Thread: Jvc hd52z575 problem |
New member Username: Spuddesign
Post Number: 1 Registered: Mar-09
| Posted on Thursday, March 05, 2009 - 06:56 pm: |
had this set about 4 or so years. when the set turns on (powers up) the red "lamp" light slowly blinks 15 times. the tv symptoms has a dark circular blur about 30% in the lower middle of the screen, and overall the whole picture seems alot dimmer than how it used to be. I checked the lamp, it seems crystal clear.. is there still an issue where the lamp could be a problem? When it powers down it does the red "lamp" light slowly blinking 15 times. thanks |
Silver Member Username: Tvshopper
Post Number: 212 Registered: Mar-06
| Posted on Friday, March 06, 2009 - 09:10 am: |
From the manual.... The LAMP LED continues blinking • It may be a malfunction of the internal electrical circuits. |
Post Number: 2 Registered: Mar-09
| Posted on Friday, March 06, 2009 - 02:57 pm: |
ya I came across that too.. what would that suggest? |
Post Number: 213 Registered: Mar-06
| Posted on Monday, March 09, 2009 - 09:37 am: |
Service call. |
