Home > Message Board > Home Video > Rear Projection TVs > Everyone With DLP Problem Must Read
Author Thread: Everyone With DLP Problem Must Read
Username: Scott367
Buffalo Grove, IL
I have a Samsung 50" DLP. The lamp went out 3 months ago. I purchased a new lamp from discount-merchandise.com . 3 months later the tv doesn't work.
**If the ballast lights up or blinks on and off your problem is you bought a cheap aftermarket lamp like me.***
you just need another lamp. I figured that the lamp was good and started replacing other stuff like the ballast, I pulled out the color wheel and started checking it, checked the sensor, the switch, the heat sensor. The whole time I just bought a cheap lamp and needed another.
Before you go checking all these other random parts, get an OEM lamp from SAMSUNG, or whoever your tv was made by.
Username: Souperman
Sparta, MI
US
I have a 50 inch T5076S. The problem is I turned the TV on and have no RED color, the picture looks almost gold in color. I tried everything in the manual to readjust the color and still no red. What must I do to get my beautiful picture back? Thank you
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Rear Projection TVs > Everyone With DLP Problem Must Read [ « Previous ] [ Next » ]
