Home > Message Board > Home Video > Projectors > Samsung 50" DLP picture goes out afte...
Author Thread: Samsung 50" DLP picture goes out after short time still have sound
Username: Hutchsc
I have a Samsung HL-R5067W that has been acting strangly. The TV will play normally for anywhere from 5 minutes to 3 hours and the picture will suddenly be gone, however, the sound is still working and the screen is back lit. No picture. I called samsung and they suggested replacing the buld. I replaced the bulb, no change, then the ballast was suggested and I replaced the ballast, only change was that it would last a little bit longer in HD mode before going blank. The other symptom that I have noticed is that the screen will go blank quicker when watching in full screen. To get the picture back all I have to do is turn the TV off for about 30 seconds and it will work again. Anyone have any ideas?
Username: John56dlp
I am having the same symptoms with my 56"
Username: Littlemouse
I have this problem too
any idea?
Username: Lucky101
Hydeabad
United States
I still thing that its either the problem of the bulb. Have you installed the bulb correctly, take a look at this video for installing the bulb guide.
http://www.projectorlampsworld.com/installation_guide.html
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Projectors > Samsung 50" DLP picture goes out afte... [ « Previous ] [ Next » ]
