Thread: Difference HD vs HDTV? |
New member Username: Otrsemidriver
Latham,
NY
Post Number: 1 Registered: Mar-09
| Posted on Sunday, March 08, 2009 - 08:36 am: |
I have a 60" HD Not a HDTV, can someone please inform me of the difference please. My HD 1080p tuner does not show 1080i so well. I installed a HS HDMI it helped a weebit. I'm on time-warner cable and the 1080 channels are choppy or grainy, and changing from 480 to 1080 there is a green streaks as it blacks out for each change of channel or format. is that the green line of death? my unit is two weeks old. I have a DLP Widescreen it should be premo over a LCD or why would IMAX use DLP? also has anyone heard of LED DLP that Samsung Introduced, I have a Misubishi I like the 3D, however I was thinking that Mitsubishi should go LED asap. So whats the scoop on HD vs HDTV, did i make a better choice as most have HDTV. Thanks. Don |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2444 Registered: Feb-04
| Posted on Sunday, March 08, 2009 - 03:56 pm: |
"....does the set have a built in digital tuner or not? If it does, it's an HDTV; if it doesn't, it's HD Ready." http://www.engadgethd.com/2005/08/30/hdtv-ready-vs-hdtv/ This article was written in 2005, when there were many displays available with no digtal tuner. Now, all TVs have digital tuners. |
