfeedback.com/forums/showpost.php?p=322536&postcount=5
This is the only file you will need.
With the receiver connected to your antenna and television, turn on the main power switch located on the back of the unit. If necessary, press the red power button on the remote control to bring the receiver out of standby mode.
Press the MENU button on the remote control to display the Main Menu. If prompted, enter your PIN code when necessary (default = 0000, master = 3570).
The file will be transferred into the receiver and then written to nonvolatile memory. During this process, I.n.S.t. will be displayed on the receiver.
Do NOT interrupt this operation in any way or your receiver could be damaged permanently.
When the operation is complete, the receiver will automatically reboot. If necessary, press the red power button on the remote control to bring the receiver out of standby mode.
* Select User Setting -> Factory Default. Press OK with Yes selected.
* Select System Information -> Receiver Information. Verify that the Main S/W listed is the same name as the firmware you just installed.
* Select User Setting -> Parental Control. Set Menu Lock to Off.
* Select User Setting -> Time Setting. Set Time Mode to Auto. Set Time Adjustment to the GMT offset for your area (-5:00 for Eastern, -6:00 for Central, -7:00 for Mountain, or -8:00 for Pacific).
* Set Summer Time to Off for Standard Time or On for Daylight Savings Time.
* Select User Setting -> System Settings. Set Local Channel to On. Change Local Channel Region to your city or the closest one listed. Channels in this region will be mapped to their normal local channel numbers.
* Select User Setting -> Option. Set Sort By SID to On. Set Auto TP to On. Set Auto Roll to All. Set Full Channel Name to On.
* Select User Setting -> EPG Setting. Set EPG TP to E:12472 and N:12311.
* Select Installation -> Antenna Setup.
For each satellite to be configured, perform the following steps:
* Set Satellite to the desired satellite.
* Set LNB Power to On.
* Set LNB Type. Legacy Single and Dual LNB's should be set to Standard.
* Legacy Twin and Quad LNB's have their own dedicated types (LNB1 = higher azimuth satellite / LNB2 = lower azimuth satellite). Dish Pro LNB's should be set to OCS-DP.
* Set LNB Freq. to 11250.
* Set 22 KHz. Select Off or On, as appropriate, if a 22 KHz switch is used with this LNB. Otherwise, select Off is no 22 KHz switch is used with this LNB.
* Set TP Freq. to 12224 unless this satellite is EchoStar 7 (119.0W), in which case use 12239 instead. The TP Freq. setting is not saved upon exit. This is normal and will not affect any subsequent operations.
* Set DiSEqC 1.0. If an external DiSEqC switch is being used with this LNB, select the appropriate port number. If this LNB is a DishPro Twin or Quad, select port 1 (higher azimuth satellite) or port 2 (lower azimuth satellite), as appropriate. Otherwise, select None if no DiSEqC switch is used with this LNB.
* Set Motor as required for your installation. If no motor is used, set Motor to Off.
* Set Legacy SW. If this LNB is a Legacy Twin or Quad, select SW42 Dish 1 (higher azimuth satellite) or SW42 Dish 2 (lower azimuth satellite), as appropriate. If using an external Legacy Switch with this LNB, select the appropriate type.
At this point, you should see readings on the signal strength (S) and quality (Q) meters above 50.
You should also see the expected satellite name displayed in the upper right corner of the screen, superimposed on the blue bar to the right of the words "Antenna Setup", and it must match the satellite name to right of the 'Satellite' label in the menu.
If you don't see the proper satellite name displayed or don't have reasonable signal readings, you should not proceed. You may need to reposition your antenna or correct wiring problems.
Repeat the Antenna Setup procedure, as needed, for each additional satellite.
When finished configuring satellites, press Exit and press OK with Yes selected to save your settings.
* Select Installation -> Auto Scan. Set Search option to All and Network Search to On. If you are configured for multiple satellites, press F1, place a check-mark after all configured satellite names, then press Exit.
* Select Scan Start and press OK.
When scanning has completed, press OK with Yes selected to save the results.
Press Exit to leave the Main Menu. Select a strong channel. It may take some time for Auto Roll to complete and the picture and sound to appear. Be patient.
To download the EPG manually, select User Setting -> EPG Setting -> Receive Guide and press OK. The EPG will be continually updated automatically when the receiver is in standby mode (powered off from the remote control).
If the main power switch located on the back of the unit is turned off, the EPG will be lost and must be reloaded.
TIP: you can lessen the load on the processor & memory by deleting unwanted channels.!
ANOTHER GUIDE sent by a member
HOW TO FLASH.
You can flash (load) your receiver with a bin on top of the bin (file) you already have. It will replace it.
Use a Null CABLE RS232 on your receiver from the computer. Or use a Null adaptor from Radio Shack number 26-264B to make a straight through cable a Null cable. Take the cable off going to the LNB to be safe. If you don't have a 9 pin plug on your computer you may need to use a USB to Serial cable 26-183 at Radio Shack with a Null adaptor. If you need a 9 pin mail to mail gender adapter it is item #: 26-231. You will need to install a drive in your computer for the USB cable.
Un-zip all the files and hook up the cable from your computer to the STB, keep the STB off with the switch in the back. Start the loader-2 and click on OPEN FILES. Find the bin file you un-zipped that now ends in PGM. Click on it and it will automatically go on the first line of the loader. Click on the icon just below the word TOOL and check the COM PORT. Then turn STB on from the back and at first light click PC->STB on the loader. If the progress bar don't move after about a minute start over again. Sometimes the timing is critical. Even try turning STB on from the back first then click PC->STB. Don't do anything as the progress bar is going across. Make sure the Computer & STB are done before you go to the next step. They may not get done at the same time. The receiver needs up to one minute to process the data, (DON'T RUSH THIS).
You may need to put a list of Satellites in your STB if you don't have any. Click on OPEN FILES and find the Satellite list you already downloaded and un-zipped. Now do the same thing you did above to flash your STB.
PLUGGING IN CABLE.
Make sure you plug in the cable from the dish to the receiver at the LNB 13/18v INPUT. Not the ANT IN. The cables coming from the dish to the switch should be put on the switch at the same number as you have set in your receiver. "Example", 119 cable goes on number 1 on the diseqc switch and the receiver has #1 for 119 in the program. You can only get one Satellite for each one LNB you have. Two LNB's two Satellites, and so on.
Now you should set your settings. Below is what most have.
MENU, INSTALLATION, then 0000 or 0937 or 2668 or 3570 then ANTENNA SETUP then side arrow to ECHOSTAR 7 119.0W. Then do the same to ECHOSTAR 8,10 110.0W
LNB Power-------ON
Legacy SW------None
MENU, OPTIONS
HOW TO DO A FACTORY DEFAULT
MENU, INSTALLATION
When you do this you will also clean out your channels.
HOW TO SCAN A SATELLITE FOR CHANNELS
You should scan for the channels. Sometimes when you use a channel list the keys or TP auto-roll will not work.
MENU, INSTALLATION, ANTENNA SETUP, then side arrow to Satellite to be scanned. then
The bottom of the screen will tell you to click on F1 or F2 key on the remote to start the scan.
HOW TO ENTER KEYS MANUALLY
In the setup under CODE (the keys) you will find DISH in two places, 00 01 00 and 01 01 00. Change the keys in 01 01 00. The "F' key may be the COLOR button on remote's if you don't have the TEXT button.
1 Menu, 2 Installation, 3 Enter Pin 0000, 4 Code, 5 Nagra, 6 Left until you see Dish or whatever.
Put 00 keys on line 08 & 09 don't change the 08 or 09 number
Put 01 keys on line 88 & 89 don't change the 88 or 89 number
EXIT once then OK to save, the light color is the one you pick to save then EXIT out.
HOW TO SEARCH/EDIT, ANTENNA CONFIGURATION, ADD SATELLITE, RENAME SATELLITE, DELETE SATELLITE.
MENU, INSTALLATION, 0000, SIDE ARROW TO DN OR whatever, then down once to NETWORK SEARCH ON, Then down once to HAMMER ICON then side arrow to what you want to do.
CHANNEL NAME WITH CHANNEL MASTER
When flashing channels to your STB some of the names may change. To correct that do this.
GO to MENU, then OPTIONS and set
"FULL CHANNEL NAMES" to OFF.
Load your CHANNEL.
When done turn FULL CHANNEL NAMES back ON.
ADD A TP
To add a TP go to the channel scan section, select Dish or whatever go down to the green screw driver and hammer icon, hit ok to enter the tp list, then F1 button to add new TP You can also hit the pause button in this section to get a overview of other actions.
HOW TO TURN AUTO-ROLL OFF & ON
MENU,OPTIONS then go to AUTO-ROLL. If there is a problem sometimes getting the keys to auto-roll take the STB off a local channel that may help.
SET GMC TIME
MENU, INSTALLATION, TIME SETTING.
TO SEE WHAT BIN & BOOT YOU HAVE
MENU, INSTALLATION, RECEIVER UPGRA, OK
RESET RECEIVER (HARD BOOT)
Sometimes you need to do a reset, (hard boot). Turn power off then on from the back.
It is a must for users to have tools to get the keys. Below is just to get you started.
KEYMASTER or KEYRIPPER - Will give you keys.
HOW TO CLONE ONE XTREAM TO ANOTHER XTREAM
Connect the Master Xtream (the one with the info) to the wall outlet and TV & have power on from the back of the Xtream.
Connect the second Xtream (the one you want to clone to) to the wall outlet with the power off in the back.
Connect the master and clone receivers together with a null modem cable.
On the master receiver click on MENU, INSTALLATION, RECEIVER UPGRADE, ALL INFORMATION, then OK.
Turn the to be cloned receiver on from the back and the transfer will start.
When the transfer is done it will take about a minute for the clone receiver to process the info. Make sure you give it plenty of time to finish.,,,, PARA KATIA,,, DEJA SABER QUE ANTENA TIENE Y ,,, LNB ,,,,
Username: Gatogt00
Guatemala, Guatemala
Guatemala
Post Number: 193
Muchas gracias Juan Ramirezone por la ayuda solo ingrese el bin cleaner U y listo ahora solo tengo que hacerle un scan pero lo principal es que ya revivio
Username: Gatogt00
Guatemala
Post Number: 194
y para los que preguntan si el viewsat ultra funciona pues dejenme decirles que yo tengo un viewsat y si funciona al 100%
Username: Sergio_verdugo
Hermosillo, Sonora
Mexico
Post Number: 823
Carlos Alonso
HOY EN LA MAÑANA SE VEIA TODO CON EL PANSAT 2700A Y BIN 211 (A EXEPCION DE LOS XXX)
SALUDOS
Username: Nikk_mty
Post Number: 77
Saludos Juan....
Que bueno que las dudas se han ido....
Dejame echar un vistazo a lo que me dices, he andado un poco saturado pero seguro que sentandome una tarde puedo _hacer lo que me sugieres...le dare un vistazo..
Saludos...
Username: Pacha19
Post Number: 238
saludos a todo el foro =)
Username: Danmarino
Post Number: 460
Alguien me podrìa decir què bin "Lzma" està funcionando para los convertidos?. Gracias
Username: Josenh
Post Number: 62
tengo un captive 600p canal revuelto alguin sabe cual bien esta funcionando
Username: Luckas25
Eagle pass, Texas
Usa
Post Number: 130
walter con cual bin esta funcinando tu viesat??
Username: Guillo54
Montreal , P,Q.
Post Number: 41
saludos al foro
Username: Guillo54
Montreal , P,Q.
Post Number: 42
buenas noches a todo el foro
Username: Nikk_mty
Post Number: 78
Dan Marino
Nikk_Mty_Jvvh-Team-PUFF_(Lzma)_V211_V3
Saludos..
Username: Cancinoi
Santo Domingo Este, R D.
Republica Do...
Post Number: 383
Hola a todos!!!
Username: Ivancali
Post Number: 47
señores: navegando en la internet, encontre un website donde tienen posteado los fixed para N3, con suscribsiones de 1 mes, 3mes y un año, sera esto cierto? ftafiles.com.
maestros orientenos...
Username: Juancho
CANADA
Xx
Post Number: 577
ivan z, desde cuando has pagado por los bines? si hay fix este sera posteado gratis igual que cuando map57 del 2006,
esos son estafadores, es como cuando te dicen te vendo un billete de loteria premiado, no creas nada sobre eso,
solo lee y diviertete leyendo,total que en estos tiempos vende arboles que producen dolares. saludos
Username: Ivancali
Post Number: 48
ja ja ja, orale, gracias juan.
Username: Rayadoblue
Post Number: 302
Saludos a toda la Razaaaaaaa
laters
Chepe
Post Number: 303
Rexio Mty puede poner la informacion de como
casar otros pajaros. la distancia de los LNBs (el
diseño de como se mira)
gracias de ante mano
Chepe
Duenas noches Razaaaaaaa
Username: Calonsor
Post Number: 33
Gracias Sergio Verdugo, mi pansat ya funcionado con el bin 211., Saludos
Post Number: 1874
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,
Post Number: 1875
Home
Members
Contact Us
April 17, 2009: Attention members! New N3 fixes have been posted in the forum. Login now to download the latest fix.Help
Contact Us
Privacy statement
Terms & Conditions
FTA Files Support
Welcome to FTA Files. We are your source for the latest premium fixes for all the top FTA receivers. We are pleased to announce our first batch of fixes working on N3 channels on some FTA receivers with more being added over the next few days. FTA Files has established itself as the front runner for providing fixes before any of our competitors. We have dedicated teams working on bringing you the latest fixes 24/7 and will not rest until our customers are happy. Here is a short list of some of the biggest brands that we offer fixes for:
Viewsat - Co-olsat - Pansat - Sonicview - Conaxsat - Captiveworks - Fortec - Nfusion - Neosat - Captain - Buzz - Ariza - Fortec - Kbox - Sonysat - Satopia - Pantec - Cooltec - Extremeview - Skyview
and many more!
All of our fixes are pretested by our teams to ensure you are getting only the best quality codes and no files that could damage your receiver.
We know that when you see the quality and quickness of our fixes that you will be a member of FTA Files for life!
Not only does our service provide you with fixes faster then our competitors, we also offer you:
24/7 technical support.
Software designed for your receiver which can be used for repairs.
Special discounts on dishes, receivers and other accessories from our sponsors.
Instant access to our fixes - no waiting to get onto our forum.
1 Month Subscription 3 Month Subscription 1 Year Subscription Lifetime Subscription
12.99 29.00 69.99 99.99
Subscribe ,,, GRAN MENTIRA ,,, NADA SOBRE NAGRA 3,,,,NO CREAN, LO PUEDEN ESTAFAR,,,,,
Username: Pacha19
Post Number: 239
Hermosillo, Sonora
Mexico
Post Number: 824
HOLA BUEN DIA
HOY ES BEVIERNES
Username: Neox
Tijuana, Baja California
Mexico
Post Number: 351
que dios bendiga este foro
Username: Javy_gza
CENTRO DEL UNIVERSO, HUICHOLES
Post Number: 2116
SALUDOS A LA RAZA TMBN PARA EL
MASTER JUANRAMIREZONE Y COMO NO TMBN PA EL WEN NIKK MTY. SALUDOS
Username: Danmarino
Post Number: 461
Nick Mty: Muy agradecido contigo.. la "cajita" trabajando como Dios manda con tu bin -Nikk_Mty_Jvvh-Team-PUFF_(Lzma)_V211_V3-. Saludos.
Username: Jmendozab
Post Number: 288
Emilio,
Podrias poner la fuente de tu informacion o por lo menos un link para saber si es una broma o es cierto?
Post Number: 1876
la informacion la tome de esta .paage,,,, FTAFILE.COM PARA Javier Mendoza
Username: Garritas
Houston, Texas
Post Number: 106
HOLA AMIGOS DEL FORO BUENAS NOCHES BENDICIONES PARA TODOS TENGO UNA PREGUNTA QUE TAL FUNCIONA UNA CAJA LLAMADA INFUSION SOLARI POR QUE ME LA ESTAN OFRECIENDO QUE MUY BUENA QUE NO SE CAE LA SENAL Y ESTAN ALGO ECONOMICA PODRIAN ORIENTARME SELOS AGRADESERIA
Username: Jmendozab
Post Number: 289
Emilio,
Es una trampa para que contrates su servicio!!!
Username: Rossyjess
Post Number: 636
Ecm la nfusion es buena pero hay que esperar ya que viene el apagon y no sabemos si las cosas ban a seguir funcionando como prometen, ese es mi modesto consejo
Post Number: 1877
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,
Post Number: 1878
"El que no ama, no ha conocido a Dios; porque Dios es amor. En esto se mostró el amor de Dios para con nosotros, en que Dios envió a su H-ijo unigénito al mundo, para que vivamos por él. En esto consiste el amor: no en que nosotros hayamos amado a Dios, sino en que él nos amó a nosotros, y envió a su H-ijo en propiciación por nuestros pecados"1 Juan 4}
Post Number: 1879
La creación
1 Dios, en el principio,
creó los cielos y la tierra.
2 La tierra era un caos total,
las tinieblas cubrían el abismo,
y el Espíritu[a] de Dios iba y venía
sobre la superficie de las aguas.
3 Y dijo Dios: «¡Que exista la luz!»
Y la luz llegó a existir.
4 Dios consideró que la luz era buena
y la separó de las tinieblas.
5 A la luz la llamó «día»,
y a las tinieblas, «noche».
Y vino la noche, y llegó la mañana:
ése fue el primer día.
6 Y dijo Dios: «¡Que exista el firmamento
en medio de las aguas, y que las separe!»
7 Y así sucedió: Dios hizo el firmamento
y separó las aguas que están abajo,
de las aguas que están arriba.
8 Al firmamento Dios lo llamó «cielo».
ése fue el segundo día.
9 Y dijo Dios: «¡Que las aguas debajo del cielo
se reúnan en un solo lugar,
y que aparezca lo seco!»
Y así sucedió.10 A lo seco Dios lo llamó «tierra»,
y al conjunto de aguas lo llamó «mar».
Y Dios consideró que esto era bueno.
11 Y dijo Dios: «¡Que haya vegetación sobre la tierra;
que ésta produzca hierbas que den semilla,
y árboles que den su fruto con semilla,
todos según su especie!»
Y así sucedió.12 Comenzó a brotar la vegetación:
hierbas que dan semilla,
y árboles que dan su fruto con semilla,
todos según su especie.
13 Y vino la noche, y llegó la mañana:
ése fue el tercer día.
14 Y dijo Dios: «¡Que haya luces en el firmamento
que separen el día de la noche;
que sirvan como señales de las estaciones,
de los días y de los años,
15 y que brillen en el firmamento
para iluminar la tierra!»
Y sucedió así.16 Dios hizo los dos grandes astros:
el astro mayor para gobernar el día,
y el menor para gobernar la noche.
También hizo las estrellas.
17 Dios colocó en el firmamento
los astros para alumbrar la tierra.
18 Los hizo para gobernar el día y la noche,
y para separar la luz de las tinieblas.
19 Y vino la noche, y llegó la mañana:
ése fue el cuarto día.
20 Y dijo Dios: «¡Que rebosen de seres vivientes las aguas,
y que vuelen las aves sobre la tierra
a lo largo del firmamento!»
21 Y creó Dios los grandes animales marinos,
y todos los seres vivientes
que se mueven y pululan en las aguas
y todas las aves,
según su especie.
Y Dios consideró que esto era bueno,
22 y los bendijo con estas palabras:
«Sean fructíferos y multiplíquense;
llenen las aguas de los mares.
¡Que las aves se multipliquen sobre la tierra!»
23 Y vino la noche, y llegó la mañana:
ése fue el quinto día.
24 Y dijo Dios: «¡Que produzca la tierra seres vivientes:
animales domésticos, animales salvajes,
y reptiles, según su especie!»
Y sucedió así.25 Dios hizo los animales domésticos,
los animales salvajes, y todos los reptiles,
según su especie.
26 y dijo: «Hagamos al *ser humano
a nuestra imagen y semejanza.
Que tenga dominio sobre los peces del mar,
y sobre las aves del cielo;
sobre los animales domésticos,
sobre los animales salvajes,[b]
y sobre todos los reptiles
que se arrastran por el suelo.»
27 Y Dios creó al ser humano a su imagen;
lo creó a imagen de Dios.
*Hombre y mujer los creó,
28 y los bendijo con estas palabras:
llenen la tierra y sométanla;
dominen a los peces del mar y a las aves del cielo,
y a todos los reptiles que se arrastran por el suelo.»
29 También les dijo: «Yo les doy de la tierra
todas las plantas que producen semilla
y todos los árboles que dan fruto con semilla;
todo esto les servirá de alimento.
30 Y doy la hierba verde como alimento
a todas las fieras de la tierra,
a todas las aves del cielo
y a todos los seres vivientes
que se arrastran por la tierra.»
Y así sucedió.31 Dios miró todo lo que había hecho,
y consideró que era muy bueno.
ése fue el sexto día. muchas bendiciones , que DIOS ME LOS BENDIGA EN GRANDE,,, EMILIO.....
Username: Lilfred
MEXICO, D.F.
MEXICO
Post Number: 241
HOLA FORO BUENOS DIAS, ME PODRIAN DECIR EN QUE OTRO CANAL SE VERA LA PALEA DE DONAIRWE VS MARTINEZ. LA PAG DE @ISH DICE Q EN EL 457 Y 471 PERO ESOS CANALES YA NO LOS VEMOS, ALGUIEN SABE POR QUE OTRO?
Post Number: 1880
FRED OLAVARRIA ,,, 455 y 473,,,,,
Username: Lilfred
MEXICO, D.F.
MEXICO
Post Number: 242
hola EMILIO, en esos canales esta proggramado el de UFC
Username: Miguel3000
Post Number: 356
Emilio Vento
Hazte un favor,ya no leas la Biblia.
La Biblia es el libro mas lleno de contradicciones y lleno de errores que ningun otro libro.
Saludos>
Post Number: 1881
MC,,, gracias lo tendre en cuenta... pero mientra tanto te deseo muchas bendiciones,,,
Username: Lucia
Calgary, AB
Post Number: 700
alguien sabe si los canales Azteca America y Univision sirven ahorita en el PUFF LZMA?
Username: Lucia
Calgary, AB
Post Number: 701
y si lo tengo que poner autoroll ON en dishnetwork
Username: Mrrasec
Post Number: 1340
fred, el 457 tiene ese evento y se ve en las convertidas, porque no lo ves?
Username: Mrrasec
Post Number: 1341
lucia 825 y 827 son esos canales y trabajan en convertidas!
Username: Lucia
Calgary, AB
Post Number: 702
gracias Savoy
Username: Lilfred
MEXICO, D.F.
MEXICO
Post Number: 243
no veo el 457 por q estoy en el d.f. y no tengo el sat 110 .
Username: Lilfred
MEXICO, D.F.
MEXICO
Post Number: 245
Username: Lilfred
MEXICO, D.F.
MEXICO
Post Number: 247
como veo el 457 en mi vs ultra lite quiero ver el box no sean malos
Username: Jmendozab
Post Number: 290
Fred, necesitas una antena de 2.4mts para agarrar el 110.
Yo estoy viendo la pelea ahora mismo en el DF.
Saludos.
Username: Jmendozab
Post Number: 291
Fred, no te perdiste de mucho, en el $to Round le KO y gano por paliza el filipino
Post Number: 1882
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,,,,,,}}
Username: Luquemario
Montreal, Quebec,canada
Post Number: 72
buenos dias estoy con un pansat 2500 que le cargo el bin 211-v3 pero dice puff y sigue roleando y no carga , es que debo acer alguna configuracion o meter algun programa?
gracias
Username: Juancho
CANADA
Xx
Post Number: 578
muchos de estos reciver tienen que clic download antes de que aparezcan las luces, enciende el reciver con el switch de atras y clic donwload, tratalo hasta que veas la linea verde empezar
Username: Nikk_mty
Post Number: 79
Lo prometido es deuda....
Aqui les dejo el file Full JTag para clones del 2700..
ojo, no es para convertidos es para clones de 2700....
Full_JTAG_2700_Clone_211
Saludos Juan...
Saludos a todos los demas...
Nikk
Username: Oijaz
Post Number: 179
Saludos Amigos
Alguien me puede decir como tener algun canal en High Definition en espanol} que no sea "HBO Latino HD"; porque ese es el unico que tengo con mi antena dish 1000.
Gracias
Username: Cancinoi
Republica Do...
Post Number: 384
hola
Username: Chilo
Post Number: 118
hola alguien sabe si el ariza extreme
se pude convertir en clon de otro
Username: Irvingoruiz
Post Number: 92
Hola a todos ...pregunta: alguien tiene problemas con el autoroll del ultimo bin 211-v3 para pansat convertidas..???
Username: Juancho
CANADA
Xx
Post Number: 579
Gracias Nikk,
muchos te lo agradeceran, hay muchos de estos sin jtag, y serviran para FTA o amazonas, tienen muy buena senial en los tp.continua con el buen trabajo,
irving ruiz, pon todos los A/R en OFF.
los pansats clones y convertidos rolean las keys asi.no problemas aqui con el nikk mty 211 v3
Username: Nikk_mty
Post Number: 80
Saludos Juan....
Me tarde un poco y tuve que dejar de lado las formas sugeridas por Jvvh
y buscar mi propio camino, estuve intentando de diversas formas usando esas sugerencias
y terminaba siempre en una pared, aunque logre encender el 2700 con el boot y el bin de Lzma,
pero despues habia problemas con el control de los LNB...
por eso opte por buscar otros caminos menos complicados...
Gracias a ti Juan por todo tu apoyo...
Saludos
Username: Guillo54
Montreal , P,Q.
Post Number: 43
hola a el foro tengo el problemita de que no puedo cargar el bin v211_3.bin en mi fortec ultra estoy usando el loader 1.4.0.0 de blacklist y tambien el ukronic`s y tampeor podria alguien decirme que puede ser? de antemano muchas gracias
Username: Jmanueluna
Los mochis, Sinaloa
Mexico
mc por muy silver member que seas no tienes derecho de hablar tarugadas y menos habiendo miles de personas cultas y estudiadas que han dicho que la biblia es un libro inspirado y perfecto venga un mamarracho e ignorante como tu ha decir esas tarugadas, cuida tu mente no la ensucies.
Username: Elparrandero
Los angeles, Ca
Los angeles
Post Number: 250
saludos ,,atodos y reportando que nfucion solaris ,,al 100%,,a esepcion de los porkis,,y captivw eor 600 premium ,,todo bien ,,asta pronto
Username: Calin
Post Number: 101
Nikk_Mty: podria postear ese Full Dump para los clones del 2700 en algun otro lugar en donde no haya necesidad de registrarse??? Por favor.
Post Number: 93
Juan Ramirezone gracias por el consejo ya mismo lo hago...
Username: Marioandres
Post Number: 248
buenos dias amigos
alguien me puede decir que debo acer para conectar tres recividores a un lnb banda c que solo tiene una sola salida cual elemento debo aderir para poder conectar los recividores
gracias saludos
Post Number: 1883
Username: Luispansat
Irapuato, Guanajuato
Mexico
Post Number: 85
\green que tal. como estan todos y todas. en este comienzo de semana. espero que bien. tengo una { SKY } = { LNB } = { 10500 } = { 2700 a } tome algunos canales { ADTH } ¿ como puedo abrirlos ? { keys } o { archivos } = gracias y saludos desde la capital de las fresas. pd : satmex { 6 } = { iter nacionales }}
Username: Spifff
Saludos a Todos}
Hermosillo, Sonora
Mexico
Post Number: 825
stunt rock
el 2700a trabaja con el bin 211 claro sin los xxx
Username: Oijaz
Post Number: 180
Saludos Amigos
Alguien me puede decir como tener algun canal en High Definition en español que no sea "HBO Latino HD"; porque ese es el unico que tengo con mi antena dish 1000.
Gracias
Username: Fletes
Montreal, Quebec
Post Number: 22
Hola! a todos alguien me puede informar si los puff estan functionales ya que yo no tengo senal la perdi hace unas dos horas atras.
Post Number: 357
JACITON MANUEL COTA CASTRO
Para enpezar tienes un nombre tan enredado y sin ton ni son..tal y como esta tu mente.
Por basarte tanto en la biblia y defenderla tan erroneamente...tus pensamientos los tienes nublados.
Supuestamente por quien o en quien fue inspirado la biblia?
Perfecta?? la biblia??
Vamos..no seas tan fanatico ..no seas seguidor....piensa por ti mismo.
Quien te asegura que tienes la razon al defender ese libro tan lleno de contradicciones?
Por gente como tu....las religiones nunca han servido para nada..solo para causar terror y atrazar a la humanidad en muchso aspectos..
saludos..Mr fanatico.
Mexico
Post Number: 86
que tal. como estan todos y todas. alguien me podria dar ayuda. resulta que ayer en la noche hubo mal tiempo. hoy no tenia signal que pasaria es el { LNB por favor ayuda. gracias y saludos desde la capital de las fresas}}
Post Number: 249
jacinto manuel cota castro
este es un chat de fta y de fta arreglados vete con tu cosmo vison a otro lugar y mejor dime que debo acer para conectar tres recividores a un lnb banda c que solo tiene una sola salida cual elemento debo aderir para poder conectar los recividores
saludos
Username: Eariverag
Guatemala
Post Number: 288
Mario Andres, prueba ir poniendo uno esclavo de otro en la salida repetidora que traen los receptores, etc. etc... y prueba estar cambiando canales en ambos, si no se te congela ninguno eso te serviría, de lo contrario tendrías que usar un multiswitch, 4 * 8 por ejemplo.
Pero para usar un multiswitch necesitarías contar con dos salidas del lnb, ya que de una halaría la polaridad Vertical y de la otra la Horizontal.
Post Number: 1884
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,}}
Hermosillo, Sonora
Mexico
Post Number: 826
AL PARECER PANSAT DOWN
Username: Chicagokid
Antigua
Post Number: 565
SALUDOS AL FORO!!!!
Dpansat
Hermosillo, Sonora
Mexico
Post Number: 827
ALGUIN QUE TENGA ACCESO A DN, TIENEN IMAGEN ???
Hermosillo, Sonora
Mexico
Post Number: 828
ALGUIEN QUE TENGA ACCESO A DN,
TIENEN IMAGEN ???
Username: Tetuscosmicus
Post Number: 461
Saludos amigos...
Sergio..por el momento estoy viendo
univision..si hay imajen..en convertido
a 2700 bin 211..v3 de Nikk.....
Saludos amigo y cuidate mucho...
Hermosillo, Sonora
Mexico
Post Number: 829
OK TKS
NO ESTOY EN CASA AL PARECE ERA CUESTION DE QUE ROLEARAN LAS KEYS
Hermosillo, Sonora
Mexico
Post Number: 830
OK TKS
Mexico
Post Number: 87
que tal como estan todos y todas. tengo 2 antenas { SKY en { 1 = 119 { 2 } = 110 pero como saben el satelite se movio la tenia libre la antena la movi manualmente en esa en contre algunos canales en el formato { ADTH } solo abrieron 4. lo que pasa es que ayer subi a mover la antena y a hora meda los { TP } del { 119 } aun caida la antena que pasaria como puedo tomar los canales que tenia de { ADTH } pues me da los mismos canales del { 119 } alguien me podria dar ayuda. gracias y saludos desde la capital de las fresas.}}
Username: Marlen
Post Number: 167
hola amigos tengo una pregunta simple, he sabido que las atmega 128 estan funcionando, y hasta he cargado una con una amiga, ahora tengo otra amiga que tiene una atmega 128 smart card color verde sin el puente para cargarla, es posible que sirva o esta descontinuada le agradezco cualquier informacion gracias
Username: Cavelar
WOODBRIDGE, ONTARIO
CANADA
Post Number: 1596
Hola a todos///\
Resucitaron los C00LSAT, pero lo mas seguro sera para
dar el ultimo suspiro, NUNCA COMPREN C00LSAT, Saludos...
Post Number: 250
€uro
gracias
saludos
Hermosillo, Sonora
Mexico
Post Number: 831
KATTIA GONZALEZ
TODAS LAS 128 SE PUDEN PROGRAMAR ES CUSTION DE PUENTIARLAS PARA ABRIRLAS DE NUEVO
SALUDOS
Username: Garibaldi
Post Number: 399
Hola raza!!!
Ya hasta me habian sacado de este foro!!!
Username: Garibaldi
Post Number: 400
CARLOS AVELAR
No diga eso compita que al parecer resucitaron de entre los muertos pero no diga que para el ultimo suspiro si no para haber si podemos ver las ultimas xxx....saludos
Username: Loco13
Post Number: 16
Dicen los que saben...
que primero seran los PORKIS...
luegos los LATINOS y los PPV...
y se iran callendo todos...
cuanto tiempo????
no se sabe....
Username: Acostamqz
Juarez, Chihuahua
Mexico
Post Number: 13
Alguien me puede decir por que los PANSAT 2700 ya se ve la senal sin que se vaya como antes? esta raro por que ahora si hay programacion, por favor alguien deme informacion, gracias!!
Post Number: 304
Saludos a toda la Razaaaaaa....
laters
Chepe
Post Number: 1885
Post Number: 1886
CO-OLSAT VOLVIO ALA VIDA, YA ESTA LOS BINES,,,
Mexico
Post Number: 88
que tal como estan todos y todas. alguien me podria dar ayuda con respecto a lo que les decia ayer. { SKY por que no he tenido ninguna respuesta por favo ayuda. gracias y saludos desde la capital de las fresas.}
Username: Acostamqz
Juarez, Chihuahua
Mexico
Post Number: 14
Emilio Vento: en que pagina se encuentran los bines???
Username: Rexio_mty
Post Number: 865
Aqui de regreso, despues de un puentecito ahi nomas tomandome unas coronas en la feria de san marcos ahi anduvimos en la apertura y de paso fui a ver ganar al necaxa , en
aguascalientes.....Huyyyy y que coronas, son unas megacoronas, 2.5 litros Mannnnn
creo que dos coronas ejercitan mas que unas mancuernas del GYM...je, je, je
saludos a la razaaa
Home > Message Board > Home Video > Satellite TV > SOLO HISPANOS--2 > Archive through April 22, 2009 [ « Previous ] [ Next » ]
