Home > Message Board > Home Video > Rear Projection TVs > Samsung dlp hl-s5086w
Author Thread: Samsung dlp hl-s5086w
Username: Hogrydah
turn it on, it plays for about 10sec, screen goes off and then 5 sec later the audio goes off, anybody got answers for me
Username: Tvtroublesolution
San Diego, California
Post Number: 34
Hi Robert,
It sounds you might have a bad lamp, but let’s troubleshoot first.
The lamp works with mercury gas so it has a lifespan of 6000 hours in average. So if your TV is more than 2 years old and if you haven’t changed the lamp… then it’s most likely your lamp is faulty. Symptoms of a defective lamp are:
>Audio with no picture
>Picture gets dimmer
>Audio and video for a couple of minutes or seconds and then the TV turns off
You can learn more about the lamp in the next link:
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html
Note: Also try taking the lamp out and check if it shattered.
Good luck!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Samsung dlp hl-s5086w [ « Previous ] [ Next » ]
