Thread: Tevion TDR930 DVD Recorder problems |
New member Username: Markw6796
Australia
Post Number: 1 Registered: Mar-09
| Posted on Wednesday, March 04, 2009 - 05:48 pm: |
I have a Tevion TDR930 DVD Recorder,a TEAC MV-6094 VCR & a Digitech AR-1822 Digital Video Enhancer & Stabilizer (looks the same as a Sima CT-200 except it doesn't have the mode switch on the side). When I try to transfer store bought tapes, tapes taped off Tv & tapes from my old Sony Camcorder, the picture goes from full colour to allmost no colour at all repeatedly. I've tried :- using 2 other VCRs, tried new & old cables, cleaned the heads on the VCR, had the tapes cleaned at Blockbuster in a tape cleaning machine, downloaded diagrams to make sure the stabilizer is connected correctly, not using the stabilizer, pluging the stabilizer into a socket different to where the rest of the equipment is plugged, after doing all this the result is the same - picture colour fading in & out. When the VCR is connected to the TV the tapes play fine, ie no change in colour. I've connected VCR to TV, then TV>Stabilizer, then stbilizer> DVD Rec. Still no difference. What's going on? I'm getting very frustrated by this! Is the problem the DVD Rec. ? Or the VCR? Or the Stabilizer? Somebody please help |
