Thread: Toshiba 62hm84 DLP Bad ballast board availability? |
New member Username: Pchap428
Post Number: 1 Registered: Mar-09
| Posted on Monday, March 23, 2009 - 11:47 am: |
ive been reading through the posts and found that i have the same problem as everyone else- my lamp ballast board is bad - however i am having trouble locating one from any of the sources mentioned- e-bay-conns,tiger-etc - does anyone have a known good source for a #23122468 tos ballast board? thanks so much...P.C. |
New member Username: Morongaman
Palm Springs,
CA
Post Number: 1 Registered: Jun-09
| Posted on Saturday, June 13, 2009 - 02:04 pm: |
Paul Chapman, I have the same problem with my 62HM84. Was wondering if you found the ballast board and if it worked. I would greatly appreciate your help and input. Contact me at: Alandiaz@aol.com or (760) 285-9033 Thank You, Sincerely.......Alan Diaz |
Bronze Member Username: Tvtroublesolution
San Diego,
California
Post Number: 17 Registered: Jun-09
| Posted on Wednesday, July 22, 2009 - 06:33 pm: |
Hi Paul, I searched for the 23122468 Toshiba ballast and found this links: Encompass part http://www.encompassparts.com/products/?TBA23122468 Discount Merchant http://www.discount-merchant.com/SearchResults.asp?Search=23122468+ Part Store http://www.partstore.com/PartSearch.aspx?PartNumber=23122468&x=27&y=12 Or try comparing prices, Google results for the 23122468 Toshiba ballast are: http://www.google.com/search?hl=en&q=23122468&btnG=Search&aq=f&oq=&aqi= Good luck Paul.
