Thread: Samsung DLP Light Ballast |
New member Username: Fmolodecki
Billings,
MT
Post Number: 1 Registered: Apr-09
| Posted on Thursday, April 09, 2009 - 10:15 pm: |
After reading all the posts on Samsung DLP's... well I guess misery loves company so here goes. I got a new lamp for my HLR4667W and it does not light up. From the posts, I gather the ballast is possibly the next culprit. Where can I find instructions on replacing or testing the ballast? Thanks |
New member Username: Atracker
Post Number: 6 Registered: Mar-09
| Posted on Friday, April 10, 2009 - 08:51 pm: |
Hi Frank, Here is how to test the Ballast Board, Color Wheel and Fans. If you need further assistance go to my post listed above. Pull the lamp housing Tie the door switch up to the closed position Turn on the TV All Fans should run, Color wheel should spin listen or shine a flashlight in the lamp side window to verify Watch at the left back side of the Ballast board for the starter to flash it will cycle flash three times Pull power cord from back of TV to shut off or it will continue to try the three attempt cycle This will verify the Color Wheel and Ballast board are getting power and most likely your problem is a bad lamp but you should also do a voltage test on the two prong plug on the Ballast board to see if there is 380 volts dc from the power board. |
Billings,
MT
Post Number: 2 Registered: Apr-09
| Posted on Friday, April 10, 2009 - 09:51 pm: |
Thanks atracker. NO DC voltage a interface, colorwheel spins and I already put in a new bulb, so I guess it's the light ballast? The code on the bottom is BP61-00728A. There is a code on one of the PC board components. Brand is Osram code is PT VIP 2AC/380 O1. Which do I use and anything special that I need to do during or after installation? Thanks Frank |
Bronze Member Username: Atracker
Post Number: 11 Registered: Mar-09
| Posted on Friday, April 10, 2009 - 10:20 pm: |
Hi Frank, Did you try the above test? Did you buy a generic or the right lamp for your set? The wattage does make a difference for startup. Can you provide me with your full model number so I can provide you with the right part numbers for your lamp and ballast board. If you will let’s take this over to my topic so I can keep track. I have also added a test for the DMD board there. http://forum.ecoustics.com/bbs/messages/2/555766.html Thanks, Andrew |
